Results*of*Flight*Performance*Determination*o f*the*Lak‐17a*FES
Old February 25th 14, 03:21 PM posted to rec.aviation.soaring
Default Results*of*Flight*Performance*Determination*o f*the*Lak‐17a*FES
On Tuesday, February 25, 2014 9:35:19 AM UTC-5, Sean F (F2) wrote:
Rick, My point is that there is no handicap penalty for "being a motor glider". The only factor that is measured in the handicap calculation is the additional weight of the motor equipment. The FES is a new situation in which it has both additional weight AND IMPORTANTLY it also has a significant, measured aerodynamic disadvantage which needs to be taken into consideration objectively when considering its handicap. In this case, if you run the numbers, the FES handicap for the Lak17bFES is only considering the additional weight (75lbs not 135 I think boys). Regardless, no consideration or calculation has been factored in (current US handicap) to compensate for the aerodynamic drag penalty of the system (propellers, etc). These propellers effect the Lak17bFES performance each and every second it flies in contest flight. It should also be considered in the handicap ALONG WITH the extra weight. I think the current handicap is incomplete and unfair to owners of the Lak17bFES and highly discouraging to potential new owners or those considering a modification to a current pure glider. Sincerely, Sean
Then write to the handicap committee and make your case instead of campaigning on RAS which is not part of the process.
It appears to me, possibly incorrectly, that the report on this was only published very recently. I see a 1/14 date on it. If that is so, it was not really available as part of the HC consideration this year. Additionally, they would likely not be aware of it unless an affected person brought it up.
Use the process.
UH
Old February 25th 14, 04:53 PM posted to rec.aviation.soaring
Sean F (F2)
will do. thanks hank.
