LXNav V7 vs Butterfly vario?
Old January 5th 13, 02:02 AM posted to rec.aviation.soaring
Default LXNav V7 vs Butterfly vario?
Richard
The V7 is on my spring wish list. Do you have cables appropriate for connections to Mio 400 running LK8000 and EW Micro Recorder flight logger?
Lane
XF
Old January 5th 13, 02:48 AM posted to rec.aviation.soaring
Richard[_9_]
On Friday, January 4, 2013 5:02:54 PM UTC-8, wrote:
Richard The V7 is on my spring wish list. Do you have cables appropriate for connections to Mio 400 running LK8000 and EW Micro Recorder flight logger? Lane XF
Lane,
I think the Mio is more trouble that it is worth as far a GPS connection.
I would recommend the Oudie Lite that will run the LK8000 Software.
I have direct cables from the V7 to the Oudie, this cable may work or let the smoke out of the Mio.
No problem with the EW Micro the V7 will provide 12V, RX, TX, GND and I can make a cable.
Richard
www.craggyaero.com
Old January 5th 13, 02:59 AM posted to rec.aviation.soaring
Thanks
I love my mio and have my students using it. $50 setup that seems to work fine. I'll try to download the diagrams and see if pinout is same as oudie.
Lane
Old January 5th 13, 06:20 AM posted to rec.aviation.soaring
Bastoune
On Friday, January 4, 2013 7:59:52 PM UTC-6, wrote:
Thanks I love my mio and have my students using it. $50 setup that seems to work fine. I'll try to download the diagrams and see if pinout is same as oudie. Lane
Lane,
I have a V7 and I am extremely happy with it. I ran it connected to a MIO400 this summer and it worked flawlessly. I can't remember exactly what was my cable configuration but it was pretty easy with the pin out provided in the V7 Manual. I switched to a V2 PNA this fall and the cable that was provided with the V7 (normally designed to work with the Oudie) worked like a charm, plug and play.
Where are you Butterfly vario? [email protected] Soaring 17 May 25th 14 06:49 AM
Butterfly vario review [email protected] Soaring 3 October 10th 12 09:50 PM
YouTube Video of the new Butterfly Vario Richard[_9_] Soaring 11 September 25th 12 11:00 AM
Butterfly vario info [email protected] Soaring 1 August 7th 12 11:08 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 05:05 AM
