At 00:38 24 February 2013, Sean F F2 wrote:
Good idea. I'll see if we can put something together. =20 In general, the USRC openly considers FAI rules to be dangerous and irrespo= nsible and their US rules alternative (dictated to the US soaring community= ) as the solution to FAIs dangerous irresponsibility. In addition, the USR= C believes that their rules are not only safer but superior in generating = flourishing contest attendance (especially with new or casual contest pilot= s). In other words, US pilots would not fly FAI rule events as they are to= o "hard core.". US rules on the other hand, with there increased safety an= d "decreased likelihood" of land outs greatly improves attendance. No need= for crews, less difficult tasks, etc. We (probably 100 US and Candian pilots, almost 60 have signed) see FAI rule= s as real/true glider racing (Assigned tasks and Assigned Area tasks only).= The rest of the world soaring community (VIRTUALLY EVERY OTHER COUNTRY ON= THE PLANET BASICALLY) happily uses FAI rules for every contest and has sin= ce the sport began. Statistically safety is approximately equal between th= e World standard FAI rules and the essentially obscure US rules. The US is= in isolation from the rest of the world as we are almost a different sport= (checkers vs. chess). The US rules are 2-3x longer than FAI rules for exa= mple. I personally would like to see, for now, that US regionals retain the US ru= les and national championships should immediately adopt FAI rules as they q= ualify US pilots for the World Championship. I want there to be a choice i= n the USA. I wish to disarm the USRC of the ability to act as dictators to= all US pilots (and contests) on what rules are best to use. I think there= is significant misinformation about the FAI rules in the USA because of a = bit if a publicity campaign against them for a reason I do not fully unders= tand. I think there is clearly (sixty signatures from jr pilots to top US = world level pilots) strong demand for FAI rules events within the US dispit= e this negative publicity campaign by the USRC. I feel the USRC is on a bi= t of a crusade to somehow pressure change the FAIs rules and uses the US co= ntests as a test lab. I'll work on the table and post it to a webpage. Sean Sean, Since I am apparently part of this negative publicity campaign, please answer how 80 pounds of lead in the cockpit is not an issue with you? You have never responded to my comments on the pitfalls of IGC CC rules. A skinny pilot in a Discus A has to load up to MTOW that matches a heavy guy in a Discus B, otherwise he is giving up a lot of performance. A heavy guy in an ASW20 can not enter Club Class because he falls outside the handicap range. Our US sports class rules modify the handicap up and down to allow for weight differences. Progressive, smart and safe. What a concept. For the record I have flown 8 IGC contests. Former dictator, Richard Walters 3R |
On Sunday, February 24, 2013 12:19:19 AM UTC-5, Richard Walters wrote:
At 00:38 24 February 2013, Sean F F2 wrote: Good idea. I'll see if we can put something together. =20 In general, the USRC openly considers FAI rules to be dangerous and irrespo= nsible and their US rules alternative (dictated to the US soaring community= ) as the solution to FAIs dangerous irresponsibility. In addition, the USR= C believes that their rules are not only safer but superior in generating = flourishing contest attendance (especially with new or casual contest pilot= s). In other words, US pilots would not fly FAI rule events as they are to= o "hard core.". US rules on the other hand, with there increased safety an= d "decreased likelihood" of land outs greatly improves attendance. No need= for crews, less difficult tasks, etc. We (probably 100 US and Candian pilots, almost 60 have signed) see FAI rule= s as real/true glider racing (Assigned tasks and Assigned Area tasks only).= The rest of the world soaring community (VIRTUALLY EVERY OTHER COUNTRY ON= THE PLANET BASICALLY) happily uses FAI rules for every contest and has sin= ce the sport began. Statistically safety is approximately equal between th= e World standard FAI rules and the essentially obscure US rules. The US is= in isolation from the rest of the world as we are almost a different sport= (checkers vs. chess). The US rules are 2-3x longer than FAI rules for exa= mple. I personally would like to see, for now, that US regionals retain the US ru= les and national championships should immediately adopt FAI rules as they q= ualify US pilots for the World Championship. I want there to be a choice i= n the USA. I wish to disarm the USRC of the ability to act as dictators to= all US pilots (and contests) on what rules are best to use. I think there= is significant misinformation about the FAI rules in the USA because of a = bit if a publicity campaign against them for a reason I do not fully unders= tand. I think there is clearly (sixty signatures from jr pilots to top US = world level pilots) strong demand for FAI rules events within the US dispit= e this negative publicity campaign by the USRC. I feel the USRC is on a bi= t of a crusade to somehow pressure change the FAIs rules and uses the US co= ntests as a test lab. I'll work on the table and post it to a webpage. Sean Sean, Since I am apparently part of this negative publicity campaign, please answer how 80 pounds of lead in the cockpit is not an issue with you? You have never responded to my comments on the pitfalls of IGC CC rules. A skinny pilot in a Discus A has to load up to MTOW that matches a heavy guy in a Discus B, otherwise he is giving up a lot of performance. A heavy guy in an ASW20 can not enter Club Class because he falls outside the handicap range. Our US sports class rules modify the handicap up and down to allow for weight differences. Progressive, smart and safe. What a concept. For the record I have flown 8 IGC contests. Former dictator, Richard Walters 3R Rick, I dont see any problem even with 200lb ballast as long you have it secured and within the weight and ballast limits. Max weight for club class glider comes from manufacturer manual(not invented by IGC).It is total max, less wings water(tail water ok) If your heavy pilot 'falls outside the handicap range"in IGC contest he can not legally fly anywhere.(US or rest of the world) Ryszard |
Club Class Nationals | 5 ugly | Soaring | 37 | September 24th 10 03:27 AM |
US 15 Meters Nationals and Region V South Club Class | [email protected] | Soaring | 0 | March 12th 09 03:59 PM |
Establishing Club Class/Too Many Nationals/Not Enough Competitors | Tim[_2_] | Soaring | 14 | October 2nd 08 03:34 PM |
AUS Club Class Nationals Overall Results | Mal | Soaring | 0 | January 27th 06 09:55 AM |
UK Open Class and Club Class Nationals - Lasham | Steve Dutton | Soaring | 0 | August 6th 03 10:07 PM |
