Houston crash today
Old July 16th 14, 08:42 PM posted to rec.aviation.soaring
Chris Nicholas[_2_]
Default Houston crash today
Sorry, you haven't.
Chris N
Old July 16th 14, 09:10 PM posted to rec.aviation.soaring
Kevin Christner
On Wednesday, July 16, 2014 3:42:12 PM UTC-4, Chris Nicholas wrote:
Sorry, you haven't.
Chris N
Some reasonable questions:
Are there over 25 known accidents (likely more than 50 fatalities) from stall / spin accidents in the Puchacz?
Have very experienced advocates of safety (Tom Knuaff, Cindy Brickner) opined that they have serious concerns about the P. and do not feel it is safe to spin?
Is there any other glider type that has lost ~10% of its production in spin / stall accidents?
If the answer to these questions is yes, it is very irrational to continue putting people at the risk of death. Sorry but think that is arguable.
Old July 17th 14, 09:11 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
Sorry, you haven't.
Chris N
safe to spin?
spin
/ stall accidents?
continue
I think you'll find that the Schweizer 2-32 has lost considerably more than
10% of the fleet inn spinning accidents.
Old July 17th 14, 11:26 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
Sorry, you haven't.
Chris N
is
safe to spin?
spin
/ stall accidents?
continue
tha
It is not the number of gliders lost that concerns me, it is the number
lost following deliberate spins.
In the absence of any other finding of technical defect there are only two
possible causes:
1. The pilot(s) mishandled the glider and failed to apply the correct
action to recover from the spin
2. Under certain, maybe very specific loading conditions it is impossible
to recover from a spin in that particular glider.
Given that the only people who could tell you for certain are dead the
assumption has always been made that the pilots screwed up. The other
possible cause has always been vehemently denied. That is extremely poor
investigative practice, not to mention wooly thinking.
I concede that the 2nd possibility is extremely unlikely but there again
the airline safety people thought that a double engine failure on a twin
engine airliner was extremely unlikely. It took a pilot with the skill of
Sully Sullenberger to recover from that "impossibility"
Old July 17th 14, 01:50 PM posted to rec.aviation.soaring
Chris Rollings[_2_]
In the UK over the last 50 years there have been something approaching 100
fatal spinning accidents in gliders.
One was definitely deliberate (they were running an audio casstte recorder
so we know all that was said) and the handling pilot (an instructor being
trained for up-grade) did not initiate the recovery action until the glider
was abour 250 ft agl. As he was about to initiate the recovery, the Chief
Instructor in the front seat exclaimed "Jesus Christ", two and a half
seconds later the tape cut off (the conclusion we reached was that the
handling instructor was so wrapped up in what he was saying and doing he
didn't register how close the ground was getting and the senior instructor
in the front seat was looking at the rudder pedals to ensure that full
opposite rudder was used, the exclaimation came when he looked up and saw
the ground 300 feet away.
Another came in a spin down from about 5000 feet at the end of a soaring
flight. The, very experienced, pilot was known to deliberately spin off
height at the end of soaring flights, the failure to recover was probably
due to the fact that he was 20 lbs below minimum cockpit load (and knew it)
and behind the aft C of G limit.
One other was a Puchacz on a pre-solo training flight, it spun in some
distance from the field, no witnesses and no evidence as to whether the
spin was deliberate or accidental.
All of the other spin-ins were in circumstances that left no doubt that the
spin was accidental.
Accidental spin-ins occurr when the pilot is distracted from speed
monitoring by some outside circumstance and, when the glider stalls and
starts to spin, fails to recognise the spin departure and take immediate
recovery action (I once arrived at the site of a spin-in only a minute or
so after it hit the ground. The relatively unhurt pilot said, "I can't
understand what happened, there must have been something wrong with the
elevator, I kept pulling back on the stck but the nose wouldn't come up. A
few minutes later he realised he had spun. He had been trained in a regime
that taught spinning but had probably not practiced any in the 400 hours
and 8 years since he finished training). The vast majority of spin-ins
occur from less than 500 feet agl.
The majority of composite single-seat gliders have spinning charactoristics
as bad as, or worse than, the Puchacz.
Sorry, you haven't.
Chris N
is
safe to spin?
spin
/ stall accidents?
continue
tha
possible causes:
Old July 17th 14, 02:59 AM posted to rec.aviation.soaring
On Sunday, July 13, 2014 11:01:46 PM UTC-4, wrote:
A JS-1C crashed today near Houston. Pilot died.
In the event there is not a cross thread issue, this is supposed to be a thread about a Houston JS1 pilot dying in a crash. Under these circumstances, nobody cares about spinning a Puchcaz. Please move your Puchcaz discussion to the Puchcaz spinning thread by Don Johnstone. Thanks.
Crash at MYF today.... [email protected] Piloting 45 February 1st 07 12:37 AM
F-15E Crash today John Doe Military Aviation 0 May 7th 04 04:42 AM
Houston Area Air Crash Ludlow Johnson Piloting 2 November 20th 03 03:10 PM
Wildcat crash in Houston Wright1902Glider Home Built 3 October 27th 03 09:24 PM
Wildcat crash in Houston Wright1902Glider Restoration 0 October 21st 03 03:38 AM
