On Friday, December 5, 2014 8:48:04 AM UTC-5, Soaring Tech wrote:
On Thursday, December 4, 2014 9:49:54 PM UTC-5, David Kinsell wrote: it's become clear that the fix being applied to Cambridge units isn't very good and won't make them as reliable as they were prior to November. -Dave Oh my! To all Model 10/20/25,302A and 302 owners who have been following this topic, were happy with there instrument prior to this issue and want to keep using these devices(that's thousands of flight computer/recorders)you can send your recorder to a qualified equipment tech who will replace the 3v re-chargeable battery internal to the Garmin Receiver, send appropriate commands to the Garmin Receiver to reset the date and re-seal the instrument. After that, you are good to go for MANY more years. IF you do not use the instrument for greater than 5 months, then power the instrument overnight to re-charge the Garmin battery as CHEAP insurance. With a little extra care they are as reliable as they were--no better and no worse then prior to this issue.....Gary Thank you Gary for clearing this up. Dennis |
A recent posting by Ian Macphee on the Aus-soaring list says that there
was an older aluminum color case version of the 302, and a newer black case version. Supposedly the black units don't have the date problem because they don't use the GPS25. It may just be age of batteries, but I'm curious if the failures have been following this pattern. I have a black case unit, just tested as good. Clock had drifted by 8 minutes prior to lock, then corrected itself. Unit probably built 2006 or 2007, battery might have been replaced recently, not sure. -Dave On Fri, 05 Dec 2014 02:49:36 +0000, David Kinsell wrote: On Thu, 04 Dec 2014 18:08:27 -0800, tom wrote: I wonder if the affected FR manufacturers could add a mod to detect a timestamp prior to "now" and munge it to the current epoch? Interesting idea, but quite hypothetical when it comes to Cambridge. Garrecht Avioncs seems to have source code for the GPS module, and intends to provide a fix in that code for their Volksloggers. It should be straightforward to add another 20 years of life that way. As the details of the problem have come out, it's become clear that the fix being applied to Cambridge units isn't very good and won't make them as reliable as they were prior to November. Probably makes more sense to just go buy a Nano or something similar if you need to replace the logging capability. -Dave |
My 302 just tested fine and it has the Black case and was manufactured in 2010.
Randy |
ClearNav CNv Vario Owners - Important News | Paul Remde | Soaring | 0 | February 20th 14 11:25 PM |
Big News from Cambridge and ClearNav | Paul Remde | Soaring | 4 | January 30th 14 10:49 PM |
Important News from the USA # 711 reporting. | [email protected] | Soaring | 5 | May 16th 05 05:02 PM |
Great news for Cambridge GPS-NAV owners! | Paul Remde | Soaring | 1 | September 11th 04 02:07 AM |
Important news For all webmaster,newsmaster | Bruce A. Frank | Home Built | 0 | November 1st 03 01:16 AM |
