Don't you just hate it when the propeller departs the aircraft?
Old December 19th 13, 12:15 PM posted to rec.aviation.soaring
Muttley
Default Don't you just hate it when the propeller departs the aircraft?
I would say a further point on the SH Turbos is that they are only started by Windmilling and do not have a Starter Motor, therefore maybe less stress with slower Windmill starts on the Belts and prop shafts!!!!
A SH Turbo Driver
Old December 19th 13, 12:31 PM posted to rec.aviation.soaring
Dave Nadler
A SH Turbo Driver
Um, no, the start mechanism has no affect on fatigue problems.
However, do review the TNs and/or ADs on the support structure
in your installation...
Old December 19th 13, 07:29 PM posted to rec.aviation.soaring
Craig Funston[_2_]
A SH Turbo Driver
There's a very nice article describing the engineering mechanics of prop drives at this link. If the link doesn't work, just google "bd-5 prop shaft analysis" and choose the top link.
Craig
http://www.google.com/url?sa=t&rct=j... d.cGU&cad=rja
http://www.google.com/url?sa=t&rct=j...187178, d.cGU
Old December 19th 13, 08:48 PM posted to rec.aviation.soaring
Dave Nadler
Excellent read, Thanks Craig!
Old December 22nd 13, 10:54 PM posted to rec.aviation.soaring
Check this out http://ad.easa.europa.eu/ad/2013-0217-E.
Yes The Ventus CM has an asymmetrical prop that probably reduces the torsional vibrations.
Dan G (Ventus CM Owner)
On Wednesday, December 18, 2013 11:54:38 AM UTC-5, Dave Nadler wrote:
A prospect was checking out the nifty Antares 18T
sustainer system somewhere over the forest west of ZWB,
when to his great surprise, the propeller departed.
Hell of a way to impress a prospect.
The problem is with the Solo propeller shaft with the
belt reduction system as used on, IIRC:
- Ventus CM (not V2)
- Duo T
- DG-100T
- Antares 18T
Apparently there have also been recent incidents with DG1000T.
The propeller is not identical on all the above so the
failure rates will differ.
Axel Lange has worked with Solo to redesign the offending
part and is working on EASA approvals. IIRC this will be
the 3rd or 4th AD on this part, but Axel can calculate why
it failed and also how to make a part that won't...
I don't know if there's been any communication from SH
or who else uses this particular (front belt-reduction)
Solo system.
I see DG has published some info he
http://www.dg-flugzeugbau.de/index.p...1349&tx_ttnews[tt_news]=147&cHash=cd1730aca0037e72c7b2911e83136b2e
Another reminder to always operate your motor with a
plan for failure at any point...
Aaarrrggggg....
Be safe out there,
See ya, Dave "YO electric"
Old December 24th 13, 02:26 PM posted to rec.aviation.soaring
John Firth[_4_]
What kind of asymmetry?
At least you can retract the engine; not so if the belt breaks.
John F
At 22:54 22 December 2013, wrote:
Check this out
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
Old December 24th 13, 04:22 PM posted to rec.aviation.soaring
Dan Marotta
Is this what you mean?
http://www.glidingmagazine.com/Image...lerPylon01.jpg
"John Firth" wrote in message
John F
Check this out
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
Old December 29th 13, 03:18 AM posted to rec.aviation.soaring
No, Like this http://www.flickr.com/photos/titanet/3923711894/
It's asymmetrical at rest but symmetrical when operating...
Dan
John F
Check this out
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
Old December 29th 13, 03:17 AM posted to rec.aviation.soaring
See this link
So the prop extends to the open position as the RPM increases when starting.
Dan
John F
Check this out
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
Old December 22nd 13, 09:19 PM posted to rec.aviation.soaring
Dave
The LBA restricts the AD to DG1000. The EASA mentions "with unfolding propeller". All gliders in your list have unfolding propellors except the Ventus CM which means the AD doesn't apply to it (yet ?).
Dan G
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
F-16 Norway Departs for Mission Maple Flag Maple1 Aviation Photos 0 February 27th 11 09:44 PM
Oil door departs the airframe Jack Allison Owning 5 June 15th 05 12:28 AM
Propeller for aircraft engine ground test Guy Deraspe Home Built 0 July 21st 04 04:41 AM
