On Monday, April 21, 2014 9:49:36 AM UTC-7, Dan Daly wrote:
On Monday, April 21, 2014 12:45:44 AM UTC-4, Mike the Strike wrote: Well, I can report that the PowerFlarm core fails to warn me of commercial traffic most of the time. In the past week, I have been within distances of concern to a Boeing 737 and a Canadair Regional jet - they descend over our gliderport into Tucson International. My transponder seems to work, though - both these aircraft took evasive action to avoid me. The Canadair was at my altitude and had to make a very steep turn away from me. Not a peep from the Flarm! Mike Mike - you have either installation or configuration problems. I have an original brick, and I see every airliner, towplane, glider with transponder, and GA with transponder nearby - we're under the most-used approach path for a major Canadian airport, and see traffic all day, every day. I use the standard centre-fed dipole that came with my brick. Try swapping with a known good antenna and see if the problem is cured... Dan: I was coming to the same conclusion and will review my installation! |
Definitely keep us posted, Mike. If not an antenna issue, maybe there's also a configuration setting you have that must be tweaked?
(I definitely agree with the grumbles about the PF folks not being great at customer communications & documentation) The PF "brick" in my '300 definitely warned me about mode C GA traffic many times! --Noel |
My earlier PCAS issue was an antenna issue. Try another antenna.
I assume you have the latest firmware. Ramy |
On Sunday, April 20, 2014 10:14:46 AM UTC-5, Dan Marotta wrote:
Listen up, Guys: GA, military, and airlines are NOT using Flarm. Oh, and we have at least one guy at Moriarty who has a Flarm but not a transponder. So he and the half dozen or so Flarm equipped gliders can avoid each other but he's cruising along blissfully unaware that ATC can't see him, nor can the airliners or military flights that buzz in and out of ABQ daily. Blissfully unaware? Well, since GA, military, and airliners are pretty much all using either Mode A/C, Mode S, or ADS-B, that PFlarm-only guy is probably fully aware of the location of any potentially threatening traffic in his vicinity - even that VFR doctor in the Bonanza squawking 1200 and not talking to anybody... And he is also aware of where all his gliding buddies are - and that's a lot of fun, too! - even the clueless new guy who it trying to run into him under his nice Cu in the middle of nowhere. So while I agree that if you routinely mix in with high-speed airline traffic (common out West, not as common in most of midwest or east) a transponder is a smart thing, I think that a PFlarm is even more of a good thing. Both is best. Try it - you might like it. Seriously. Cheers, Kirk |
While I agree with what you said about the fun of knowing where your buddies
are, you missed my point that it's ATC and other aircraft that can't see the Flarm-only glider. Sure he (might be able to) see them, but they can't see him. I also had to draw the line at mounting a device that can only either block my panel or my outside view. Sometimes more is not necessarily better but I know opinions vary on what to have. Finally at the risk of starting a flame war, I would not install a device that I consider to be still in beta test. XCSoar releases beta software but they identify it as such and ask experienced users to "gorilla test" it and identify problems. From the level of complaints I've read regarding Flarm firmware updates, missed targets, suppression, antennae, displays, etc., I believe it's still a beta product. Sure it does great things, but it would not yet receive a TSO. Happy testing! "kirk.stant" wrote in message ... On Sunday, April 20, 2014 10:14:46 AM UTC-5, Dan Marotta wrote: Listen up, Guys: GA, military, and airlines are NOT using Flarm. Oh, and we have at least one guy at Moriarty who has a Flarm but not a transponder. So he and the half dozen or so Flarm equipped gliders can avoid each other but he's cruising along blissfully unaware that ATC can't see him, nor can the airliners or military flights that buzz in and out of ABQ daily. Blissfully unaware? Well, since GA, military, and airliners are pretty much all using either Mode A/C, Mode S, or ADS-B, that PFlarm-only guy is probably fully aware of the location of any potentially threatening traffic in his vicinity - even that VFR doctor in the Bonanza squawking 1200 and not talking to anybody... And he is also aware of where all his gliding buddies are - and that's a lot of fun, too! - even the clueless new guy who it trying to run into him under his nice Cu in the middle of nowhere. So while I agree that if you routinely mix in with high-speed airline traffic (common out West, not as common in most of midwest or east) a transponder is a smart thing, I think that a PFlarm is even more of a good thing. Both is best. Try it - you might like it. Seriously. Cheers, Kirk |
Dan,
A famous science fiction writer, Jerry Pournelle, once wrote that "perfect is the enemy of good enough". That applies to PowerFLARM in spades. Even in its present "beta" stage (your words), it works very, very well. It hasn't risen to the level of "saved my butt" yet, but it has certainly helped me avoid some very close encounters, including one with a 747 sneaking up on my rear 400 feet above me! I agree with Darryl and Kirk - you should get both a PowerFLARM and a Mode S transponder if you possibly can. They were tough to shoe-horn into a LS8 cockpit, but believe me, they repaid my sweat (and my monetary) investment! -John, Q3 On Monday, April 21, 2014 9:52:10 AM UTC-4, Dan Marotta wrote: While I agree with what you said about the fun of knowing where your buddies are, you missed my point that it's ATC and other aircraft that can't see the Flarm-only glider. Sure he (might be able to) see them, but they can't see him. I also had to draw the line at mounting a device that can only either block my panel or my outside view. Sometimes more is not necessarily better but I know opinions vary on what to have. Finally at the risk of starting a flame war, I would not install a device that I consider to be still in beta test. XCSoar releases beta software but they identify it as such and ask experienced users to "gorilla test" it and identify problems. From the level of complaints I've read regarding Flarm firmware updates, missed targets, suppression, antennae, displays, etc., I believe it's still a beta product. Sure it does great things, but it would not yet receive a TSO. Happy testing! |
John, fair enough regarding perfect being the enemy of good enough. Please
send me one and I'll try it out! :-) "John Carlyle" wrote in message ... Dan, A famous science fiction writer, Jerry Pournelle, once wrote that "perfect is the enemy of good enough". That applies to PowerFLARM in spades. Even in its present "beta" stage (your words), it works very, very well. It hasn't risen to the level of "saved my butt" yet, but it has certainly helped me avoid some very close encounters, including one with a 747 sneaking up on my rear 400 feet above me! I agree with Darryl and Kirk - you should get both a PowerFLARM and a Mode S transponder if you possibly can. They were tough to shoe-horn into a LS8 cockpit, but believe me, they repaid my sweat (and my monetary) investment! -John, Q3 On Monday, April 21, 2014 9:52:10 AM UTC-4, Dan Marotta wrote: While I agree with what you said about the fun of knowing where your buddies are, you missed my point that it's ATC and other aircraft that can't see the Flarm-only glider. Sure he (might be able to) see them, but they can't see him. I also had to draw the line at mounting a device that can only either block my panel or my outside view. Sometimes more is not necessarily better but I know opinions vary on what to have. Finally at the risk of starting a flame war, I would not install a device that I consider to be still in beta test. XCSoar releases beta software but they identify it as such and ask experienced users to "gorilla test" it and identify problems. From the level of complaints I've read regarding Flarm firmware updates, missed targets, suppression, antennae, displays, etc., I believe it's still a beta product. Sure it does great things, but it would not yet receive a TSO. Happy testing! |
Dan,
Can't provide the goods, because I'm not giving mine up! I will give you a prediction: when you finally fly with a PowerFLARM you're going to be asking yourself over and over "why did I wait so long to get one"? -John, Q3 On Monday, April 21, 2014 8:46:40 PM UTC-4, Dan Marotta wrote: John, fair enough regarding perfect being the enemy of good enough. Please send me one and I'll try it out! :-) |
On Sunday, April 20, 2014 8:14:46 AM UTC-7, Dan Marotta wrote:
it strikes me funny that nobody seems to have noticed that it's the "same altitude" aircraft that's going to hit you. It's not that nobody has noticed. I have posted about this issue before. The reason FALRM implemented this change is that it is less bad than having continuous alerting to ownship transponder. Why would you want all transponders at co-altitude to be suppressed? Because they have not figured out how to suppress the only co-altitude transponder that needs to be suppressed - the one in the same aircraft as the Power FLARM. Andy |
Zaon figured it out years ago. My PCAS does not alert on my transponder.
In fact, with a simple button hit, it displays my squawk code to verify that it's giving me alerts based upon my transponder altitude rather than its own internal pressure sensor. Why can't the PFlarm simply eliminate the most powerful transponder received? That would have to be your own unless another aircraft is parked with his transponder antenna closer to your PF antennae than your own transponder antenna and that ain't bloody likely. "Andy" wrote in message ... On Sunday, April 20, 2014 8:14:46 AM UTC-7, Dan Marotta wrote: it strikes me funny that nobody seems to have noticed that it's the "same altitude" aircraft that's going to hit you. It's not that nobody has noticed. I have posted about this issue before. The reason FALRM implemented this change is that it is less bad than having continuous alerting to ownship transponder. Why would you want all transponders at co-altitude to be suppressed? Because they have not figured out how to suppress the only co-altitude transponder that needs to be suppressed - the one in the same aircraft as the Power FLARM. Andy |
PowerFLARM 3.0 and TIS | Andy[_1_] | Soaring | 6 | January 21st 14 09:35 AM |
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 | Tim Taylor | Soaring | 20 | June 17th 13 05:56 PM |
PowerFLARM 2.71...WTF? | [email protected] | Soaring | 40 | May 2nd 13 03:32 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
