Stall/spin and ground reference maneuvers
Old March 5th 14, 06:08 PM posted to rec.aviation.soaring
John Carlyle
Default Stall/spin and ground reference maneuvers
Kirk,
Thank for writing that - very interesting that you mix approach types.
I'm not too clear about your comment "always flying the same pattern into the same airfield pretty much guarantees that your first landout will be exciting". I always use a downwind-base-final pattern, I've logged 10 landouts in farmers fields, and except for having to dodge an electric wire fence once they were low or no drama events (although some of the retrieves were interesting).
Your "de-stabilized" (non-constant airspeed) approach comment was also interesting. I tend to keep high until on final, just to keep my options open, but my speed stays pretty much constant. Being high has helped me on several occasions to delay a bit (once a person behind me with no radio landed under me, another time someone drove onto the field). Do I understand correctly that you tend to keep your energy in speed rather than altitude?
-John, Q3
On Wednesday, March 5, 2014 11:30:30 AM UTC-5, kirk.stant wrote:
On Wednesday, March 5, 2014 7:35:51 AM UTC-6, John Carlyle wrote:
Would you do a circling approach if you were going into a difficult strip, too? Say, a narrow cornfield surrounded by trees. I ask because the Navy pilots I know who fly gliders have reverted to the non-circling approach.
Depends. If low, yes - I'll fly whatever pattern I can to land safely. If I have more time and want to look over the landing area more, then I might fly a higher, longer pattern to give more time to pick the best place to land. Also need to be able to fly bigger patterns when sequencing behind other gliders, so all the skills need to be maintained.
I think it's important to be able to fly a "de-stabilized" (non-constant airspeed) approach in gliders, so that energy can be maintained until late in the approach, and used or gotten rid of as required. Also should be able to fly an approach from just about anywhere around the intended point of landing. Always flying the same pattern into the same airfield pretty much guarantees that your first landout will be exciting! Power pilots are taught to fly "stabilized approaches" because that is how you land a big airplane. Totally unnecessary in small planes, and IMO downright dangerous in gliders.
As far as watching the ASI, after reaching the TLAR point where I want to start the turn, I look just to the inside (11 or 1 o'clock) when initiating the turn, monitor the ASI for trend (glider is trimmed slightly fast), monitor the yawstring, then check how the turn is progressing, then back to ASI - yawstring - turn, etc until time to roll out. If it's a busy runway I might roll out momentarily to check the extended final, then roll back into the turn - those would be pretty aggressive rolls with lots of speed.
Kirk
Old March 5th 14, 08:37 PM posted to rec.aviation.soaring
John Firth[_4_]
Always check for that low airplane dragging it in on a long final.
JMF
At 18:08 05 March 2014, John Carlyle wrote:
Kirk,
Thank for writing that - very interesting that you mix approach types.=20
t=
exc=
landouts=
o=
i=
nteresting).=20
inte=
open,
severa=
un=
correct=
ly that you tend to keep your energy in speed rather than altitude?=20
-John, Q3
=20
str=
Nav=
approach.=
=20
=20
I=
migh=
to
ot=
=20
(non-constant
late
able=
l=
much
taug=
airpla=
gl=
iders.
=20
to=
initiatin=
mo=
A=
I=
int=
=20
Kirk
Old March 5th 14, 10:10 PM posted to rec.aviation.soaring
John Carlyle
Yes, indeed! That was just one of several "interesting" experiences I had a that contest...
-John, Q3
JMF
open,
severa=
un=
-John, Q3
Old March 6th 14, 04:03 AM posted to rec.aviation.soaring
kirk.stant
My experience is that you can never be sure that you will be able to fly a "textbook" pattern, so better to be comfortable in a variety of situations. It's a matter of getting your glider from where it is to short final to your desired landing area, at a safe speed and altitude for the existing conditions. Patterns are guides - but one can land safely from all sorts of patterns; one can also (as we are proving) crash from "textbook" patterns.
If you have the luxury of large fields and plenty of time, then setting up a "standard" pattern is always a good option - but what if you don't have those options? You may find on base that the field you picked is not landable, or the wind changes 180 degrees due to a gust front; you may be following a valley and have to suddenly land in that field on your left; or you may get back to your own field and be in a gaggle of gliders all vying for the same runway at the same time. Most of my landouts have been benign also - but I've also done a couple of final glides into fields that I couldn't see and the pattern consisted of one turn, gear & flaps down, and land. I think you have to be prepared for these kinds of eventualities, and be able to fly your glider safely when low and stressed. That takes planning and practice.
Energy is the key, high and fast is nice, lower and fast is OK, but slow and low is never good until over the threshold! I see my "hot" pattern speed as a minimum and if it gets a bit high I don't worry about it - final is a fine time to decelerate and get ready to land. Again, it depends on the situation - if there are lots of gliders around trying to land, then playing off altitude and speed is a useful tool to use to get sequenced into the flow - and extra speed on final is good unless you KNOW you have to land short! If there is nothing going on and it's the last landing of the day, then a perfect, constant speed pattern is a fun challenge; but if it's a hectic arrival, I may have to maneuver aggressively to get down; then speed control is more of the "stay fast, stay fast, stay fast..." variety until the immediate problem of where to go is solved. Stall/spins make lousy pattern entries!
Cheers,
Kirk
66
Old March 7th 14, 03:47 PM posted to rec.aviation.soaring
John Carlyle
Kirk,
Thanks for your detailed answer. I understand what you're saying - be flexible and be prepared to do what you gotta do when you gotta do it.
I tend to make mistakes when I rush, so I try to keep ahead of the situation. During landings I do this by using the typical downwind-base-final pattern. It doesn't always work out, of course, during BFRs it's common for me to get a release on tow and hear the instructor say "where you going to land now"? That practice has helped immensely with the problems you mentioned of being in a gaggle of gliders all trying to land now, or needing to make a quick change of farmers field when the first choice had to be ruled out.
-John, Q3
Cheers,
Kirk
66
Improved shear/stall-spin alarms KiloKilo[_2_] Soaring 23 June 11th 13 11:55 PM
Another stall spin Jp Stewart Soaring 153 September 14th 12 07:25 PM
Ground Track Maneuvers? Mike Rhodes Piloting 15 September 19th 11 03:45 AM
Stall/ Spin testing the RV-12 cavelamb himself[_4_] Home Built 3 May 14th 08 07:01 PM
Glider Stall Spin Video on YouTube ContestID67 Soaring 13 July 5th 07 08:56 AM
