Recognizing and reacting to tow plane engine failure
Old October 25th 14, 03:48 PM posted to rec.aviation.soaring
Dan Marotta
Default Recognizing and reacting to tow plane engine failure
We always brief that a student will box the wake above 1,000' AGL. We
also prebrief steering turns for training flights. Having said that,
I've steered the tug when he was a new tuggie and having radio
problems. No problems there.
Dan Marotta
On 10/25/2014 4:52 AM, Cookie wrote:
Soooo..when practicing "box the wake" one should expect there is a good possibility to be "given" the rope. ??
Cookie
On Friday, October 24, 2014 4:46:13 PM UTC-4, Bruce Hoult wrote:
On 2014-10-24 16:43:23 +0000, Waveguru said:
Glider pilots and tow pilots have an iron-clad covenant that should be
talked about, not just silently acknowledged: You do your very best
not to kill me, and I'll do my very best not to kill you. Towing is a
unique thing in aviation, it's serious business, and it needs to be
constantly recognized as such.
I had a tow pilot get mad at me just the other month for doing a
steering turn. He slammed the Pawnee over so hard I couldn't follow
him and it broke the rope. My passenger was so freaked out he'll never
fly again. When I talked to the tow pilot about it he admitted that it
****ed him off when I tried to steer him.
Boggs
Around here, if a tow pilot hits the stops on any control (including
rudder) then you're going to wear the rope.
If you want him to turn, use the radio.
Old October 26th 14, 06:08 AM posted to rec.aviation.soaring
Bruce Hoult[_2_]
Cookie
Boggs
If boxing the wake causes the towplane to reach control stops then you
are doing it WAY WRONG and should expect to wear the rope, yes.
Old October 26th 14, 09:45 AM posted to rec.aviation.soaring
Cookie
Ok...and signalling a turn by moving out to the side will not make the towplane hit its rudder stops either ...so what's the problem?
Shall we now replace all 17 of the "standard American soaring signals"...with "use radio"?
Cookie
Old October 26th 14, 10:48 AM posted to rec.aviation.soaring
Bruce Hoult[_2_]
Cookie
If it's mere communication ... like wagging your wings ... that's one
thing. If it's physically pulling the tail around against the tow pllot
attempting to maintain his intended heading then that's quite another.
Old October 26th 14, 01:20 PM posted to rec.aviation.soaring
Cookie
Its all "communication"..
But the whole point of the "turn" signal is that the tow pilot doesn't need to or try to "fight" it.
So which signals do you use radio for and which signals do you use the standard accepted signal?
Do you brief glider pilots as to which signals you do not respond to and which you do?
Has the SSA changed/adopted the accepted signal for "tow plane please turn" to now a "radio signal"?
When the tow plane rudder hits the stop, what happens? It snap rolls!!!??
Cookie
Cookie
Old October 26th 14, 11:03 AM posted to rec.aviation.soaring
Bruce Hoult[_2_]
Cookie
Btw:
Pawnee wingspan 36 ft 2 in. So out at his wingtip you are 5.5 m off
center. On a 60m rope that's 5.3 degrees angle on the rope.
If the glider weighs 600 kg and has a 30:1 L/D at towing speed then
there will be 20 kg of pull in the rope from drag, plus (at 600 fpm, 3
m/s climb and 70 knots 38 m/s airspeed) another 48 kg pull from
climbing. Total 68 kg. About 6 kg of which will be sideways pull on the
tail.
Anyone want to figure out how much rudder deflection it takes to
produce 6 kg sideways force at 70 knots? It won't be a lot.
Old October 26th 14, 01:23 PM posted to rec.aviation.soaring
Cookie
So, you're saying the rudder won't even be near the stop on a typical box the wake, or "please turn" signal....so what's the problem?
Cookie
Cookie
Btw:
tail.
Old October 25th 14, 04:16 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Dumping the glider because the *rudder* hit the stop is way over the top. Someone needs to HTFU.
T8
Old October 25th 14, 05:02 PM posted to rec.aviation.soaring
kirk.stant
What about a situation where the tug's vertical tail stalls due to the glider being way off to the side? If you are holding full rudder against the yaw, and the glider keeps on pulling the tail, you may stall the vertical tail - supposedly the ensuing snap roll is highly entertaining!
This situation may be more theoretical (I think the BGA had an article that mentioned it) but my technique is to let the glider pull my tail around if he really wants to. Unless wake boxing is prebriefed, I pretty much stay off the rudders and let the glider take me where he wants, if he gets out of position laterally.
Kirk
66
Old October 25th 14, 07:14 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Kirk
66
The release is there for real emergencies. 99+% of the time, the rudder hitting the stop momentarily is *not* an emergency.
T8
failure of an auto engine Steve Hix[_2_] Piloting 0 November 26th 09 12:05 AM
AA Engine failure at LAX... .Blueskies. Piloting 3 June 13th 06 11:05 PM
engine failure swag Piloting 16 June 8th 06 06:13 PM
Engine failure Jase Vanover Piloting 59 October 30th 05 05:43 PM
In-Flight Engine Failure O. Sami Saydjari Owning 59 April 30th 04 08:40 AM
