Time for pogo sticks.
The idea of launching a glider by having someone run the wing originated with wooden gliders and quite low speeds for stall and aileron effectiveness. Those speeds have gradually crept up through the years, to the point that really nobody can run the wing of a modern glider, with waterballast, and anything less than 10 mph straight down the runway, to the point of aileron effectiveness. Mostly we hope that the wing runner lets go, with the aircraft in balanced position, and it picks up speed faster than one wing drops. That often isn't true. For airtows the results are usually just some scraped gel coat; sometimes a collision with a runway light, and occasionally a ground loop. There have been accidents where wing down gliders hurt bystanders, the Tonopah 15 m nationals being the one I remember best. Clearly, for winching, wing-down events are much more serious. The answer: either retractable or disposable pogo sticks on the wingtips, or mid-wing. Something that keeps the wings level to 25 mph and then either drops off or retracts into the wing. Reading the UK Nimbus 3 report, it would seem that a video link between winch driver and launch point would be a good idea, and quite cheap with current technology. It would cut a crucial second or so out of the abort-the-launch loop John Cochrane |
Hi Justin,
I suspect that this is Bill Daniels, a Google search for Bill Daniels gliding shows that IN the USA in any case he is considered to perhaps be an expert. I suspect that by such comments as "imperial arrogance" he is most certainly not an Anglophile and to be honest find the arrogance part somewhat ironic. Terry Walsh At 12:56 09 October 2013, Justin Craig wrote: Bill, I have watched this tread with some interest. Just for the record, what authority are you on the subject? I find it very interesting that you are so dismissive of the hours of research done by trained professionals who have considerable amount of date and past cases to work with. If this is your humble opinion, look after yourself, but keep your opinions to yourself. If how ever you are some sort of authority in the subject, I will bow to your superior judgement. Regards, Justin At 16:52 08 October 2013, Bill D wrote: On Sunday, October 6, 2013 4:05:57 PM UTC-6, Don Johnstone wrote: All John says is absolutely correct. The sad fact is that this type of accident occurs on a fairly regular basis and as yet no one has come up with a plausible cause. What is clear that the wing drop is a symptom and requires that the glider is released very early which is why the hand should be on the release. A similar accident happened at my club a month back involving a Discus, in that case the pilot was unhurt but the glider was written off. What is clear is that once the glider starts to yaw nothing on this earth is going to stop it except contact with the ground so early release, to mitigate the inevitable accident, is essential. The sad fact is the UK hasn't figured out the cause - everyone else has. |
Number of aero tows in 2011 | Bill D | Soaring | 35 | November 21st 12 03:39 AM |
Looking for a Yellow Tow Release Handle | Randy Teel | Soaring | 3 | August 7th 12 10:36 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 2 | May 14th 10 05:17 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 0 | April 22nd 05 07:21 PM |
CG hook on aero tows?? | Ted Wagner | Soaring | 130 | January 12th 04 11:04 PM |
