Fatal crash Arizona
Old June 16th 14, 10:44 AM posted to rec.aviation.soaring
Fred Bear
Default Fatal crash Arizona
On 6/15/2014 8:18 PM, Tom Claffey wrote:
While I agree that landing straight ahead is best if there is room, your
sequence of events is wrong. On an aerotow the question whether to land
ahead or turn should be made on every launch! "Then ask the question" will
lead to overload and grief! On tow, once you have decided you cannot land
ahead then it may be a turn to an off-field landing if possible, followed
by a
180 turn back to runway when safe. (That will invariably be at least 200')
I repeat: after a failure is not the time to be thinking about where to
go!
Tom
No, what I was taught and what I teach applies to ALL launch failures,
winch, auto tow, and aerotow as detailed above. The first action is to
select the appropriate attitude, at least approach attitude and make sure
that you have a minimum of approach speed. Then ask the question, "Can I
land ahead" If and ONLY if the answer is NO or NOT SURE should any other
action be considered.
That's how I was taught - first immediate action - fly the glider. Then
assess.
I was sent solo in a T21 at Portmoak, flying off winch from the SW end,
accompanied by a sandbag in the RH seat. Two 360 degree turns and a good
landing. Woohoo.
Ok - now for the second solo flight - cable break at 300 feet. All I
remember of my thought processes at the time was to get the nose down
out of full climb immediately before speed bled off, get rid of cable
and then assess - unsure about straight ahead (20/20 hindsight - full
spoiler and land would have worked), too low for short circuit (maybe),
so I made a 90 degree left turn to get some room, turned back to right
and landed across the main onto the alternative area across from the
hangars, passing in front of the winch.
I explained my thought process to the instructor and we reviewed what I
had done - got a slow nod and a well done lad. Good enough for me and a
credit to my instructors. Was sent back up once we had towed the T21
back to the launch point.
Old June 16th 14, 12:43 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
your
will
land
followed
by a
200')
go!
Tom
sure
I
other
Spot on, run away to the south field, worked for me too
assess.
landing. Woohoo.
Old June 17th 14, 07:46 AM posted to rec.aviation.soaring
Andrew[_13_]
In the event of a launch failure (or a bounce on landing) I was
taught to 'adopt the attitude that you would be at that height
during a normal approach', which I think is a clear and good
description of the 'appropriate attitude' that Don recommends. I
completely agree with Don's advice about then checking speed,
and landing ahead as the first choice.
I was worried by writers in this thread who have mentioned
aerotowing at sites where a straight ahead landing from a low PT3
could not be safely made. Single-engine power pilots often accept
catastrophic risks (e.g. from engine failures) but we glider pilots
don't have to. If the PT3 danger is only to the glider, I guess that's
ok, if the owners and their insurance company have no objection.
But if personal injury is risked by PT3, I hope everyone agrees that
such sites should not be used for aerotowing gliders.
failures,
is to
make sure
question, "Can I
any other
Old June 17th 14, 10:17 AM posted to rec.aviation.soaring
Bruce Hoult
I disagree.
Options in the event of a tow failure include:
1) land ahead
2) land cross wind
3) do a (approx) 180 and land downwind
4) do a (approx) 180, enter an abbreviated downwind leg, land crosswind
5) do a (approx) 180, enter an abbreviated downwind leg, land upwind
6) do a (approx) 180, do a normal downwind leg, land upwind
As long as at least *one* of those options is available at all times the site is fine.
Which ones are appropriate does change according to conditions. For example 3) is likely to be a bad idea in all but the lightest winds. But as the wind strength picks up the opportunities for the others increases quickly.
Old June 17th 14, 03:58 PM posted to rec.aviation.soaring
Bill D
I disagree.
1) land ahead
2) land cross wind
I agree with Bruce. However, all those actions require the pilot to have at least basic airmanship abilities which is clearly missing in some posts to this thread.
When applied to flight training, I find terms like "KISS" and "lowest common denominator" to be infuriating. Aviation is not simple and never will be.
When I read "KISS, I'm reminded of Forrest Gump: "Stupid is as stupid does". Rather than aiming to accommodate the "lowest common denominator" in students, demand excellence.
Old June 15th 14, 10:54 PM posted to rec.aviation.soaring
Bill D
On Sunday, May 25, 2014 2:40:01 PM UTC-6, Don Johnstone wrote:
"we do not practice very low winch launch failures, just after liftoff"
That's one of several reasons why the UK has such a terrible safety record on winch launch. I watched a UK 'trained' instructor destroy a glider and put himself in the hospital from a real low failure because he didn't know what to do next. Lacking training, he simply continued the rotation into the climb until the glider stalled.
I insist on simulated low failures just after lift-off. Given a pilot with minimum airmanship skills, there is no danger whatsoever. It's exactly like flying a bungee launch.
"In any event I would never simulate a launch failure at 200 ft if there was
not room to land ahead."
Nor would I - on a winch launch. On aero tow, where rules are different, a 200' failure will be beyond the departure end of the runway where there is often no choice but to turn back. Pilots trained to do so have a better chance of survival.
Parowan Fatal Crash ContestID67[_2_] Soaring 30 July 3rd 09 03:43 AM
Rare fatal CH-801 crash Jim Logajan Home Built 8 June 22nd 09 03:24 AM
Fatal crash in NW Washington Rich S.[_1_] Home Built 1 February 17th 08 02:38 AM
Fatal Crash Monty General Aviation 1 December 12th 07 09:06 PM
Fatal Crash in Fittstown, OK GeorgeC Piloting 3 March 7th 06 05:03 AM
