Yes in the hanggliding world checklists are pretty
much non existent, you would get laughed at for having one, but what they do use is something called a "hang check" What this is is before you launch off of a cliff or slope, you have an assistant hold your nose wires and you drop down into the prone position, when you do this you can crank your head around and visibly see that you have connected your carbineer correctly to your hang strap and backup hang strap. Usually your assistant also verifies this but I always preferred seeing the connection with my own eyes. This was always common at any site I ever flew at. I also owned a tandem hangglider and did 60-70 tandem flights total, I would never consider launching tandem without doing a proper hangcheck, and I have never been at a site where anyone ever launched tandem without doing this, you could expect a bunch of people to start screaming if they ever saw this. I am not confident a checklist would have saved this tragedy, but I am confident that a hangcheck would have avoided it. By the way hanggliders are far more complicated to assemble than a sailplane is. |
On Friday, February 14, 2014 5:57:41 PM UTC-5, joesimmers wrote:
Yes in the hanggliding world checklists are pretty much non existent, you would get laughed at for having one, but what they do use is something called a "hang check" So do you go through an unwritten preflight checklist for anything that is not verified by the hang check? |
On Friday, February 14, 2014 7:22:14 PM UTC-5, son_of_flubber wrote:
On Friday, February 14, 2014 5:57:41 PM UTC-5, joesimmers wrote: Yes in the hanggliding world checklists are pretty much non existent, you would get laughed at for having one, but what they do use is something called a "hang check" So do you go through an unwritten preflight checklist for anything that is not verified by the hang check? So typically we perform a preflight of the hang glider itself. This is a walk-around/touch-around of the glider after assembly or a hard landing to insure that it is assembled correctly, no bent tubes, wires straight and unkinked, double check bolts/nuts, etc. This is a pretty standard procedure and is documented in the glider manual. I personally also perform a prelaunch check (just as I'm getting situated to launch) similar to the "SCRUB CATS" verbal check that some sailplane pilots use. I've modified it a bit for the hang glider but it works for me. S= Straps; hooked in and check the suspension. C=Canopy; helmet on and buckled. R=Release; When towing, check the release system. U=Undercarriage; rock upright in the harness to insure harness leg straps are proper. B=Brakes; Check parachute pins. C=Controls; insure clearance above the base tube. A=Altimeter; check altimeter, vario, and other instruments to be on and properly set. T=Trim; check the VG. S=Slop; insure that nothing is dangling which could create problems with launch (especially with the tow cart.) I also verbally state "Hooked in, Locked in, and Preflighted". This is where I will look and confirm that I am hooked into the hang strap, the carabineer is locked, and mentally recall the glider preflight process. I then verbally say "Attitude Check" where I make a final assessment of my physiology at the moment to insure I'm up to the task of committing aviation. Not all hang glider pilots use a written or verbal check list but the preflight walk around is pretty standard. The Canada incident is really sad and could have been prevented with a full and proper hang check. Danny Brotto LS-8/18 "P6" Wills Wing U2 145 Wills Wing Falcon 170 |
On 2/14/2014 5:57 PM, joesimmers wrote:
Yes in the hanggliding world checklists are pretty much non existent, you would get laughed at for having one, but what they do use is something called a "hang check" What this is is before you launch off of a cliff or slope, you have an assistant hold your nose wires and you drop down into the prone position, when you do this you can crank your head around and visibly see that you have connected your carbineer correctly to your hang strap and backup hang strap. Usually your assistant also verifies this but I always preferred seeing the connection with my own eyes. Yeah, me too. I personally knew 2 people that failed to do that on cliff launches - they were not hooked in. One was fatal, the second pilot was a gymnast who "simply" hung onto the base tube, swung up, trapeze like, hooked in and landed safely. Tony |
addition to preflight checklist | shkdriver | Soaring | 1 | August 22nd 11 12:44 PM |
Drunk Delta pilot thrown in jail | Nee Ewes | Piloting | 5 | February 7th 11 04:28 AM |
Student Pilot Who Gets 5 Months for Lying on His Application for Medical | [email protected] | Home Built | 2 | June 30th 05 03:00 AM |
Student Pilot Gets Five Months In Prison | Montblack | Home Built | 95 | March 13th 05 02:34 PM |
Student Pilot Gets Five Months In Prison | Montblack | Piloting | 13 | March 3rd 05 05:46 AM |
