Parachute Comfort
Old March 30th 13, 12:15 AM posted to rec.aviation.soaring
Dan Marotta
Default Parachute Comfort
snip
Everyone's plane is buried in snow these days, so it's hard to do trial
fits. :-(
Not in New Mexico! Check OLC... ;-)))
Old March 31st 13, 04:25 PM posted to rec.aviation.soaring
Dave Nadler
On Friday, March 29, 2013 8:15:21 PM UTC-4, Dan Marotta wrote:
Everyone's plane is buried in snow these days....
Huh ?
http://www.onlinecontest.org/olc-2.0...=2013&c=C0&sc=
Old March 28th 13, 07:15 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
I mounted a 1050 BRS canister below the rear hatch. The Genesis was designed with BRS in mind, but never tested. The bridle mounts to the 4 lift-fitting, hard points just inside the skin. When deployed below 130 knots and not over 1050 GW, it will bring me down wings level with nose down about 30 degrees. If I should get center-punched bad enough to wipe out the BRS, I figure I would no longer be among the living, anyway. I feel very secure with my little red handle at arms reach and talk about a comfortable cockpit!
JJ
Old March 28th 13, 08:57 PM posted to rec.aviation.soaring
Craig Funston[_2_]
JJ
JJ, that's a pretty nice situation. Even though I rehearse the bailout sequence frequently, I've only got nominal confidence of getting out in a real emergency. Side mounted SH canopy drops my confidence even lower.
Craig
Old March 28th 13, 10:26 PM posted to rec.aviation.soaring
Frank Whiteley
JJ
But JJ, unlike most of us, you have confidence (and experience) in capsule descents;^)
Old March 29th 13, 01:05 AM posted to rec.aviation.soaring
Paul Remde
Hi Frank,
You have me very curious about that comment. Was JJ an astronaut?
Paul
___________________
"Frank Whiteley" wrote in message
JJ
descents;^)
Old March 29th 13, 01:20 AM posted to rec.aviation.soaring
Tom K (ES)
Or a 'Vark driver??
Old March 29th 13, 01:53 AM posted to rec.aviation.soaring
Frank Whiteley
On Thursday, March 28, 2013 7:20:58 PM UTC-6, Tom K (ES) wrote:
Or a 'Vark driver??
That's it. Came down safely somewhere near Roseville, CA, IIRC. McClellan AFB was depot maintenance for the F-111 and they had to be test flown at the end of the visit of course.
Old March 29th 13, 03:48 PM posted to rec.aviation.soaring
"Paul Remde" wrote in message ...
Paul,
No, JJ was a F-111 Weapons Officer
_______________________
Hi Frank,
Paul
___________________
JJ
descents;^)
Old March 29th 13, 01:18 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Actually, we parked a F-111F on the south side of Carson Sink east of Fallon, NV in 1972. Got her into a spin at 20,000 feet. After holding stick full forward, rudder neutral and roll-augmentation off for 8000 feet, we raised the little handles........everything worked as advertised. Sure is nice to have a readily available back up plan.
JJ
Extending new pilot comfort zone? tstock Soaring 14 January 13th 11 07:44 PM
Country Comfort for EAA writewoodz Home Built 1 September 30th 10 09:52 AM
Lightnings In Art, pt 1 - Jack Fellows - Too close for comfort.jpg (1/1) Mitchell Holman Aviation Photos 0 January 12th 07 03:02 AM
Passenger Comfort..... [email protected] Soaring 32 August 9th 05 02:39 PM
Discus 2b cockpit comfort? Jeremy Zawodny Soaring 11 January 12th 04 08:03 PM
