Grob 104 Speed Astir
Old May 4th 13, 04:39 AM posted to rec.aviation.soaring
John Cochrane[_3_]
Default Grob 104 Speed Astir
On May 3, 9:34*pm, Greg Delp wrote:
I finally got the chance to fly the 104. I have a few issues to try and sort out.
First the airspeed indicator seems to read lower than the actual speed. I will test the pitot static system for leaks as well as against a known good ASI.
Second, while checking out the Cambridge MKIV vario and the MKIV Director it was obvious that the Vario was not behaving correctly. I think it may be over compensated and hope the video below may help someone more experienced could determine if this is in fact the case. The Winter mechanical seems to indicate fairly accurately. It is connected to the TE probe and a flask.. The MKIV is connected to the aft fuselage static ports(4) and pitot tube. The director is connected to the pitot tube and the forward fuselage static ports with the other pitot static instruments.
The mechanical vario seems to display correctly while cross checking the altimeter. The MKIV seems to indicate opposite especially while changing speeds, which can be seen in the video while changing flap settings. Then it sometimes stabilizes and almost matches the mechanical.
Any suggestions? I haven't had the chance to fly on a smooth day yet.
http://www.youtube.com/watch?v=d6yhK...e&list=UUvGOQo...
Buy a new vario. Really, this is ancient equipment, and nothing --
nothing -- helps your soaring performance more than a really good
vario
John Cochrane
Old May 4th 13, 05:34 AM posted to rec.aviation.soaring
Greg Delp
A LX Nav V7 is in the future plans but I'd like to get this one working as well as I can for now.
Old May 7th 13, 06:47 PM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
Second, while checking out the Cambridge MKIV vario and the MKIV Director it was obvious that the Vario was not behaving correctly. I think it may be over compensated and hope the video below may help someone more experienced could determine if this is in fact the case. The Winter mechanical seems to indicate fairly accurately. It is connected to the TE probe and a flask. The MKIV is connected to the aft fuselage static ports(4) and pitot tube. The director is connected to the pitot tube and the forward fuselage static ports with the other pitot static instruments.
vario
John Cochrane
....except perhaps a relief system!
Old May 16th 13, 12:01 AM posted to rec.aviation.soaring
Greg Delp
I got a chance to test the pitot/static system today and came up with the following results. It seems both problems are most likely related as the pitot systems ties the airspeed indicator, Vario, and Director together.
The pitot system did indeed have two leaks. The first and largest is inside the Cambridge MKIV Vario itself. The second smaller leak is inside the MKIV Speed Director. If I clamp off these two pitot connections just outside of the units, the airspeed indicator will hold an almost constant airspeed(a very slow leak of one knot or so in ten minutes). If I clamp off one unit at a time, the Director leak will drop the airspeed at about 10 kts/minute, and the Vario will drop the airspeed almost instantaneously. Since these are quite old and aren't service by Cambridge anymore I decided why not crack the cases and see what I can find. Both units have internal tubing from the case ports to what appear to be pressure transducers. The tubing looks to be in good shape and well sealed. Does anyone know if these sensors are some sort of calibrated leak/flow type of pressure sensor or should they be sealed with no leaks? Would it make a difference if the electrical power was on or off on the units?
If I can't get these units to seal the pitot system better it looks like a new vario will be more urgent than I had planned. I would still love to use these units for now if anyone has any further suggestions. Until then it looks like isolating the airspeed indicator and using the mechanical vario is my only option.
Old May 16th 13, 01:04 AM posted to rec.aviation.soaring
Dave Nadler
IIRC the ASI is implemented with a calibrated leak and
flow sensor in that gear; the leak is normal...
Hope that helps,
Best Regards, Dave
Old May 16th 13, 03:23 AM posted to rec.aviation.soaring
Greg Delp
Any idea if that is true in the MKIV Vario as well? It seems like the leak in the director would be small enough to not cause much of an issue with the actual ASI but the larger leak in the vario is definitely causing low airspeed indications on the ASI. The director does seem to indicate a reasonable push or pull command and average climb/descent based on the vario's output but the vario is indicating opposite of what it should like it's overcompensated when the gliders airspeed is changing then seems to stabilize pretty close to where it should be and somewhat matches the Winter mechanical.
Old May 19th 13, 02:55 PM posted to rec.aviation.soaring
On Thursday, January 24, 2013 4:20:09 PM UTC+2, Greg Delp wrote:
I recently purchased a Speed Astir IIB and I'm in the process of getting it sorted for the next flying season. I'm interested in getting information from current and previous 104 owners regarding their tips, hints, and suggestions on flying the 104 as well as maintaining it and possible upgrades.
I'm currently replacing the pitot static lines and the wiring. I hate mice! The ship is equipped with an Edo Aire 551A which seems to be quite power hungry. There appears to be a voltage drop when transmitting as the Cambridge MKIV vario is affected every time the PTT is pressed. I'm reworking the wiring to get rid of any voltage drops including larger gauge wire and fuses versus the currently installed breakers. I will also reroute the wiring to try and limit any interference issues. I'm also considering making up a 14V battery as well if the problem persists after redoing the wiring.
Once these issues and the interior are replaced I will start to refinish the gel coat. When I bought the glider the control seals (other than the elasti-flap)were in really bad shape. The rudder seal was missing although I could see adhesive residue on the right side and there was a deteriorated fabric seal on the top of the stab and elevator gap. There were no turbulator strips either on top or bottom of the wing. In doing research I've seen the Eppler 662 will see some improvements with turbulators and have the info on placement from one of Udo's threads. Does anyone know what type and size of strips are best for this application? Also are other 104 owners using mylar seals on the rudder and elevator and if so what size seems to work best? Any internal seals?
I'd like to thank Guy "DDS" and "Skimmer" for there insights and help along the way so far.
Just for the record: We redid the instrument panel of our club's speed astir last year (as well as the whole interior, wiring and tubing). My contribution was to create a SolidWorks model for the panel, which was later CNC'ed and came out great (we put in a "brand new" rectangular DX-50). Anyone wanting to use this - just drop me an email to uri at savoray dot com.
Soft landings...
Old July 25th 17, 10:39 PM posted to rec.aviation.soaring
Just figuring out the Rec.aviation.soaring thang .. Uncle Fuzzy has changed ownership hands, and is now dubbed "Uber Fluggen" .. Uncle Fuzzy passed away about two years ago, succumbing to an aggressive malignant brain tumor. We miss him at our club ..
As I'm learning UF, I found it's meant for a smaller person than I. I could lose some 15 lbs, but that might take years and cost lots of lives .. I'm at 193 now.
Instead, I had a couple of questions to ask the G104 Speed Astir II community ..
- the side panels that cover the control links result in a rather narrow fit, and while I fit snugly, this past summer was the first time I had a chance to fly for more than 3 hours. I discovered that the snug fit, combined with the wider instro panel, causes some cramping in my legs after 2.5 hours, so I was wondering if anyone experienced this and if they thought making mods to the side panels to widen them (without interfering with the controls) .. I'm uncertain as to how Uncle Fuzzy coped - he was wider than I, but perhaps it's because I'm a couple of inches taller than he was .. ?
- I had the unusual fortuosity of having both my wing stands and both wing sleeves severely damaged the same day .. by two different personnel. One of the sleeves is workable, but the other is not .. does anyone know of spare wing sleeves, or have they made their own .. ?
Thanks!
Uber Fluggen
Old August 2nd 17, 05:57 PM posted to rec.aviation.soaring
Soartech
I discovered that the snug fit, combined with the wider instrument panel, causes some cramping in my legs after 2.5 hours, so I was wondering if anyone experienced this and if they thought making mods to the side panels to widen them
I also am subject to cramping in my legs after 2.5 hours due to an old injury. I found that taking 3 Advil just before flight completely eliminates this problem and sometimes has the added benefit of reduced urge to pee.
Old August 3rd 17, 05:14 AM posted to rec.aviation.soaring
SoaringXCellence
Sorry to contribute to thread drift, but:
Interesting observation about the Advil (Ibuprofen).
I sometimes get cramps in my calf late at night. I've discovered that taking two Aleve (naproxen sodium) prevents the cramps from occurring at night. I'll have to try it in the glider too, as my feet get cold and crampy at altitude.
Mike
Grob 102 Astir CS fredblair Soaring 1 February 18th 12 12:06 PM
Grob 102 Astir Std III [email protected] Soaring 0 May 30th 07 10:27 PM
FS: Grob G104 Speed Astir II B KO Soaring 0 March 30th 06 01:09 AM
FS - Grob Speed Astir IIB Fred Soaring 3 February 18th 06 04:22 PM
FS - Grob Speed Astir IIB Steve Leonard Soaring 0 February 17th 06 04:42 AM
