On Saturday, June 29, 2013 8:22:46 AM UTC-6, Nigel Pocock wrote:
Excessive initial ecceleration can cause problems with certain types. I have experienced it with 2 types. PW5 with stick fully forward at the start of the launch. Hard acceleration caused the glider to rotate from the nose wheel to the tail wheel and rocket into the air. I only managed to regain control at about 50ft. The other one is the K8. Light glider, high wing. Similar problem. If slow acceleration is a safety problem what about the ground run and take off with aerotow using belly hooks, and autotows? Here's a PW-5 winch launch done right. Note the 1 second ground roll. http://www.youtube.com/watch?v=IseFvZXK7Dw Here's a K8 also with a one second ground roll. http://www.youtube.com/watch?v=ict8W0Q5ZpA Both of these launches were at accelerations greater than 1G. Neither showed an "uncommanded" pitch up. So, neither the gliders nor the acceleration are a problem. |
Thanks for the info Andreas.
Not that the reporting is that diligent in either case when far from home. And BGA Numbers include any that occurred to a BGA member, anywhere, in any registration. Bruce On 2013/06/29 2:23 PM, Andreas Maurer wrote: On Fri, 28 Jun 2013 09:56:50 +0200, BruceGreeff wrote: Indeed. As an example - the BGA statistics include any accident or incident reported by a member anywhere in the world. So their numbers include locations in Spain and South Africa. The German numbers do not. I express no opinion on which is a better approach. Merely that the one is organisational statistics and the other is geographic. HI Bruce, German accident statistics include any accident/incident that happened on a German airfield, in Germany, or in which a German registered aircraft was involved, worldwide. Cheers Andreas -- Bruce Greeff T59D #1771 |
Thanks Andreas
Most informative. The resale value driver is obviously a consideration when exporting a glider. It then appears there is a high difference in historical reported accident rate. Current rates don't seem to be that different. IT is nice to see that the BGA safe winching initiative has made such a difference. Do you know how these numbers compare with the worldwide stats that John Roake collected? I am sure there are a number of contributory factors - including the size/layout of airfield, demographics and composition of fleet which also contribute. In South Africa it has been 14 years since we had a fatal winch accident. No idea how many launches involved. Bruce On 2013/06/26 3:40 AM, Andreas Maurer wrote: On Tue, 25 Jun 2013 18:41:36 +0200, BruceGreeff wrote: From the little I have been able to ascertain. -- Bruce Greeff T59D #1771 |
NTSB crash report, autopsy report- Stevie Ray Vaughan | Mark. | Piloting | 5 | March 22nd 20 10:17 PM |
NTSB Report on Bill Phillips' Accident | Ron Wanttaja[_2_] | Home Built | 63 | September 29th 09 12:02 PM |
Preliminary NTSB report on Walton accident | ChuckSlusarczyk | Home Built | 11 | July 12th 05 04:23 PM |
Prelim NTSB report, Pilatus accident in PA | vincent p. norris | Piloting | 15 | April 11th 05 02:52 PM |
NTSB Aircraft Accident Reports Updated Daily? | [email protected] | Owning | 2 | March 4th 05 01:25 PM |
