Fatal crash Arizona
Old May 8th 14, 01:05 AM posted to rec.aviation.soaring
Bruce Hoult
Default Fatal crash Arizona
On Thursday, May 8, 2014 1:20:33 AM UTC+12, Vaughn wrote:
The comparison isn't quite as simple as just looking at L/D. Turn
radius also has a lot to do with your chances of making it back to the
field, and turn radius is proportional to the SQUARE of airspeed.
Compare your example (40 knot stall) with a (horrors) 2-33. The highest
stall listed for a 2-33 is around 30 knots. If you do the math, you
will find that your DG1000 has nearly double the turn radius of the
slower glider.
I've done the math :-) With a 30 knot stall instead of 40, you'll want 41 knots for that 45º banked turn instead of 55 knots. And, yes, the radius will be about 56% as large, or about 65m instead of 115.
Whether that 100m difference laterally after the turn makes a difference is highly airfield dependent. On a wide field you can land straight in in either case. Somewhere else, it might put you on the wrong side of a row of trees.
In a typical place, I'd much rather be twice as far off the center line with twice the L/D :-)
Old May 9th 14, 01:39 AM posted to rec.aviation.soaring
2G
On Tuesday, May 6, 2014 6:20:44 PM UTC-7, Bill D wrote:
On Tuesday, May 6, 2014 5:56:44 PM UTC-6, Don Johnstone wrote:
At 22:22 06 May 2014, Bill D wrote:
On Tuesday, May 6, 2014 2:41:23 PM UTC-6, Don Johnstone wrote:
Frankly I would be horrified to be required to conduct a turn back at
=20
200ft, I would suggest that this is one of those occasions where the
dang=
er
=20
of practice is to great to justify.
If you should check out in the USA, you'll be required to demonstrate
compe=
tence in this maneuver. Every pre-solo student is required to do so and
mo=
re than a half century of safety records do not suggest a problem. In
fact=
, even with low performance gliders, there's quite a large safety margin.
T=
he most likely outcome is a pilot will find the glider uncomfortably high
f=
or a downwind landing requiring full spoilers and a slip.
The logic is simple - it's better to have pilots trained for the option.
N=
o one says a pilot is required to turn back or that 200' is always
adequate=
to do so. What is illogical is to suggest a pilot be required to crash
in=
unlandable terrain when a safe option exists to land on the departure
runw=
ay.
What are you trying to save? The pilot or the aircraft? The priority should
be survival of the soft bit, that is you and me.
As an instructor with nearly 50 years experience I know that when I
initiate an emergency procedure I do so allowing a margin to ensure my
survival if it does not work out, I have been bold but never certifiable.
Most living instructors have the same survival instinct. That is why I have
lived long enough to do 10,000 launches, and of course landings. It has
already been hinted that the practice you describe involves modifying what
you normally do, in my view that probably makes it pretty useless and not
real preparation for the event. If you did carry out the training in
exactly the same way as the possible real event you might find that the
results were very different, not to mention painful. I will stick with my
300ft thank you, I know it works. Low turns, below that height may have
been acceptable in old wooden gliders, the minimum height in T31 and T21
gliders was 150ft, but for modern glass gliders it is just far too low, you
only have to look at the accident statistics to see that low final turns
figure to a large degree in accidents so why plan for it?
I repeat a controlled descent with wings level is far more likely to have a
better result than hitting the ground in a turn or even worse spinning in
trying to avoid it.
PS Despite all that there have been times when I have initiated a practice
emergency and very quickly wished I had not, no plan survives first
contact.
So, you're saying the pilot will be safer if they don't learn to perform the return to runway maneuver when it's safe to do so?
I can assure you that the higher a glider's performance, the safer it is. It's the old, low L/D gliders that can run out of altitude before getting lined up with the runway.
The discussion seems to focus exclusively on the decision height for a turn around. I think that is only one factor in making this decision. As reported by Bob T there was heavy sinking air on the departure end of the runway. Returning to the airport would have required transiting thru this air a 2nd time, which strikes me as inadvisable without much more altitude than Knauff had.
The other issue is that a tow rope break requires immediate lowering of the nose. This is done routinely at altitude, but at low altitude this means pointing the glider's nose uncomfortably down at the ground while executing a steep banked turn. If the ground is rising, as it is at Sampley, the picture seen by the pilot is even more disturbing. All that it takes is a momentary hesitation in this reflex and the outcome can be fatal.
As an aside, I once did a wind mill start in my DG400 below 1000' (over a runway). This maneuver requires achieving in excess of 90 kt airspeed. Because the engine & prop act like dive brakes, you feel like you are standing on your rudder pedals when you do this close to the ground. I got to this airspeed and the prop still didn't rotate. This meant that I had to steepen the descent even more. All of my instincts said no, but my brain said yes, which is what I did. The engine started, but I decided that this maneuver really needs to be started at a higher altitude.
Old May 9th 14, 01:55 AM posted to rec.aviation.soaring
Bill D
Why would anyone lower the nose? The glider is presumably at aero tow speed - 65 - 70 knots which is way above the pattern speed. A better plan is to use the excess airspeed to maintain height while turning until airspeed drops to pattern speed.
The nose is not "uncomfortably down". The turn back is a normal turn.
Aha! You're really a motor glider pilot, not an aero tow pilot which explains your misconceptions.
Old May 9th 14, 02:43 AM posted to rec.aviation.soaring
son_of_flubber
Perhaps I have a fundamental misunderstanding...
but I thought that the AofA at 65 knots on aerotow is steeper than the AofA at 65 knots in free flight. So if you don't reduce the AofA (aka drop the nose) after the rope breaks, the glider will slow down. If you start the turn before reducing the AofA, you may find yourself going too slow for the turn.
It is true that you can use the speed coming off aerotow or PTOT to gain a bit of altitude, but that just means lowering the nose gradually as you bleed off the speed. In both cases the AofA needs to be adjusted to match the desired free flight speed.
I thought that we practiced this 'gain altitude and slowly drop the nose' every time we release from aerotow?
Old May 9th 14, 03:41 AM posted to rec.aviation.soaring
Bill D
I think you are confusing pitch attitude with angle of attack. In unaccelerated flight, for a given weight and airspeed, the AOA will always be the same whether you are being towed or not.
Yes it will slow down if the pitch attitude isn't reduced. However, lowering the nose to establish a normal glide at pattern speed will actually see an increase in AOA due to the lower speed - you're just changing the flight path from a climb to a glide at a slower speed.
What you are saying is if the pilot attempts a turn while continuing the nose-up climb after a rope break, the glider will slow down. Of course it will but in most cases this is desirable since the tow speed was well above pattern speed. Just don't continue the slowdown below pattern speed. The AOA is more closely related to airspeed than pitch attitude.
It is true that you can use the speed coming off aerotow or PTOT to gain a bit of altitude, but that just means lowering the nose gradually as you bleed off the speed. In both cases the AofA needs to be adjusted to match the desired free flight speed. I thought that we practiced this 'gain altitude and slowly drop the nose' every time we release from aerotow?
Yes, this technique is correct but the glider is just transitioning from being towed to a normal glide. The AOA will actually increase as the glider slows down.
Discussions like this highlights why gliders should have an AOA indicator in addition to and ASI.
Old May 9th 14, 02:42 PM posted to rec.aviation.soaring
You have a few things wrong.
First- angle of attack is related to the geometry of the glider and airflow over it. On tow the attitude of the glider is slightly nose up relative to the ground compared to the attitude it would have at the same angle of attack in a gliding configuration.
Second- "Every time" implies that we handle all releases the same. In normal flight we will transition from tow attitude and speed to gliding attitude and the associated speed. If in lift, that likely means slowing to thermalling speed. If not in lift we would be going to the appropriate speed to fly.
Third- There is no reason to try to gain altitude in PTT as the amount of gain accomplished by going from tow speed to pattern/approach speed is likely to be quite small. The correct action is to lower the nose slightly to establish a gliding attitude and speed appropriate for the conditions. In many cases, tow speed is about right for the return to the runway.
Also note that "every time" we turn right on release because that is standard. There is a 50% chance that, due to wind velocity and direction(including shear that may be present), terrain considerations, and position, that the correct action is to turn left.
These considerations are why we MUST have an emergency response plan in mind on every launch. There is no time to figure it out- you must execute the plan you have in your head already.
And forget all the mumbo jumbo calculations espoused in this thread.
UH
Old June 15th 14, 07:09 AM posted to rec.aviation.soaring
2G
PLEASE stop with the sanctimonious crap! I have done hundreds of aerotows. You need to lower the nose because you are in a climb attitude and need to transition to a glide attitude. On your next tow note where the horizon is on the canopy and compare it to where it is after release at the same airspeed.
Tom
Old June 15th 14, 12:31 PM posted to rec.aviation.soaring
Bruce Hoult
On Sunday, June 15, 2014 6:09:22 PM UTC+12, 2G wrote:
PLEASE stop with the sanctimonious crap! I have done hundreds of aerotows.. You need to lower the nose because you are in a climb attitude and need to transition to a glide attitude. On your next tow note where the horizon is on the canopy and compare it to where it is after release at the same airspeed.
While the nose ends up lower, you don't lower the nose. The decrease in airspeed does that for you, and the movement of the stick is rearward, to prevent the nose falling through into a dive and again attaining the aerotow airspeed.
Old June 15th 14, 01:21 PM posted to rec.aviation.soaring
John Firth[_4_]
Whether or not positive action is required to maintain airspeed
depends on the trim; this will be different for nose and belly hooks. A
belly hook on some ( older ) gliders requires
nose down trim to balance the rope force.
JMF
aerotows=
need
t=
i=
air=
speed.
air=
prev=
ai=
rspeed.
Old June 15th 14, 07:20 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
aerotows=
need
t=
i=
air=
speed.
air=
prev=
ai=
rspeed.
The expression you are looking for is "select the approach attitude". That
should be the case after ALL launch failures. With the correct attitude
selected the speed will eventually decay or increase to the correct value.
By selecting the approach attitude you will ensure that the speed is less
likely to reduce below the desired value in any turn. Of course if the
failure occurs at height it may be that normal glide attitude is more
appropriate and this can be selected at the appropriate time but the
initial selection should always be approach attitude.
KISS
Parowan Fatal Crash ContestID67[_2_] Soaring 30 July 3rd 09 03:43 AM
Rare fatal CH-801 crash Jim Logajan Home Built 8 June 22nd 09 03:24 AM
Fatal crash in NW Washington Rich S.[_1_] Home Built 1 February 17th 08 02:38 AM
Fatal Crash Monty General Aviation 1 December 12th 07 09:06 PM
Fatal Crash in Fittstown, OK GeorgeC Piloting 3 March 7th 06 05:03 AM
