Fatal crash Arizona
Old May 9th 14, 03:06 AM posted to rec.aviation.soaring
Bruce Hoult
Default Fatal crash Arizona
On Wednesday, May 7, 2014 1:20:44 PM UTC+12, Bill D wrote:
I can assure you that the higher a glider's performance, the safer it is. It's the old, low L/D gliders that can run out of altitude before getting lined up with the runway.
It's a mystery to me why some people think you can "get away with" so much more in old gliders than in those great big heavy clumsy glass ones.
Somewhere in this thread I saw a statement that you could safely turn back from 150 ft in an old glider (which I agree with), but you're a dead man if you try it below 300 ft in glass.
The differences that govern such a thing just aren't that big!
Let's look at some numbers for weight and wing area of typical training gliders (from Wikipedia):
ASK13: 290 kg, 17.5 m^2
Blanik L13: 292 kg, 19.15 m^2
PW6: 360 kg, 15.3 m^2
ASK21: 360 kg, 17.95 m^2
Puchacz: 368 kg, 18.16 m^2
Janus: 365 kg, 17.3 m^2
G103: 390 kg, 17.9 m^2
Duo Discus: 410 kg, 16.4 m^2
DG1000: 415 kg, 17.5 m^2
There's not a lot of difference in the wing areas, with individual variations bigger than the generational differences.
Yes, the glass ones weigh a bit more. How much more?
Someone flying solo in an ASK21 is at about the same all up weight as someone in a ASK13 with a smaller than average instructor in the back seat.
Someone flying solo in a DG1000 is at about the same all up weight as someone in a ASK13 with a largish instructor in the back seat.
We expect students to be able to cope with the flying characteristic differences between having an instructor and not having one -- and to cope with that difference on their first time flying alone!
Old May 10th 14, 01:13 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
is.
much
back
if
seat.
cope
I think you are missing the point. The difference between the perceived
attitude of a Discus flying at 45kts (too slow) or 55kts (much better) in a
turn is very small, easy to get wrong.
The perceived attitude difference in a T21 Sedburgh between 35kts (slow)
and 45kts(better) is quite large, easy to spot if you got it wrong. Bearing
in mind that a T21 would not stall until you got it back to 22-25kts made
low turns much more unexciting. The T21 and T31 are the gliders I was
referring to.
When it all turns to ratsh1t in a glass glider it happens that much more
quickly than it ever did in wood.
Old May 10th 14, 08:20 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
is.
getting
much
back
if
seat.
cope
a
Bearing
referring to.
All completely correct but there is one even bigger problem, most pilots
when making a low level turn off a launch failure or to modify a
circuit/pattern that has got too low, tend to be looking for/at the place
they intend to land with little or no attention to spare for the ASI,
attitude or slip/skid indicator, that's why these events are so productive
of stall/spin accidents. Training needs to emphasise, GLANCE AT THE ASI
EVERY 2 - 3 SECONDS IN THESE CIRCUMSTANCES. Attitude is un unreliable
indicator very near the ground, even the smallest undulations in the
terrain can give a false impression and just being low can make the
attitude look more nose down than it is.
Old May 7th 14, 04:35 AM posted to rec.aviation.soaring
Bob Whelan[_3_]
On 5/6/2014 5:56 PM, Don Johnstone wrote:
Major Snip...
I will stick with my
300ft thank you, I know it works. Low turns, below that height may have
been acceptable in old wooden gliders, the minimum height in T31 and T21
gliders was 150ft, but for modern glass gliders it is just far too low...
Snip...
Volunteers for testing whether a lower-speed/higher-rate glider (T21/T31
certainly qualify) requires less height to execute a course reversal compared
to a higher speed/lower-sink rate modern plastic one? While testing, please do
contact the ground in controlled flight...
...you
only have to look at the accident statistics to see that low final turns
figure to a large degree in accidents so why plan for it?
Because: a) it happens (statistics); and b) (IMO) we reasonably safely can?
(That's certainly NOT the case when practicing the inadvertent departure from
controlled flight in the pattern.) And the skill might be good to have in
one's skill set? I'm not trying to be snarky, but it's the *uncontrolled*
ground contact that jumps out from the death statistics I've seen.
I repeat a controlled descent with wings level is far more likely to have a
better result than hitting the ground in a turn or even worse spinning in
trying to avoid it.
Roger both thoughts...especially that last one!
It's not "merely" the broken rope Joe Glider Pilot needs to be prepared for
as "the" source of an in-pattern prematurely terminated tow. Except for
training flights, I've never had an in-pattern premature tow termination...but
I know of lots of others who "for real" have, with causes including (off the
top of my head) unlatched canopies, passenger idiocy, improperly connected tow
rings and almost certainly more I'm forgetting.
Stuff happens. Prepare - mentally, training, muscle memory - accordionly.
Bob W.
Old May 8th 14, 12:23 AM posted to rec.aviation.soaring
waremark
We have a
rule here in the UK, launch failure on aerotow below 300ft a landing should
be made ahead, or slightly to one side. No attempt should be made to turn
back below this height.
As a UK FI(S) and FIC, previously a Full Cat instructor, this is news to me. Where is it expressed?
I thought the rule was to exercise judgement. I always address 'where would you go now' issues with students and on check flights. In most conditions and situations I would turn back from lower than 300 foot.
Old July 18th 14, 05:10 AM posted to rec.aviation.soaring
flgliderpilot[_2_]
On Tuesday, May 6, 2014 4:41:23 PM UTC-4, Don Johnstone wrote:
While in no way do I wish to speculate on the cause of this accident or
indeed suggest that my comments in any way address the cause of this
accident.
I feel that comment is needed on some of the things said here. We have a
The reason is simple, a controlled crash into difficult terrain is likely
to result in a better outcome than an uncontrolled arrival on the airfield.
The important bit to keep intact is the bit you are sitting in, the rest of
the glider does not really matter too much. The best chance of achieving
that is flying to the ground with the wings level. It has only happened to
me once, there was a field ahead but it was full of the Tiger Moth tug that
had landed in the middle. I discovered that there was just enough space for
a Skylark 2 as well. I have no doubt that a turn back would have resulted
in an accident. I was at 250ft agl max.
If there really is nowhere to land ahead you should really ask the
question, "should I be taking a launch".
Frankly I would be horrified to be required to conduct a turn back at
200ft, I would suggest that this is one of those occasions where the danger
of practice is to great to justify.
Sometimes it's hard to face the fact that the glider must be destroyed to survive. Trying to save the device could be a deadly decision.
Again, I don't know what actually happened, best guess, inadvertent unintentional release. Whether he tried to turn back, or just plain didn't get the nose down quick enough during a 90 degree or lesser turn, who knows.
The only way to practice rope breaks at 100' is on a simulator (condor).
Old July 19th 14, 03:47 AM posted to rec.aviation.soaring
waremark
Don's suggestion that there is a rigid rule about turn back heights in the UK is a surprise to me (I am an instructor). Select the least bad option at the time. Prepare students for it by (at an earlier stage) saying 'from here I would..'. Later asking 'if the tow fails here, where would you go?'
In most circumstances from 200 foot I would turn back.
Old July 19th 14, 07:20 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
Quite right, individual clubs may have had a minimum turn back height as
advice or even a rule, the BGA has not. I write as the ex-National Coach
who produced the BGA Instructor's Manual.
at=
he=
Parowan Fatal Crash ContestID67[_2_] Soaring 30 July 3rd 09 03:43 AM
Rare fatal CH-801 crash Jim Logajan Home Built 8 June 22nd 09 03:24 AM
Fatal crash in NW Washington Rich S.[_1_] Home Built 1 February 17th 08 02:38 AM
Fatal Crash Monty General Aviation 1 December 12th 07 09:06 PM
Fatal Crash in Fittstown, OK GeorgeC Piloting 3 March 7th 06 05:03 AM
