How Boeing steered tanker bid
Old April 1st 04, 03:36 AM
sid
"Tarver Engineering" wrote in message ...
"Gord Beaman" wrote in message
(sid) wrote:
I should have framed the question this way:
How far would either aircraft fly if there is trouble in the E&E bay
that compromises the electrical system and you are down to DC
power...And then you lose even that?
Isn't that like saying "what would happen if the bloody wings
were to fall off"?...pretty silly statement imo.
I can't understand the obsession with DC power either. Airplanes mostly use
AC power for controls. I have yet to see a synchro that runs on DC.
Further assurance of maintaining proper attitude can come from
dedicated power sources. In the last five minutes of the 1998 tragedy
of Swissair Flight 111, with a raging electrically stoked fire
spreading from the attic space in the cockpit, the two pilots had no
attitude reference at all—not even a turn needle or turn coordinator
to fall back on. They saw inky blackness on the outside and black
primary flight displays [PDFs] inside the cockpit. The standby ADI,
even if it had been working, was located near the bottom center of the
instrument panel. It was poorly lit and even more difficult to see
while wearing smoke masks.
The Swissair jet's standby was lost because it had been hooked to a
vulnerable hot battery bus. When it failed, the powerless gyro started
to spin down. Therein lies a vital object lesson in redundancy:
Standby instruments need their own batteries, so that a loss of
generated power doesn't take down the sole fallback attitude
reference.
Old April 1st 04, 04:08 AM
Tarver Engineering
"sid" wrote in message
om...
use
attitude reference at all-not even a turn needle or turn coordinator
Yep, old Marky Ostendorf modified the airplane such that there was a half
assed exension cord in the cieling carrying 55 Ampres of AC derived from the
battery bus.
reference.
None of that mattered when the magnetic contacter triped bac in and th arc
tracing wire bundle burned an 18 feet long hole in the fuse; including
cutting the doubler at dorr #1. Writing about a case of manslaughter by way
of gross negligence is no reflection whatsover WRT Boeing, or AI airplanes.
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Boeing B-767 Tanker case "Virtual Kryptonite" BJ Military Aviation 1 December 20th 03 05:15 AM
Boeing fires top officials over tanker lease scam. Henry J. Cobb Military Aviation 2 November 25th 03 06:15 AM
AOPA and ATC Privatization Chip Jones Instrument Flight Rules 139 November 12th 03 08:26 PM
Boeing Set For Huge Profits From Tanker Deal ZZBunker Military Aviation 2 July 4th 03 03:18 AM
