Fatal crash Arizona
Old September 10th 16, 12:39 AM posted to rec.aviation.soaring
BobW
Default Fatal crash Arizona
On 9/9/2016 3:58 PM, Bob T wrote:
Snip
A really scary comment in the NTSB final report: "Postaccident examination
of the glider's release system revealed that it was missing a spring, which
likely resulted in the cable not engaging in the detent and caused the
premature release from the tow line."
http://www.ntsb.gov/_layouts/ntsb.av...04X34426&key=1
It was a bumpy day. I took off about 10 minutes of Bob and hit strong
turbulence and sink over the last few hundred yards of the runway. My 200
foot countdown took much longer than usual, but, as I continued on tow,
finally got up and found a good thermal and left the area, unaware of the
crash that had occurred behind me.
Bob was a very experienced jet pilot with thousands of hours, but had just
gotten into gliding and had only recently purchased the glider. Having his
glider release itself because of a faulty release mechanism in turbulence
only 100 ft. AGL and only desert trees ahead, our newbe pilot made the
unfortunate fatal decision to turn back and spun in.
When was the last time YOU had your release checked by a professional???
"Right on!" regarding "known-good release health."
Philosophical agreement aside...if (big "if") the release was an original
Aerotek release, I've a hard time getting my head around the NTSB's "missing
spring" possibility (though if it happens, it must be possible).
So far as I'm aware, every Zuni left the factory with a clone of Dick
Schreder's dirt-simple HP release (used in every HP I've examined, including
up to HP-16's and one HP-18).
The original release uses a single spring, easily visible (assuming the
cockpit-side of the release wasn't subsequently enclosed by some sort of
doghouse). But more to the point, without the spring the original release
simply doesn't *work* properly - as in, requiring active, precise-and-fiddly,
action (on-the-rope-connnector-person's-part), to make a tension-holding
connection. I know because I tried both my HP-14 and Zuni (S/N 3)releases
sans-spring, on the ground, just out of curiosity. As it was, even with a
properly functioning release, part of my pre-launch routine was describing to
(almost!) every rope-connecting-person how to connect the rope (a task Joe
Pilot could not assist with from within the cockpit). Whereas having "Joe
Average Connector Person" make a successful connection with a functioning
spring is "verbally trivial" from Joe Pilot's perspective, I doubt I could
have talked through J.A.C. Person into making a(n apparently) secure
connection in the absence of a spring. Memory says that doing so requires two
hands, one with access to the interior/cockpit side of the release.
Now if the spring failed or somehow came loose, I'd expect an immediate back
release the instant the rope lost tension for any reason.
Bob W.
Old September 12th 16, 03:34 PM posted to rec.aviation.soaring
Ernst
Go to the accident docket and read the MATERIALS LABORATORY FACTUAL REPORT.
My conclusion is that the pawl spring had been missing for some time.
Ernst
Old September 13th 16, 04:09 AM posted to rec.aviation.soaring
Bob Whelan[_3_]
REPORT. My conclusion is that the pawl spring had been missing for some
time.
Ernst
I found the 7-page Factual Report, which includes the statement, "A detailed
examination report for the glider release mechanism is contained in the
Materials Laboratory factual report located in the public docket."
I've been unable to find the "Materials Laboratory factual report." Pointer
help will be Seriously Appreciated!
Meanwhile, I'm still finding it hard to believe the accident aircraft was
successfully operated for ~26 hours without the release spring, though I can
believe the (light-in-tension) spring *might* leave very little in the way of
witness marks on the I.D. of the pawl's through hole.
Thanks very much.
Bob W.
Old September 13th 16, 04:21 AM posted to rec.aviation.soaring
Bob Kuykendall
On Monday, September 12, 2016 at 8:09:10 PM UTC-7, Bob Whelan wrote:
...I've been unable to find the "Materials Laboratory factual report." Pointer
The Docket Management System (DMS) has many good detail photos of broken aircraft. It is (or should be) every detail designer's go-to resource:
http://dms.ntsb.gov/pubdms/search/hi...docketID=58737
Thanks, Bob K.
Parowan Fatal Crash ContestID67[_2_] Soaring 30 July 3rd 09 03:43 AM
Rare fatal CH-801 crash Jim Logajan Home Built 8 June 22nd 09 03:24 AM
Fatal crash in NW Washington Rich S.[_1_] Home Built 1 February 17th 08 02:38 AM
Fatal Crash Monty General Aviation 1 December 12th 07 09:06 PM
Fatal Crash in Fittstown, OK GeorgeC Piloting 3 March 7th 06 05:03 AM
