How to determine if your ASG29 has the large or small panel?
Old November 18th 14, 09:24 PM posted to rec.aviation.soaring
Sean Fidler
Default How to determine if your ASG29 has the large or small panel?
Interesting thought. I would hope that others would comment as well but for me, YES.
I do waste(?) time (a quick glance) to look at and interpret the display first before looking out. For me, the "o"clock display is easy to understand from a glance. It gives me situational awareness without alot of mental processing power required. I completely understand what you are saying. Its a worthwhile point to make. Is it worth the glance?
Remember that I am trying to spend 90% + of the time (probably more like 98%) with my eyes out scanning for traffic and watching the clues develop around me (both nearby and far away). I always have a very good idea (I hope) of what is going on around me. If I hear a beep when I didn't think any gliders were around, I know there is potentially a big problem! That is the key.
With that, imagine you are flying along, unaware that another glider is around. Suddenly you get a FLARM collision warning "beep." Without looking at the Flarm display immediately, you have absolutely no idea where that warning is located. Perhaps only 10 seconds may be left before a potential collision. The threat could be coming from behind, below or directly above. It could be "head on" or from the side (either level, up or down). The only way you have any actionable intelligence with Flarm is to immediately empower yourself with the information that the Flarm is trying to communicate to you (and the other Flarm equipped pilot) "directionally" (unless you have a synthesized voice say it to you!). If you wait 5 seconds (say you can't ID any traffic), then look in to see the Flarm display directional info, the danger of that situation is now much higher.
So, if you are suggesting simply looking ahead upon hearing the Flarm audio warning in an effort to rule out the most dangerous situation for an unknown, unseen potential collision, I'm not sure I can agree that that would be the best technique.
Another "fatal" mistake I have experienced while using Flarm is to mistakenly "assume" the traffic you know about (already see) is the traffic the warning is for. I have experienced this. An instance where I have assumed the traffic at the "x" O clock is the Flarm equipped traffic the warning was for, only to realize seconds later than another, unknown glider was the collision warning. A scary, scary adrenaline fueled moment for sure. This is the danger of having many gliders flying together and only having "some" equipped with flarm.
I treat the Flarm as a "cherry on top" of a constant, nervous traffic scan. It is a system that may point out a collision that I would otherwise have not realized was coming.
As a motorcycle rider/racer in my youth, I learned to never (ever) trust any traffic or any seemingly innocent traffic situation. I basically assumed that all other drivers are going to do the exact worst thing (at the worst possible moment). I assumed that in any blind spot (say around a blind corner at a green light intersection) is a out of control semi truck going 90 mph. With motorcycles, I ultimately learned that driving on public roads is simply not worth the risk. Then I took up soaring ;-)...
Soaring is much the same thing for me as motorcycles. Flying in large groups (around airports after launch for example) is a highly unpredictable situation. I assume that everyone is unaware and going to make the turn or maneuver that makes my situation worse. I try to never be in a position where I have to fully trust the other pilot. This takes alot of discipline. The Flarm is only there to give me extra hints, above and beyond my own extreme caution. I never assume the Flarm is going to work at all. But when it does beep loudly, I quickly add what it is trying to tell me to my information bank and confirm it quickly as it "usually" provides very valuable information.
As I understand it, Flarm (generally) first warns its pilot of potential collision 10-15 seconds out. If you wait too long to confirm what its trying to tell you directionally (and don't ID the right traffic in the meantime), its value will have fallen to near zero. Yes, I know Flarm will keep beeping more aggressively as the collision gets more likely but that second beep might be 5 seconds from the first... I say take and glance early and use that information to your advantage while you still can.
Sean
On Tuesday, November 18, 2014 3:15:16 PM UTC-5, John Galloway wrote:
Do you really waste time looking at and interpreting the display first -
before you look out ahead?
At 18:32 18 November 2014, Sean Fidler wrote:
UH,
=20
I agree, FLARM warning speech synthesis is exactly how warnings
should be
c=
ommunicated to the pilots. The idea of a display is fundementally
flawed.
The process of 1) hear warning, 2) glance in to the display, 3)
interpret
t=
he warning then 4) look out and 5) find the traffic and 6) avoid the
traffi=
c (if necessary) is a 3+ second process at best. A quick clear audible
war=
ning (Traffic 1 o'clock, level) might save a second or more. I'm
surprised=
speech synthesis of FLARM WARNINGS are not highlighted more
distinctly in
the product descriptions. I was honestly unaware of it. To be frank
and
h=
onest, I can't think of a more important function in the glider
(especially=
while flying with other a good number of other gliders and towplanes,
etc)=
than very fast and very accurate FLARM collision warnings. All the
other
"stuff" in our gliders are just nice to have when compared to FLARM.
But this means replacing my SN-10. Maybe I can get Dave Nadler to
add
spee=
ch synthesis FLARM warnings to the SN-10 ;-)! Just kidding Dave!
Thanks again all.
Sean
On Tuesday, November 18, 2014 9:54:31 AM UTC-5,
wrote=
On Tuesday, November 18, 2014 8:59:18 AM UTC-5, Sean Fidler
I have a PowerFlarm Brick which connects to the SN10, then the
SN10
sen=
ds NMEA to the Oudie. This all works very nicely but I don't like the
way
the Oudie displays close in Flarm warnings (essentially it doesn't). I
sim=
ply see the Flarm targets on the map view. The Oudie does not jump
to a
Fl=
arm collision screen when a warning is announced. I prefer the
simple
warn=
ing interface of the Flarm displays (balls at the "o'clocks"). Perhaps I
h=
ave the Oudie set up incorrectly? Maybe I can get Dave Nadler to add
a
Fla=
rm warning page to the SN10 ;-)? The FlarmView works well (ball at
o'clock=
s warning view) although I would personally prefer to have a display
that
i=
s neatly and cleanly installed in the open 57mm slot. Perhaps you
have a
g=
ood point on the right placement being on the top of the panel. That
would=
also give me room for something else. It would be easy to place an L
brac=
ket on the top of the panel to mount it. Thanks.
=20
I like ClearNav's "traffic 2 o'clock high" audio output. No look down
at
alarm, interpret, then look. Just listen and look. You aren't looking
down
to figure it out just when you need to find the target.=20
I don't know how many other have this, but to me, this is the way it
shou=
ld work.
FWIW
UH
Old November 18th 14, 09:13 PM posted to rec.aviation.soaring
Dave Nadler
No look down at alarm, interpret, then look. Just listen and look.
You aren't looking down to figure it out just when you need
to find the target. I don't know how many other have this,
but to me, this is the way it should work.
FWIW
UH
There are many, many downstream products (hardware and software) which
produce FLARM voice warnings. Triadis had one at least 5 years ago;
don't know if anyone in USA stocks this:
https://translate.google.com/transla...dvs&edit-text=
Old November 18th 14, 11:56 PM posted to rec.aviation.soaring
I have a Flarm Core, C302, and Oudie running SeeYou Mobile.
SeeYou on the Oudie gives me an audio warning (beeps) and a large red banner warning me of a potential collision. Everything is selectable in the software.
Perhaps you should consider some trouble shooting with Paul Remde. He was very patient with me in sorting out my Flarm/SeeYou issues.
Old November 19th 14, 12:53 AM posted to rec.aviation.soaring
Sean Fidler
Thanks. I remember (now) that Oudie has an audible flarm warning "announcement" but I also remember that I found it hard to understand. The speaker on the Oudie was not the best. At least on my Oudie. Depending on the situation, the cockpit can be very loud with the vario chirping away, wind noise, radio activity, etc. Maybe I need a hearing check.
I know that Oudie does provide good basic FLARM data on the map section of each screen (FLARM RADAR). This works quite well. However, when a collison warning occurs, I believe the banner on the screen shows some useless text like "Warning - traffic 2 O'clock, above" and a spoken warning occurs (that I find hard to understand) if you have the warning turned on. If I remember correctly, the Oudie display itself does not present the directional warning screen like a tradition Flarm does. That is what I really want (see pic below). Audio is only good for me if I can comfortably and very reliably hear it.
pic of screen - http://www.cumulus-soaring.com/flarm...ningScreen.jpg
This is why I bought the FlarmView in the first place (for the directional warning screen).
I just looked at the Oudie manual (http://download.naviter.com/oudie/Oudie.pdf). Here is what I found:
3.9 Flarm Radar
...."SeeYou Mobile is able to read the output from Flarm devices and present a radar-like system which displays other Flarms with correct visibility/privacy settings in vicinity. Flarms that have privacy enabled are hidden."
8.9 Warnings
There is three types of warnings in SeeYou Mobile
1. Airspace warnings 2. Altitude warnings 3. Flarm warnings...
....Flarm warning is special in that it "reads" the information from the Flarm device and then uses voice
Thats it. Nothing is stated and no diagram showing what/if the actual Oudie flarm collision warning screen looks like.
Do you think there is a visual directional warning screen that shows the direction and altitude of the threat on the Oudie display when a warning occurs? If not, I think the boys and girls at Naviteer should consider adding it!
Old November 19th 14, 12:59 AM posted to rec.aviation.soaring
SeeYou gives a loud distinct beep beep beep and displays a red banner at the top of the screen.
The target aircraft symbol turns red.
The screen does not change to some simplified, high magnification display that focuses on the target aircraft.
I find it attention getting and easy to understand.
Cad drawing for ASW27 or ASG29 instrument panel Larry Goddard Soaring 16 December 30th 18 07:19 PM
ASG29 For Sale YourNameHere Soaring 0 May 29th 14 01:04 PM
How to simply determine the L/D of your glider jan Soaring 41 January 17th 11 01:05 AM
How do you determine remaining life of Ceconite covering? [email protected] Aviation Marketplace 2 October 8th 05 01:19 AM
Invest small Earn Large ($20 000+) promethean General Aviation 0 October 3rd 03 06:08 AM
