![]() Read the book "Destination Disaster" about the THY DC-10 crash outside Paris. This aircraft hit a forest at high speed. There was very little wreckage any bigger than a piece of notebook paper. |
![]() Laura Bush murdered her boy friend wrote in message ... Sept. 11 crash remains shrouded in mystery, Pennsylvania coroner says Miller, the director of a family-run funeral home and elected county coroner for Somerset, Pa., said only eight per cent of the wreckage was recovered. Everything else was vaporised, he said. "We found remains 50 feet deep," he said of the massive crater the plane left on impact. The debris field spanned about 2.5 square kilometres of wooded area. Victim recovery efforts were hampered because most of the salvageable human remains were in the treetops. snip http://www.canada.com/news/national/...4-e2eeafa96b46 ------------------------------------------------------------------- WTF is going on here? Since when do crashes cause 92% of the plane to VAPORIZE?? What preytell do you think happens when an aircraft hits the ground at high speed from relatively high altitude? Perhaps he shouldn't have used the term vaporize, but the end result is the same, a plane ripped mainly into tiny little bits, with a few larger bits surviving. From what I've read people in Lockerbie, Scotland are still finding the occasional bit of Pan Am Flight 103, more than 15 years after it was blown up. And how did most of the human remains end up in treetops? Has that ever happened before? Of course. http://wildcat.arizona.edu/papers/ol...94/01_2_m.html Sounds to me like there were explosives on board that went off on impact. Sounds to me like you don't know anything about plane crashes, or explosives either. Certainly the folks at the NTSB would have found explosives traces on the wreckage when it was examined. Of course its likely you believe they too were in on whatever plot it is you believe in this week. PS - and please note that this article is in a canadian paper. The staff of which would likely laugh at you if they read your post. tim gueguen 101867 |
![]() "tim gueguen" wrote in message news:2wnac.50477$QO2.43514@pd7tw1no... Sounds to me like you don't know anything about plane crashes, or explosives either. Certainly the folks at the NTSB would have found explosives traces on the wreckage when it was examined. Of course its likely you believe they too were in on whatever plot it is you believe in this week. Of course there were explosives on board. It's called Jet Fuel. :^) Slam it into the ground at 500knots plus in a combustible metal container with an ignition source and it goes off pretty nicely. Remember that aircraft are mostly *empty space* and combustible organic material and combustible *metal*. Aircraft are mostly aluminium - which *burns* quite readily if you get it hot enough in the presence of an oxidiser. (Oxygen in the air in this case ) PS - and please note that this article is in a canadian paper. The staff of which would likely laugh at you if they read your post. It's all just crap from a whacko. The CO |
On Wed, 31 Mar 2004 11:04:39 +0930, "The CO"
wrote: Of course there were explosives on board. It's called Jet Fuel. :^) Slam it into the ground at 500knots plus in a combustible metal container with an ignition source and it goes off pretty nicely. Remember that aircraft are mostly *empty space* and combustible organic material and combustible *metal*. Aircraft are mostly aluminium - which *burns* quite readily if you get it hot enough in the presence of an oxidiser. (Oxygen in the air in this case ) HAHAHA. Listen to this loonie. Now he's saying airplanes just burn up all on their own. All that flammable aluminum you know!! HAHA. You rw nuts will lie about anything. |
On Tue, 30 Mar 2004 20:15:10 -0700, Laura Bush murdered her boy friend
wrote: HAHAHA. Listen to this loonie. Now he's saying airplanes just burn up all on their own. All that flammable aluminum you know!! HAHA. You rw nuts will lie about anything. "0108 crashed 11/10/64 near Glasgow AFB while on low-level mission" The fuselage and wings had been completely VAPORIZED! There were some small, melted aluminum "puddles?" left on the ground. Maybe five pieces would fit in your hand if you could find that many. Aluminum burns and it isn't really a loonie HAHA situation when you realize there were real human beings inside of that aluminum frame. |
On Wed, 31 Mar 2004 11:04:39 +0930, "The CO" wrote: Of course there were explosives on board. It's called Jet Fuel. :^) Slam it into the ground at 500knots plus in a combustible metal container with an ignition source and it goes off pretty nicely. Remember that aircraft are mostly *empty space* and combustible organic material and combustible *metal*. Aircraft are mostly aluminium - which *burns* quite readily if you get it hot enough in the presence of an oxidiser. (Oxygen in the air in this case ) HAHAHA. Listen to this loonie. Now he's saying airplanes just burn up all on their own. All that flammable aluminum you know!! HAHA. You rw nuts will lie about anything. Hey, genius, have you ever heard of thermite? One of the components is aluminum. The other is iron oxide (rust) which provides oxygen. In the case of a burning airplane the oxygen comes from the air which, mixed with fuel and aluminum will be extremely hot and not much is likely to survive. Look up rocket fuels and you'll find some that include aluminum. Dan, U.S. Air Force, retired |
Laura Bush murdered her boy friend wrote: HAHAHA. Listen to this loonie. Now he's saying airplanes just burn up all on their own. All that flammable aluminum you know!! HAHA. You rw nuts will lie about anything. And which part does your twisted mind think he is lying about? Aluminum burning? Nope. It's true. Jet fuel burning? No, that's true too. It's how the jet engines run. Come on, out with it. What is he lying about? -Geoff |
![]() "The CO" wrote in message ... "tim gueguen" wrote in message news:2wnac.50477$QO2.43514@pd7tw1no... Sounds to me like you don't know anything about plane crashes, or explosives either. Certainly the folks at the NTSB would have found explosives traces on the wreckage when it was examined. Of course its likely you believe they too were in on whatever plot it is you believe in this week. Of course there were explosives on board. It's called Jet Fuel. :^) Slam it into the ground at 500knots plus in a combustible metal container with an ignition source and it goes off pretty nicely. Remember that aircraft are mostly *empty space* and combustible organic material and combustible *metal*. Aircraft are mostly aluminium - which *burns* quite readily if you get it hot enough in the presence of an oxidiser. (Oxygen in the air in this case ) PS - and please note that this article is in a canadian paper. The staff of which would likely laugh at you if they read your post. It's all just crap from a whacko. Comments from the original poster aside accompanying the posted article, I see no one discussing or refuting the two weird, misplaced tidbits of information contained herein: "There was, in my conclusion, no way we could ever know who they were that charged that cockpit," Wallace Miller told students at the B.C. Institute of Technology. Uh, no, Wallace. The plane was smashed to bits. Right? Was there a reason that we needed to be so redundant? Perhaps it was a badly written article, and thus, a bad example? But then there's this: "The debris field spanned about 2.5 square kilometres of wooded area." How big is that in miles? I'm not sure, but I'll bet it's bigger than the generic "size of a couple of football fields across" reference in most of the other "official stories" I've seen. And in another "official story", the word "six" is used in relation to "miles from the crash scene": http://post-gazette.com/headlines/20...somersetp3.asp "Residents and workers at businesses outside Shanksville, Somerset County, reported discovering clothing, books, papers and what appeared to be human remains. Some residents said they collected bags-full of items to be turned over to investigators. Others reported what appeared to be crash debris floating in Indian Lake, nearly six miles from the immediate crash scene. Workers at Indian Lake Marina said that they saw a cloud of confetti-like debris descend on the lake and nearby farms minutes after hearing the explosion that signaled the crash at 10:06 a.m. Tuesday" Whoo! But hey--if that isn't enough to confound you, get a load of this: they even had robotics out there, poking around, looking for pieces and parts: http://www.postgazette.com/headlines...ppernat3p3.asp Boy, they musta wanted to find EVERY scrap of that plane. That isn't unusual, in and of itself, of course. The more pieces of the plane they can find, the better chance they have of finding a cause. BUT, why would they go to all that trouble, if the thing was smashed completely to bits on its only "impact"? This is what is called a "contradiction": http://www.post-gazette.com/headline...rset0911p4.asp "There was a crater in the ground that was really burning. There were pieces of fuselage and clothing all over the area, burning, said Peterson. He said he didn't see any debris longer than a couple of feet long." Draw your own conclusions. mellstrr |
On Tue, 30 Mar 2004 23:36:30 GMT, "tim gueguen"
wrote: WTF is going on here? Since when do crashes cause 92% of the plane to VAPORIZE?? What preytell do you think happens when an aircraft hits the ground at high speed from relatively high altitude? Perhaps he shouldn't have used the term vaporize, but the end result is the same, a plane ripped mainly into tiny little bits, with a few larger bits surviving. Well "vaporized" is what he said and he's the expert, not you. |
Laura Bush murdered her boy friend wrote: Well "vaporized" is what he said and he's the expert, not you. And how is a funeral director an expert on plane crashes? Do they now require a degree in aerospace engineering in order to be a funeral director? -Geoff |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Sim time loggable? | [email protected] | Instrument Flight Rules | 12 | December 6th 03 07:47 AM |
