Flanker vs F-15
Old March 26th 04, 05:29 AM
Michael Kelly
Jeff Crowell wrote:
Yabbut, isn't that a case of a Lawn Dart pulling max G and
then hitting turbulence, etc.?
I could see too high of an onset rate, or pulling a turn as you
decelerated through the sound barrier. The latter case would be a very
good candidate if pulling a turn close to the limiter because of the
forward shift in the aerodynamic center going from supersonic to subsonic.
Jeff
Michael Kelly, Bone Maintainer
Old March 26th 04, 05:24 AM
Michael Kelly
R Haskin wrote:
Actually fly-by-wire aircraft can be over-Gd -- it happens to F-16s all the
time.
Agreed. The Bone is a 2 channel FBW on one side with a hydromechanical
stability augmented system on the other side. There are no limiters on
the FBW or stability aug so over G's happen all the time. Limiters on
the 16 make it harder to over G but not impossible.
The F-15, while not "fully" fly-by-wire, has a primary flight control system
that is FBW (called the CAS, or Control Augmentation System) and a
hydromechanical backup system.
IIRC my F-15 test pilot former colleague described the F-15C as fully
hydromechanical and the Echo's as you did. BTW saw you the other day on
the history channel. Good interview.
Cheers,
Old March 26th 04, 08:50 PM
Mary Shafer
On Thu, 25 Mar 2004 05:41:52 -0500, "R Haskin"
"Michael Kelly" wrote in message
m...
John Mullen wrote:
The Su has a pull-through fuction on the fbw ISTR. Might be a factor?
Probably not since the the F-15C isn't FBW and only has an overload
warning function. You can over G a F-15C.
time.
All modern FCSs are electronic, not mechanical or hydraulic, but we
don't consider them to be FBW. We just consider them to be analog or
digital FCSs. However, it's possible to have hydraulic or mechanical
FCSs.
The point is that FBW is strictly between the pilot and the control
surfaces. That's it. Nothing to do with the feedback control in the
flight control system. After all, the SR-71 was summing electric
inputs from the FCS with the push-rod and cable inputs from the pilot
back in the '60s.
You can have FBW without having a feedback control FCS, not that
anyone does, and you can have an FCS without having FBW, which the
F-15 does and the SR-71 did. Or you can have both, which the F-16 and
F-18 do.
Mary
Mary Shafer Retired aerospace research engineer
Old March 26th 04, 08:59 PM
Tarver Engineering
"Mary Shafer" wrote in message
m...
factor?
time.
system
FCSs.
The part that makes the system FBW is a distinction between cable tripped
valves, or electric valves. (current, or hydraulic)
back in the '60s.
The 747-200 and the DC-10 are termed "hybrid FBW" for having cable driven
hydraulic valves controlled electrically.
F-18 do.
An the Boeing 717.
OT-ish Su27 Flanker fans *might* enjoy... Andrew MacPherson Military Aviation 0 February 1st 04 11:33 AM
F-22 Comparison robert arndt Military Aviation 39 December 4th 03 04:25 PM
[New WebSite] Su-27 Flanker Benoit Military Aviation 0 November 11th 03 04:54 PM
Su-27SK(Upgraded), Su-27KUB & new Flanker book Thomas J. Paladino Jr. Military Aviation 6 July 28th 03 07:53 PM
RIAT Fairford Reviews John Cook Military Aviation 4 July 21st 03 07:36 PM
