Oh!!!! So it,s OK to let your wingtip run along the ground during an areo
tow launch.?? NO NO NO Pull the bloody release when ever your wing is on the gound THAT WILL SAVE YOUR LIFE ONE DAY Soggy 16:16 07 October 2013, wrote: The real point is that having your hand on the release may save your life= , to me that is a complete no brainer. Thanks all for the good thoughts and ideas. I just want to make sure everyo= ne remembers the title of this topic and it explicitly stated during aero t= ows. It is fine that people are talking about winch tows too but please don= 't confuse the two. They are separate types of operations and require diffe= rent flying methods to stay as safe as possible. Keep your hand off the rel= ease during aero tows. Thanks, Bruno - B4 |
Yes, it is OK to do that. I've done it a dozen or some times when the tow pilot came to retrieve me and there wasn't anyone to run the wing. It's never been a problem for me, even with a CG equipped ship.
-John, Q3 On Monday, October 7, 2013 2:30:59 PM UTC-4, John Marsh wrote: Oh!!!! So it,s OK to let your wingtip run along the ground during an areo tow launch.?? NO NO NO Pull the bloody release when ever your wing is on the gound THAT WILL SAVE YOUR LIFE ONE DAY Soggy |
On Mon, 07 Oct 2013 18:30:59 +0000, John Marsh
wrote: Oh!!!! So it,s OK to let your wingtip run along the ground during an areo tow launch.?? NO NO NO Pull the bloody release when ever your wing is on the gound THAT WILL SAVE YOUR LIFE ONE DAY Depends on the glider. For probably 95 percent of the gliders you are correct. But for instance the AS 22-2 (forerunner if the ASH-25) has absolutely no aileron control on the first 200 ft of the ground roll, so in most cases it drops a wing. Since it is usually flown with full water , the wing tip hits hard and it takes some time to pick the wing up again. On the other hand, it's got a a tail load of about 120 lbs on the tail wheel, so it doesn't have the slightest tendency to ground loop. And with a wing loading of 10.5 lbs / sqft it's not going to take of inadvertedly either. So during an aerotow it is possible and safe to pick up the wing again. In this special glider. Winch launch is a completely different animal though. Cheers Andreas |
On Monday, October 7, 2013 12:30:59 PM UTC-6, John Marsh wrote:
Oh!!!! So it,s OK to let your wingtip run along the ground during an areo tow launch.?? NO NO NO Pull the bloody release when ever your wing is on the gound THAT WILL SAVE YOUR LIFE ONE DAY Soggy 16:16 07 October 2013, wrote: The real point is that having your hand on the release may save your life= , to me that is a complete no brainer. Lol, Love your enthusiasm John. I promise it is possible to use the release lever without having to hold on to it the entire tow and put yourself in possible danger of an inadvertent release. Of course you release if you drop a wing and can't raise it safely on aero tow. That doesn't mean you need to keep your hand on the thing. In my glider (ASW27) I have my hand on the spoiler to start and then move to flaps and then move to my knee so it is close to the release in case I need to pull early. I can move the hand to the release at any point. Bruno - B4 |
On Monday, October 7, 2013 2:24:08 AM UTC-6, Don Johnstone wrote:
OK, try sitting in a Schemp Hirth or even and ASW 17/19/20 with the stick full to the left and try finding the release knob if you do not actually have your hand on it. The time you have to realise you have a problem and react is very short, trying to find the release will take longer than the time you have. If reaching the release is difficult, it gets an extension installed ASAP. (That a minor modification not requiring paperwork.) The really bonehead action is to continue flying a glider where the pilot can't reach the release. does that idea actually occur to anyone in the UK? Actually the glider should point down the direction if the initial cable run, of course that should be the same as the direct line to the winch. Only the UK still seems to be using steel cable. Almost everyone else is using "plastic rope" (Dyneema) Plastic rope straightens out like a bowstring as soon as tension is applied so it's always in a "direct line to the winch" which means POINT THE GLIDER AT THE WINCH - NO EXCEPTIONS. Not so, anyone with any experience of winch launching would know that the time taken for a stop signal to be sent, received by the winch driver and reacted on is way more than the time taken for the event you are trying to prevent being over. No one suggests the pilot shouldn't pull the release. But, clearly, in the case of the UK, that isn't working. You need a backup plan to stop the launch if the pilot doesn't act. Wing drop is not the cause of the problem, it is a symptom. The primary problem is yaw and increased acceleration will exacerbate this. WHAT!! Acceleration causes wing drop? Causes yaw? That's as absurd as it gets. To a certain extent this type of accident is an operating hazard. In aviation safety, this is one of the hazardous thought processes called "resignation". Again, no one says a pilot shouldn't have a hand on the release and should pull it if the launch goes wrong but a fair question is, "How's that working out?" Giving a skilled observer at the start point an option to instantly stop the launch if the pilot doesn't act would have saved this pilots life. FIGURE OUT HOW TO DO IT! Or, just ask the Germans. The totally absurd aspect of this is the UK is has a longstanding problem with "cartwheel" accidents like this one. A problem not seen to anywhere near the same degree in the rest of the world. Yet, your response it to lecture everybody else on doing it your way. |
At 17:34 08 October 2013, Bill D wrote:
On Monday, October 7, 2013 2:24:08 AM UTC-6, Don Johnstone wrote: OK, try sitting in a Schemp Hirth or even and ASW 17/19/20 with the stick full to the left and try finding the release knob if you do not actually have your hand on it. The time you have to realise you have a problem and react is very short, trying to find the release will take longer than the time you have. If reaching the release is difficult, it gets an extension installed ASAP. = (That a minor modification not requiring paperwork.) The really bonehead a= ction is to continue flying a glider where the pilot can't reach the releas= e. does that idea actually occur to anyone in the UK? I wish it were that simple. A change of this nature, to a critical control, requires approval from EASA which in turn requires the TC Holder to approve. In all the gliders I fly I use a paracord loop which I loop round my wrist and the release knob. As it is a modification to my hand it does not require EASA approval. I am not going to bother answering the rest of your points, I feel you have proved your ignorance sufficiently. As far as the UK is concerned starting a winch launch with the hand on the release is not optional. As I have said before doing it can save your life, it is a complete no brainer. |
At 20:08 06 October 2013, John Galloway wrote:
At 15:34 06 October 2013, Bill D wrote: On Sunday, October 6, 2013 2:53:16 AM UTC-6, Don Johnstone wrote: http://www.aaib.gov.uk/cms_resources.cfm? file=3D/Schempp-Hirth%20Nimbus-3= %20glider%20G-EENN%2006-13.pdf There are so many bonehead screw-up's in this report it makes one want to c= ry. A few: 1. Not staging the glider so it points exactly at the winch. 2. A VERY long, slow, wobbly takeoff roll despite a 15kt headwind component= .. 3. A failure of the launch crew to stop the launch when a wing went down. 4. Not releasing when it was clear the ground roll wasn't precisely normal. A dry Nimbus 3 launching into a 15 knot wind would likely have aileron cont= rol BEFORE the roll began and should have been airborne in around one secon= d after rolling about a glider length. Obvious point: Once airborne, there= 's no danger of dragging a wing. At least you Brits are good at writing accident reports. This tragic accident happened to one of my club colleagues. With reference to the comments above: 1) There is nothing in the AAIB report to suggest that the glider was not pointing at the winch. It was situated 30m from the position that the cables had been drawn to and so the cable would have been pulled over to the glider. It may have been better to point the glider away from the winch and somewhat towards the line of the cable. (Better still to have minimized the bow in the cable by positioning the glider closer to the cable and pulling the cable as straight as possible.) 2)There is nothing in the report to suggest "a very long, slow, wobbly takeoff roll". I can report from personal experience of many launches from the winch and professional winch-driver involved that this is a very powerful rapidly accelerating winch. The AAIB report makes direct reference to the fact that the winch was operated correctly according to the manufacturer. The cable released at 4 seconds from the start of the launch with the glider already airborne and unrecoverable so that leaves no time for a takeoff roll as characterised above. 3) There is no suggestion in the AAIB report of a "failure" by the ground crew to stop the launch. This point is specifically addressed: "On this occasion both the wing holder and the launch signaller saw the wing touch the ground but events then developed quickly, so it is unlikely that either of them had time to consider and make a ‘stop’ signal. Therefore, the responsibility to release the cable would have to rest with the pilot" 4) Agreed - to release the cable as soon as the wing cannot be kept level is vital. John Galloway All John says is absolutely correct. The sad fact is that this type of accident occurs on a fairly regular basis and as yet no one has come up with a plausible cause. What is clear that the wing drop is a symptom and requires that the glider is released very early which is why the hand should be on the release. A similar accident happened at my club a month back involving a Discus, in that case the pilot was unhurt but the glider was written off. What is clear is that once the glider starts to yaw nothing on this earth is going to stop it except contact with the ground so early release, to mitigate the inevitable accident, is essential. |
Not a single instructor, check pilot or examiner I flew with in England and Germany ever suggested/required holding the release on a winch launch. I was always told to keep my hand close, but not wrapped around the knob.
Worked well every time. |
On Sunday, October 6, 2013 4:54:35 PM UTC-6, Terry Pitts wrote:
Not a single instructor, check pilot or examiner I flew with in England and Germany ever suggested/required holding the release on a winch launch. I was always told to keep my hand close, but not wrapped around the knob. Worked well every time. I think "touching but not gripping" is the best advice. |
Number of aero tows in 2011 | Bill D | Soaring | 35 | November 21st 12 03:39 AM |
Looking for a Yellow Tow Release Handle | Randy Teel | Soaring | 3 | August 7th 12 10:36 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 2 | May 14th 10 05:17 PM |
Schweizer Tow Release Handle/Bracket | Jim Newton | Soaring | 0 | April 22nd 05 07:21 PM |
CG hook on aero tows?? | Ted Wagner | Soaring | 130 | January 12th 04 11:04 PM |
