"Keith Willshaw" wrote: The problem is that merely reaching the altitude is only a part of the problem. The real issue is achieving orbital velocity No, it's not. http://www.xprize.org/teams/guidelines.html "3. The flight vehicle must be flown twice within a 14-day period. Each flight must carry at least one person, to minimum altitude of 100 km (62 miles). The flight vehicle must be built with the capacity (weight and volume) to carry a minimum of 3 adults of height 188 cm (6 feet 2 inches) and weight 90 kg (198 pounds) each. Three people of this size or larger must be able to enter, occupy, and be fastened into the flight vehicle on Earth's surface prior to take-off, and equivalent ballast must be carried in-flight if the number of persons on-board during flight is less than 3 persons." -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
![]() "Chad Irby" wrote in message .com... In article , "Keith Willshaw" wrote: The problem is that merely reaching the altitude is only a part of the problem. The real issue is achieving orbital velocity No, it's not. http://www.xprize.org/teams/guidelines.html I'm aware of the rules of the X prize. Lots of posters in this thread have made comparisons with NASA and alluded to civilian space flight. You need to achieve orbital velocity to do that. Keith |
"Keith Willshaw" wrote: "Steve Hix" wrote in message ... In article . net, "Steven P. McNicoll" wrote: "C J Campbell" wrote in message ... The earlier flights were not done in a re-usable spacecraft. So what? So that is a large part of what makes it different from the single-shot suborbital flights of the past. Not to mention the thousands of man-hours and cast of thousands needed to turn around the shuttle. One step on the road to non-government, gold-plated, decades-long development projects type spaceflight. The problem is that merely reaching the altitude is only a part of the problem. The real issue is achieving orbital velocity and the Rutan aircraft doesnt achive much more than 15% of the velocity required to put something in orbit. That's not the point of this particular exercise. Lindbergh didn't take any passengers, or significant cargo, either. |
"C J Campbell" writes: "Steven P. McNicoll" wrote in message ink.net... Where's the similarity? The Wrights were the first to achieve powered, sustained, controlled heavier-than-air flight. Nobody had accomplished that before the Wrights on December 17, 1903. But manned suborbital flight HAS been accomplished before, four times before, and it was last done over forty years ago. If manned suborbital spaceflight had any real usefulness why did it stop? The earlier flights were not done in a re-usable spacecraft. Most definitely _not_ the case (Or to quote Mary Shafer, "Wrong, wrong, wrongitty wrong!") The two suborbital Mercury flights were not my re-usable spacecraft, But they weren't the only spacecraft used. On July 19, 1963, Joe Walker, flying X-15 66672, reached an altitude of 347,800'. (Flight 3-21-3, Mission # 90 in the X-15 program. On August 22, 1963, Walker, again flying 66672, reached an altitude of 354,200'. (Flight 3-22-36, Mission # 91 in the X-15 program. Are you trying to say that the X-15 wasn't reusable? That'll come as a big surprise to the people who got 199 flights out of 3 aircraft. Note that the August 22 flight was originally scheduled to be flown on Aug 6, 1963, but was aborted before launch due to a systems problem (Computer overheat). There was an attempt to refly on Aug 13, 1963 that was aborted after an APU wouldn't start. Another reply attempt of Aug 15 was aborted due to weather. So the second flight could very easily have occurred on Aug 6. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Spaceship 1 hits 212,000 feet!!!!!! | BlakeleyTB | Home Built | 10 | May 20th 04 10:12 PM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) | Peter Stickney | Military Aviation | 45 | February 11th 04 04:46 AM |
Ta-152H at low altitudes | N-6 | Military Aviation | 16 | October 13th 03 03:52 AM |
