![]() "Jeff Crowell" wrote in message ... George Z. Bush wrote: I went into it expecting a triple bypass and a replacement valve and ended up with a quadruple bypass, a valve replacement, with oil, filter and lube job thrown in at no extra charge. It's great to hear from you again. Get well quickly, and execise when you can. Great job staying on the right side of the grass! Thanks for the kind words. I'll do my best. See you around. George Z. Jedd |
"George Z. Bush" writes: "Jeff Crowell" wrote in message ... George Z. Bush wrote: I went into it expecting a triple bypass and a replacement valve and ended up with a quadruple bypass, a valve replacement, with oil, filter and lube job thrown in at no extra charge. It's great to hear from you again. Get well quickly, and execise when you can. Great job staying on the right side of the grass! Thanks for the kind words. I'll do my best. See you around. George Z. G.Z., Listen to your Doctors, but don't be too agreeable. - Make 'em think that they convinced you to follow their advice. That way they'll be sure that you'll follow it. And, please, follow the advice. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
My sincerest thanks to each of you who took the trouble to send along their well wishes on the occasion of my recent largely unexpected open heart surgery. I very much appreciated hearing from you guys. I went into it expecting a triple bypass and a replacement valve and ended up with a quadruple bypass, a valve replacement, with oil, filter and lube job thrown in at no extra charge. Anyway, it looks like I'm at the beginning of a fairly comprehensive rehab program, so I may not be on line as much as I have in the past, for a while anyway, which will probably be a relief to many of you. Stay healthy and be good. It beats the hell out of the alternative. George Z. Congratulations on the successful surgery (did they give you a detail job too?) and best wishes for a speedy recovery. Mike |
Great News
-- Scott |
![]() "George Z. Bush" wrote in message ... My sincerest thanks to each of you who took the trouble to send along their well wishes on the occasion of my recent largely unexpected open heart surgery. I very much appreciated hearing from you guys. I went into it expecting a triple bypass and a replacement valve and ended up with a quadruple bypass, a valve replacement, with oil, filter and lube job thrown in at no extra charge. Anyway, it looks like I'm at the beginning of a fairly comprehensive rehab program, so I may not be on line as much as I have in the past, for a while anyway, which will probably be a relief to many of you. Stay healthy and be good. It beats the hell out of the alternative. George Z. Good to have you back, George. Regards, BMC |
