If Bill D could be bothered to read my posting before spouting a reply he
wouls see that I had started the launch with full forward stick in both cases. Hard acceration with these gliders can cause the tail to hit the ground hard - not safe. To avoid this the tail of the K8s are usually held down for the launch. Too hard acceration can cause the glider to shoot into the air and immediately into a 45 degree climb despite the stick position. If the rope breaks at this point you have too little height to recover. Hence the winch driver will give slower initial acceleration with these types. By regained control I mean the elevator having any effect. Until then you are just a passenger. I was always taught with ground launch to keep it straight and level until the glider lifts off in a shallow climb. When a safe speed had been reached to rotate steadily into a full climb. At any point in this process you can still recover and land safely using the correct procedures - as taught be both the german and british systems. At 14:42 29 June 2013, Bill D wrote: On Saturday, June 29, 2013 8:22:46 AM UTC-6, Nigel Pocock wrote: Excessive initial ecceleration can cause problems with certain types. I =20 have experienced it with 2 types.=20 =20 PW5 with stick fully forward at the start of the launch. Hard acceleratio= n =20 caused the glider to rotate from the nose wheel to the tail wheel and =20 rocket into the air. I only managed to regain control at about 50ft. =20 The other one is the K8. Light glider, high wing. Similar problem. =20 =20 =20 If slow acceleration is a safety problem what about the ground run and ta= ke =20 off with aerotow using belly hooks, and autotows? K8's and PW-5's, as with all "nose dragger's, are supposed to rotate back o= nto their tail wheels. What do you mean exactly by "regained control"? Yo= u're still with us so, presumably, it worked. With those gliders you shoul= d have started the ground roll with the stick full forward. Aero tow with a CG hook isn't safe as discussed elsewhere on this forum. H= owever a tug can't generate the forces a winch can so a wing drop induced g= round loop likely won't be as severe. |
Excessive initial ecceleration can cause problems with certain types. I have experienced it with 2 types. PW5 with stick fully forward at the start of the launch. Hard acceleration caused the glider to rotate from the nose wheel to the tail wheel and rocket into the air. I only managed to regain control at about 50ft. The other one is the K8. Light glider, high wing. Similar problem. If slow acceleration is a safety problem what about the ground run and take off with aerotow using belly hooks, and autotows? Here's a PW-5 winch launch done right. Note the 1 second ground roll. http://www.youtube.com/watch?v=IseFvZXK7Dw Here's a K8 also with a one second ground roll. http://www.youtube.com/watch?v=ict8W0Q5ZpA Both of these launches were at accelerations greater than 1G. Neither showed an "uncommanded" pitch up. So, neither the gliders nor the acceleration are a problem. |
Thanks for the info Andreas.
Not that the reporting is that diligent in either case when far from home. And BGA Numbers include any that occurred to a BGA member, anywhere, in any registration. Bruce On 2013/06/29 2:23 PM, Andreas Maurer wrote: On Fri, 28 Jun 2013 09:56:50 +0200, BruceGreeff wrote: Indeed. As an example - the BGA statistics include any accident or incident reported by a member anywhere in the world. So their numbers include locations in Spain and South Africa. The German numbers do not. I express no opinion on which is a better approach. Merely that the one is organisational statistics and the other is geographic. HI Bruce, German accident statistics include any accident/incident that happened on a German airfield, in Germany, or in which a German registered aircraft was involved, worldwide. Cheers Andreas -- Bruce Greeff T59D #1771 |
NTSB crash report, autopsy report- Stevie Ray Vaughan | Mark. | Piloting | 5 | March 22nd 20 10:17 PM |
NTSB Report on Bill Phillips' Accident | Ron Wanttaja[_2_] | Home Built | 63 | September 29th 09 12:02 PM |
Preliminary NTSB report on Walton accident | ChuckSlusarczyk | Home Built | 11 | July 12th 05 04:23 PM |
Prelim NTSB report, Pilatus accident in PA | vincent p. norris | Piloting | 15 | April 11th 05 02:52 PM |
NTSB Aircraft Accident Reports Updated Daily? | [email protected] | Owning | 2 | March 4th 05 01:25 PM |
