#11
John wrote:
I need to acquire a dolly capable of recovering a typical general aviation aircraft with a flat tire. I would like something that I can just place the flat tire wheel assembly onto without removing wheel pants or brakes. It also needs to be capable of being towed up to a mile using only one tug. Any ideas? Have done it with a 4 wheel dolly, but it was one of the really sturdy ones that moving companies use. McMaster-Carr has many of them, but I don't know which model would be it. www.mcmaster.com |
On Thursday, April 16, 2009 7:48:26 AM UTC-7, John wrote:
I need to acquire a dolly capable of recovering a typical general aviation aircraft with a flat tire. I would like something that I can just place the flat tire wheel assembly onto without removing wheel pants or brakes. It also needs to be capable of being towed up to a mile using only one tug. Any ideas? go to theirontire.com for the answer |
On Thursday, April 16, 2009 9:48:26 AM UTC-5, John wrote:
I need to acquire a dolly capable of recovering a typical general aviation aircraft with a flat tire. I would like something that I can just place the flat tire wheel assembly onto without removing wheel pants or brakes. It also needs to be capable of being towed up to a mile using only one tug.Any ideas? I have built what you wish for. It carries a capacity of 10,000lbs and works great. Hydraulics up to twice as much. Typically you can roll a flat tire 1 1/2 ft Even if rim is damaged the same can happen. If interested visit aircraftrecovery.net |
LS4 tail dolly | Leigh | Soaring | 0 | May 30th 08 02:02 AM |
ASK-21 - is a tail dolly necessary? | Dave Springford | Soaring | 7 | December 31st 07 08:43 AM |
FS: ASW-24 Tail Dolly | [email protected] | Soaring | 0 | December 26th 06 02:40 PM |
WTB: used tail dolly | David Campbell | Soaring | 5 | April 17th 06 03:19 PM |
assembly dolly | Udo Rumpf | Soaring | 0 | April 29th 05 04:17 PM |
