PowerFLARM leeching comments
Old November 2nd 12, 05:00 PM posted to rec.aviation.soaring
Andy[_1_]
Default PowerFLARM leeching comments
On Nov 2, 1:23*am, wrote:
we all know the history we had with poor range beginning of this season.
But I do think we have that under control now.
Gerhard,
Would you please sumarise what, if any, changes have been made since
the beginning of the season that would have resulted in increased
FLARM range for the US portable and core systems.
The only change I am aware of is a recall of portables to fit a band
pass filter but that recall has not yet been made.
thanks
Andy GY
Old November 1st 12, 12:50 PM posted to rec.aviation.soaring
On Wednesday, October 31, 2012 10:05:38 PM UTC-4, Ramy wrote:
Don, can you back up your claim that Flarm was designed mainly for wave flying by providing some reference? Also,can you share with us your actual experience flying with Flarm? Ramy
I recall hearing that Flarm was developed to attempt to address the issue of mid air collisions and collisions with obstacles in the Alps. There is a big issue with coming around the corner of a rock and there is another glider. They also have a huge number of wires and such that you can't see.
Maybe the Flarm folks can clarify this bit of history. I'm sure we all would like to know.
UH
Old November 1st 12, 08:44 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
you can't see.
I heard that too - especially the point about flying round a corner in a
mountain face and meeting traffic coming the other way. I think that also
explains the built-in obstacle database.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old November 2nd 12, 11:51 AM posted to rec.aviation.soaring
FLARM has been designed and deployed since the beginning for gliders and light aviation.
It has *not* been designed specifically for wave flight, but rather to cover a wide range
of situations where the human eye can fail. (Wave flight accounts only for a very
small percentage of flight time at least here in the Alps, so the benefit would've been minimal).
The FLARM algorithm is general enough to support any type of aircraft and maneuvers,
with the exception perhaps of aerobatics.
Initially, most installations were in gliders, but tow planes and other GA aircraft
soon followed.
The collision algorithm does work in wave, however with the caveat that the relative
bearing may be off because of the wind influence. This is covered in the manual.
(BTW, the relative bearing will also be off if you fly inverted!
I hope this clarifies a few questions!
Best
--Gerhard
Logger on PowerFlarm? LOV2AV8 Soaring 7 July 27th 12 03:18 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Paul Remde Soaring 9 November 6th 10 04:30 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
PENTAGON CONSIDERING MILITARY BUILD UP AGAINST IRAN (Scroll down to comments section - see page 2 of the comments section as well): [email protected] Naval Aviation 0 December 19th 06 08:37 PM
