Is the 200ft below Min Finish Height Rule Working?
Old January 21st 14, 01:53 PM posted to rec.aviation.soaring
Default Is the 200ft below Min Finish Height Rule Working?
A hard deck within - say - 4 miles from the finish line is a simple alternative. Get below finish height and you're scored as a land-out.
This is indeed a simple and better alternative. It eliminates all this worry about pilots thermaling low to get over the edge, as well as last minute pull ups. (A pull up to get over the hard deck won't work, as you will run out of energy.)
We don't have it, because you see the uproar that a simple finish cylinder is causing. Mention the words "hard deck" -- even just a doughnut at 500 feet AGL, 4 miles around the airport -- and there will be RAS apoplexy. I brought it up once, and the rest of the RC pointed out wisely that if I wanted to go get tarred and feathered that was fine, but they weren't going to join me.
Don't do big pull ups at the finish!
Once, approaching Hobbs at about 70 knots -- I was on a pretty marginal glide to the cylinder -- about 1.1 miles out a glider rose up right in front of me. He had passed me below at high speed, somehow missed the glider above him (me). Staring at the airport on final glide is common. At the moment of the pull up, I couldn't see him -- I'm above -- and he couldn't see me -- now behind his tail.
When you do a big pull up, there is no way to see who is above and behind you!
John Cochrane
Old January 21st 14, 04:50 PM posted to rec.aviation.soaring
Sean F (F2)
Personally, I kinda like this 4 mile hard deck idea. It is simple to understand and solves a real problem. The idea of pull ups at 1 mile and 700 ft AGL is a little terrifying. The hard deck would certainly prevent that potential behavior.
On the other hand, (devil's advocate), the high points risk associated with flying out over the hard deck with low energy would result in the same "save it" circling just outside of the 4 miles hard deck "shelf" instead of 1 mile finish circle. The good news is the gliders would be slightly higher at 4 miles.
Would this hard deck be 500 AGL (penalty penalty) or 700AGL (finish height)?
Sean
John Cochrane
Sean F2, Evan T8, HELP! Current finish cylinder rule! Tom Kelley #711 Soaring 5 May 24th 13 09:59 PM
Safety finish rule & circle radius Frank[_1_] Soaring 19 September 12th 07 07:31 PM
Height records? Paul Repacholi Soaring 2 September 7th 03 03:14 PM
