PowerFLARM leeching comments
Old October 22nd 12, 02:52 AM posted to rec.aviation.soaring
Default PowerFLARM leeching comments
On Sunday, October 21, 2012 6:41:11 PM UTC-5, Evan Ludeman wrote:
On Oct 21, 7:35*pm, wrote:
On Saturday, October 20, 2012 5:52:55 PM UTC-4, Dave Nadler wrote:
On Saturday, October 20, 2012 5:30:05 PM UTC-4, Don Johnstone wrote:
... I was very uncomfortable with the concept of instructing
pilots to lessen the efficiency of an anti-colision assistance device.
Stealth mode in no way lessens the efficacy of FLARM anti-collision.
It gives you warnings when there is a collision hazard regardless.
Hope that is clear,
Best Regards, Dave
Dave,
it is clear, and while your statement is probably technically accurate, it isn't entirely correct. *Any mode that reduces the pilot's situational awareness also degrades safety to some extent. Stealth mode by definition does exactly that. *The OC fatality scenario is a case where stealth mode might not provide enough warning to assess the situation and take appropriate action, whereas the 'full' mode probably would. *Just my $0.02
Frank (TA)
See pg 19 of the PowerFlarm Dataport Specification for details about
how stealth mode works.
It's he http://tinyurl.com/8ne9cjx
Stealth mode does not change the anti-collision functionality of
PowerFlarm at all. You'll get the get the same 25 seconds warning,
which is plenty.
Evan Ludeman / T8
"Plenty" is interesting. Let's all remember, flarm is not a "collision avoidance" device. It is a "collision warning" device. You still have to find the other glider, avoid it, and not run in to anyone else while you're doing that. Don't just bank away from the collision threat, make sure there isn't a new collision threat.
If glider A is a collision threat, glider B is off to your side and not a collision threat, will flarm show glider B in stealth mode? No, I gather. If you suddenly bank towards glider B to avoid glider A...
And it doesn't always give 25 seconds warning, especially if carbon fuselages are blocking signals. Gliders have collided when both had operating flarm systems. Norway and Uvalde.
A stealth mode is far from obviously a good idea, if it only shows imminent collision threats. The operation and reliability of such a mode have to be really bulletproof. Which, given power flarm's recent history with range issues, software updates, antenna updates etc., would seem to be something one would want a lot of real world experience with. But how do we get real world experience and find out its actual limitations?
It's interesting how many reports we're getting of pilots who saw collision threats with flarm. But we obviously don't know about the failures until they hit each other. And how do we learn about the failures under stealth mode. Can of worms here.
John Cochrane
Old October 22nd 12, 04:28 AM posted to rec.aviation.soaring
Ramy
Stealth mode in no way lessens the efficacy of FLARM anti-collision..
Hope that is clear,
Best Regards, Dave
Dave,
Frank (TA)
which is plenty.
Evan Ludeman / T8
John Cochrane
I agree with John. I find the situational awareness as important as the collision alert. Also, not sure where the 25 sec came from, but when I was on a head on with another glider at 17K both of us flying above 100 knots TAS, the warning we got was more like 10 seconds, just enough to react and bank away. We never saw each other until we banked away, but luckily we saw each other on flarm radar 5 miles away giving us plenty time to be alerted and be prepared to change course. I sure hope no one will fly in stealth mode.
Ramy
Old October 22nd 12, 12:20 PM posted to rec.aviation.soaring
Dave Nadler
No, I gather.
Correct.
And especially if pilots have not followed sensible practice
installing the antennas, or used antennas with no radiation
downwards. Speak to your fellow pilots when you see this,
it could be your life...
gratuitous obnoxious comment snipped
... would seem to be something one would want a lot of real world
One could possibly pay attention to foreign experience, where many
thousands of FLARM have been deployed for years, instead of
provincially continually reinventing the wheel...
Just a far-out idea, wishful thinking no doubt...
Old October 22nd 12, 03:30 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Hope that is clear,
Best Regards, Dave
Dave,
Frank (TA)
which is plenty.
Evan Ludeman / T8
John Cochrane
If there's a comm problem between flarm transceivers, then the operating mode simply doesn't matter. One advantage of the open mode is that it provides a means to test the system performance without aerial jousting. And yeah, I see a lot of carbon gliders (V2's mainly) with really spotty contact.
Short warning time when comm is established probably reflects maneuvering, i.e. a course conflict that arose "unexpectedly". For high speed head on traffic, "maneuvering" doesn't necessarily mean much. A small heading/glide slope change is all it would take.
T8
Old October 28th 12, 08:44 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
I was very uncomfortable with the concept of instructing pilots to lessen
Stealth mode in no way lessens the efficacy of FLARM anti-collision. It
Hope that is clear,
Dave,
it
isn't entirely correct. Any mode that reduces the pilot's situational
does exactly that. The OC fatality scenario is a case where stealth mode
might
action, whereas the 'full' mode probably would. Just my $0.02
Frank (TA)
From the FLARM manual
"Stealth mode inherently reduces some of the benefits of situation
awareness for yourself and surrounding aircraft. We do not recommend the
use of Stealth mode, but it is better than turning FLARMĀ® off for tactical
reasons."
There is no way that the above can be interpreted in any way other than the
safety benefits are reduced. Do you really want to be seen being
responsible for telling pilots to reduce safety?
http://www.flarm.com/support/Flarm_Competitions.pdf
Old October 28th 12, 11:40 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Hope that is clear,
Dave,
it
might
Frank (TA)
use of Stealth mode, but it is better than turning FLARM® off for tactical
reasons."
It's a matter of how much warning and of what type is useful and actionable..
You have not actually flown with PowerFlarm "radar", have you?
The amount of head down time required to develop any actionable information from present flarm radar screens is scary large. In fact I would argue that given only flarm/butterfly panel mount displays currently available we'll be safer with everyone in stealth mode simply because there will be less to look at on the panel and eyes may stay outside a little more. 3rd parties will solve the display problem even if Flarm doesn't, but the fact remains that radar in open mode shows you mostly targets that are not and will never become collision threats.
Read (I tire of saying this) the dataport spec. Page 19. It describes in detail what stealth mode actually does. Among other things, you'll find that it still displays all radar targets that might become a collision threat.. I can make the argument that this enhances safety because it does not so clutter the display with non-threats.
Evan Ludeman / T8
Old October 28th 12, 07:48 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
=20
=20
=20
=20
=20
lesse=
n
=20
=20
=20
=20
It
=20
=20
Hope that is clear,
=20
=20
=20
=20
Dave,
=20
=20
accurate,
=20
it
=20
=20
definition
=20
mode
=20
might
=20
=20
=20
=20
=20
=20
Frank (TA)
=20
=20
=20
=20
=20
=20
=20
=20
use of Stealth mode, but it is better than turning FLARM=AE off for
tacti=
cal
=20
reasons."
=20
t=
he
=20
=20
=20
=20
=20
actionable=
.. =20
information=
th=
we'l=
less
parti=
remai=
n=
in
th=
threat=
so=
Evan Ludeman / T8
No, but I have flown with an LX800, not that this has anything to do with
it at all. I would rather take the advice of the makers of the instrument
and those who have been using FLARM for some time. Stealth mode is no
longer required here for competitions, the full mode can be used. FLARM are
very clear, "We do NOT recommend the use of stealth mode", which part of
that do you not understand. You ignore it at your peril or perhaps more
likely to the peril of others.
Old October 30th 12, 09:04 AM posted to rec.aviation.soaring
Evan,
I'm fully with you in that head-down time needs to be minimized.
Just for the record, another possibility to reduce the number of irrelevant
targets on the display is of course to reduce the respective horizontal and vertical ranges. Dangerous targets are not affected by the range setting.
Best
--Gerhard
Logger on PowerFlarm? LOV2AV8 Soaring 7 July 27th 12 03:18 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Paul Remde Soaring 9 November 6th 10 04:30 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
PENTAGON CONSIDERING MILITARY BUILD UP AGAINST IRAN (Scroll down to comments section - see page 2 of the comments section as well): [email protected] Naval Aviation 0 December 19th 06 08:37 PM
