![]() "Guy Alcala" wrote in message . .. Kevin Brooks wrote: "Guy Alcala" wrote in message . .. Kevin Brooks wrote: "Guy Alcala" wrote in message .. . Sorry for the delayed reply -- it's been a busy week. Kevin Brooks wrote: snip corrosion lead-in You are forgetting the corrosion problems with the E models--corrosion tends to reduce fatigue life, too, IIRC from my long-ago materials science classes... Corrosion is an issue with any a/c -- certainly the KC-135Rs as well, which (after all) were 135As before, just as the Es were. It sounds to me like the only way you are going to get that long a life from the E's would be if you also replaced some structural components (meaning you are going even further than the old R model mods, IIRC). Why is corrosion and fatigue on the Es supposedly so much more serious than the Rs, when they all started out as 135As? I'd assume they are both going to exhibit corrosion problems, but didn't the R's go through a significant IRAN as part of their upgrade? Not that I can find, but that's not definitive. Boeing replaced the lower wing skinsof 746 C/KC-135s, but that seems to have been applied to all models in service. All I can figure is that the old nacelles and struts (from 707s) may be causing the difference, which would go away if they were upgraded to Rs (which get new struts and nacelles as well as engines). The USAF, per those comments from the three-star last year, seems most concerned with the E's. See above, or possibly just because the Es were less effective than the Rs, so sure, say they're falling apart because of corrosion so we can buy new a/c. You've got to come up with some justification. No, I don't have to. A serving USAF LTG made the statements quoted to you--the best you have offered in response is that the DSB says they can control the problem--if enough money is committed to maintenance on a yearly basis. Duh. Doesn't it sound a bit odd to hear a response that says, "It is not a problem--if we dump enough money into it annually throughout the remaining service life..."? That sounds like the very definition of a "problem" to me. snip Wait a second--spend *more* money on trying to upgrade E's, while doing *another* study to determine if/when/how we replace the E's? What do you mean, _trying_ to upgrade the Es? We know perfectly well how to upgrade them -we've got 400+ prototypes in service, after all, with the R&D all paid for. No, no, no--that was not what I meant. My point is that at this point tossing *more* money into the upgrade of the E models seems a bit shortsighted, when that same money (along with the savings accrued from cheaper operating costs) could go towards purchasing new-build airframes. We did not have that option (or the money to make it happen) available back when the original R program started--we do now. Actually, we don't have the money at the moment, which is why the whole lease thing was suggested. But look at it another way -- might it make more sense to upgrade some/all Es to Rs at far lower cost than than buying 767s, while we perhaps decide to skip the 767 generation entirely and buy either a 7E7 tanker, or even a BWB one around 2015 or so, if the latter a/c is more suitable in the long term? Considering the difference in cost between upgrading an E to a Pacer Crag R vs. buying new KC-767s, it's going to take a considerable time (a couple of decades, I imagine) for the O&M cost advantage of the latter to overcome purchase cost advantageof the former, assuming that it ever does (at least one source claims that it won't). That sounds like a fine...bureaucratic solution? Even the GAO was saying in the 1990's that the USAF needed to get off its duff and start planning the replacement of the KC-135E fleet. Sure. It didn't say what to replace them with. Nope. The USAF has said what they want to replace them with--you have no trust in the USAF? The USAF said what it wanted to replace them with in 2001, when they had no other US choice, and still haven't justified the _need_ to replace them now, vs. other options. The assumptions have changed, as has the situation. Studies are great--unfortunately, they have a tendancy of becoming an ends-unto-themselves. We have a good proposal that the USAF has supported--it puts new airframes into the mission much more quickly than if we follow the "usual" method of purchasing new aircraft (of course, you could use the F/A-22 or F-35 model...which would mean if we started that new study right now, we might plan on seeing some new tankers around what...2015 at best?), and it takes advantage of an existing excess production capability/inventory at the only US company currently building aircraft of that class--sounds like a good plan to me. Who says we need new airframes _right_ now? As we both agree, buying more pods and converting more Rs to carry them is the best solution in the short term to the navy/Allies problem, while converting Es to Rs _may_ be the best solution for increasing our tanker force in a hurry. Or it may not be, butsince the USAF never did an Analysis of Alternatives (AoA), we don't know. Upgrading to R's does not do a great deal towards "increasing our tanker force"--it instead is more of a "spend some money now to reduce O&M costs in the long run, and keep the force from being *reduced* as E models break". Of course, the 767 option does ptretty much the same thing--albeit with an even greater reduction in operating costs, and a significantly better possibility of future upgrades (at what point does it become impractical to keep trying to modernize a 43 year old airframe?). You'd better ask Bufdrvr (or the Air Force) about that one;-) However, I disagree with your premise - upgrading Es to Rs does indeed increase our tanker force, both by improving MC rates, and by increasing offload and reducing runway length requirements, just as the KC-767 would. The E is restricted by lack of thrust in the amount of fuel it can lift off many runways, compared to the R or a 767 (Boeing claims the 767 can lift the same fuel load from a 4,000 foot shorter runway). The A model was even worse, of course, being essentially useless during DS from most runways in the middle east. Hot and/or high has become pretty typical for us, so tankers that have trouble operating from such fields are essentially operationally useless (which is what the USAF general claiming that we needed the 767 to replace the Es said). snip The corrosion problem is apparently under control. See the URL above. From what I recall of the GAO report, the O&M costs for the Es was averaging $4.6 million a year vs. $3.7 million for the Rs That is an additional $130 million bucks each *year* in operating cost (not exactly chump-change...but even that is a "lowball" figure...). What would be the operating cost of the 767? Less than the 135R (two engines versus four, better fuel economy, more maintenance friendly subsystems, less likelihood of inspection-and-repair work, more stringent (and more frequent) inspections, etc.), that is for sure. So your operating cost per year differential measured against the 767 is going to be greater. Add in the cost of bringing those E's to a full PACER CRAIG R model level, and the cost is going to be significant, to say the least. Not a wise investment plan, IMO. If you managed your personal auto program in this manner, then you would still be driving (only--no newer cars allowed) a 1960's era car, and one which you had paid to drop new engines in, along with paying to modify the emissions system to keep it in compliance (like the noise requirements the KC-135's face), and here in 2004 you would be saying that instead of buying a new vehicle, you'd be better off paying to essentially completely rebuild the one you have and drop *another* new engine in it, along with updating the other systems in the dash, maybe a new trannie to be compatible with that new engine, etc. I don't think you would endorse such a plan (I made the mistake once of trying to extend the life of a noble little Nissan pick-up at the 170K point by dropping a *used* engine in it, and that was *not* cheap--and I found that within 10K more miles I was *had* to break down and buy a new vehicle). If most people maintained their cars the way that the military does its tankers, and only drove them 1/10th as much as the average 'driver', then upgading themwith new componenets might well be the most cost effective solution for the long-term. The numbers I have seen quoted for the E to R (plus Pacer Crag) conversion vs. new 767 comparison imply that the conversion is indeed the most cost-effective option, but without knowing every assumption made I'll withhold judgement. I don't buy that. My personal experience was in the more mundane area of military trucks (we used various models in the combat engineer units). As a company commander (late eighties/early nineties) I had dump trucks in my unit that were manufactured in the late sixties and had pretty low mileage. Somewhat like the KC-135 fleet, but a bit younger. Guess what? We still had problems resulting from *age* (sometimes less use is not a *good* thing for mechanical equipment, especially anything that has hydraulics), and we soon (not long after I gave up command) faced a "train wreck" in terms of supportability (the Army found it uneconomical to continue carrying the spare parts inventory for the oldest trucks)--with no replacements immediately available. Not unlike the situation facing the KC-135, IMO. If the military services managed equipment like civilian entities do ( run it to the point of best return in terms of depreciation, then unload it and buy new equipment), the KC-135 would have been gone long ago, before corrosion (among other factors) ever became a serious concern. I agree that too little use can sometimes be almost as bad as too much. By that logic, then, you're recommending that the Air Force have fewer tankers but fly them more, so let's just stick with the Rs we have and fly them till their wings fall off, then buy all new in 15 years or so. By that point the procurement bow wave of the F-22 and F-35 should have died down freeing up some money, and who knows, we may not even need conventional tankers by then. That would be one extreme, IMO--the other being what we are doing, in acting as if the KC-135 (or the B-52, for that matter) will be able to fly forever. No doubt they'd be chasing the DC-3s that are still in commercial service ;-) We stretched the KC's by doing the R conversion a few years back, when there was no option to buy new airframes. Now there is an alternative to our continuing to slap hundred-mile-an-hour tape on old equipment in hopes of keeping it viable forever, and "carpe diem" would be an advisable course of action IMO. Again, at what point do you stop tossing money into trying to keep the E models viable, and instead commit that money to recapitalizing the fleet? I agree that the Es aren't particularly viable per se, but for operational not cost reasons, so let's make them Rs and see what we want to _buy_ (if that makes the most sense) when we can afford to. snip The most critical KC-135 tanker metric is age, and the most pressing KC-135 problems are corrosion and stress corrosion cracking-both age related. Stress corrosion cracking is one of the most difficult structural failures to predict." Are you saying that all of these problems have been solved since that date? Apparently they've been ameliorated to a considerable extent, so that this is no longer a driving factor. And again, why is the E's corrosion problem supposedly so much worse than the Rs, when they started from exactly the same airframe? Again, age and , I suspect, a pretty extensive (and comparitively costly) IRAN process during the upgrade. Can we conquer the corrosion process in the E model? No doubt we can--but would it be worth the cost of doing so for a 43 (or more) year old airframe? If it's worth it for the 42 year-old Rs, then it's worth it for the 43 year old Es, at least if we make them Rs. I don't hear the USAF complaining about the Rs, so the corrosion issues would seem to be due to the different engines plus the slight difference due to age. snip old ground One of the things I object to is the assumption, without any analysis, that the 767 buy is essential (the DSB says it isn't), Well, the DSB also says the corrosion problem is something we can easily discount, Actually, I believe what they said was that the facility responsible for dealing with it has learned to handle it so well that they are able to do the work much quicker and cheaper than expected. I can't find the quote, unfortunately, but I'm still looking. Hopefully this corrosion revelation came after the LTG quoted above gave his testimony--a quick google on the subject did not give me any hits on sites that indicate the corrosion problems are licked. The DSB only began their study in February of this year, so yeah, their data is recent. I'll keep trying to find the quote, or else hopefully the actual report will get put up soon. and has apparently decided that *outsourcing* the tanker mission, or buying second-hand aircraft, is the way to go. Outsourcing may be great for the RAF, etc., but the USAF is another story, IMO. Then there is the "spend the money on already used aircraft" approach--wonderful! As if tossing more money down the O&M pit for the E model is not enough, we should take the money we have and buy older airframes than we can afford? (And yes, we can afford new tankers under the current deal being offered) They've said that it _may_ be the way to go, and: "The report by the Defense Science Board says that, contrary to Air Force claims, corrosion of the aging tanker fleet is "manageable" and several options exist to refurbish the fleet. Manageable at what cost?! Ask the DSB members how many of them are driving even twenty year old cars that they find economical to periodically strip, inspect, repaint, and replace corroded parts as necessary--I'll bet it won't be many, if any. That they are proposing outsourcing the tanker role seems to me to be unrealistic for the USAF, and is indicative of a study probably done by "experts"--not the flying kind, or the kind that even manage the fliers, but the other kind (what we used to sarcastically define as, "an expert is an SOB from out of town with a briefcase". Again, at what point do you think it is unwise to keep dumping money down the tube in an effort to keep the 135E viable, versus using that same money to help purchase new airframes with lower operating costs and greater potential for future upgrade? When its no longer the most cost-effective option which achieves the operational goals, just like any such choice should be made. I've owned four cars in my life, a '65 Chevy Impala bought new by my Dad, and still running great on the original engine 23 years later with 240,000 miles on it when I sold it, as no longer meeting my 'operational' needs; a '69 Datsun 2000 roadster which I bought used in '78 and drove for several years because it was fun, but not worth the money (by me) to fix up; an '88 Subaru 4Wd wagon bought new (which replaced the Chevy), which lasted me for 14 years and which I'd still be happily driving now if it hadn't been stolen, and my current car (another Subaru), which I'll drive until it no longer meets my needs or becomes so unreliable to operate that its more trouble than it's worth, and there's something new that's so much better that it's worth laying out the money upfront. In short, I expect to get 20 or more years out of a car. Now, I drive far less than the average driver, and most of the miles I put on are easy ones on the interstate rather than stop and go commuting (kind of like the Air Force's tankers), so such lifespans can be expected. If officials are willing to tolerate increased maintenance costs, "you can defer major near-term . . . investments" to replace the tanker fleet, the report said. Guy, that is a telling statement. I suspect the USAF folks are as afraid of that statement as I would have been when I was on the green suit side--because they know that when the money does get short, the first thing that usually ends up getting cut (or really stre-e-e-e-tched) is usually the O&M money. Those "increased maintenance costs" (for an aircraft that is already the most expensive in its class, the E model?) represent an increased chunk of a finite pool of O&M money. Not to sound like a broken record, but at what point is enough enough, where you start using that money to instead buy into newer, less costly (to operate and maintain) airframes? See above, and after you've done a proper Analysis of Alternatives to see just what the most cost-effective solution is, which is what the DSB says we have time for. They're not saying you can go on forever, they're saying we don't have to rush out and buy a new 'car' tomorrow; we've got the time to study Consumer Reports as well as Car and Driver, go to Edmunds.com, take some test drives, figure out what our needs really are (as opposed to what we'd like to have), look at several different ways we might meet them, and then see which is the cheapest. Works for me. "There is no compelling material or financial reason to initiate a replacement program prior to the completion of" a lengthy analysis of alternatives and other studies, the report said. " Hooray! "There is no compelling material or financial reason (of course, you'll have to foget about that whole "increased maintenance costs" part of what we just said), Oh come now, Kevin. Putting an extra $500 into my old car every year to keep it running while I spend more time deciding whether it makes more sense for me to buy a $25,000 dollar car next year, or wait another year or two so I can decide if the really neat $30,000 hybrid gas/electric SUV that will be available then is a better fit for my long terms needs, is not "forgetting about that whole 'increased maintenance costs' part of what we just said." We all have to make such decisions all the time, at least those of us whose last name isn't Gates (and I bet he makes them too). so like the bureaucrats we be, let's study it...and study it...and analyze what we studied, and then study it some more... For at most, 18 months, and it seems more likely, to the end of this year, a study that we should have done back in 2001 but didn't. while you guys keep paying out those "increased maintenance costs" you should be oh-so-happy to "tolerate", not to mentioon having bitten the bullet and sunk the requisite funds into belatedly upgrading the E models to R as (if?) you secure the funding to do so..."? See above. If you can come up with $2 billion a year for the 767 lease, you can sure as hell come up with only $130 million a year instead (compared to the KC-135R costs) for the Es extra O&M, even if you decide to leave them completely unmodified. snip The biggest things you have to buy spares for are the avionics (which are more plug-and-play than they were in the 135 era), and engine related systems. There are a lot of 767's that will remain in service in the civilian sector for decades to come--they will need spares too, and in the end they become another source for spares for the KC version. I don't see this as a deal-breaker. Given that airlines are already looking to replace their 767s ( a 20-year old design, let's remember) with the next generation, and given that world oil production is predicted to peak sometime in the 2007 (the pessimists) -- 2040 (the optimists) period, considerably improved fuel consumption may well drive the mass replacement of older a/c, just as the post 9/11 slump did. It's definitely an issue. But you find the improved fuel consumption of the 767 versus the R models, and especially the E models, to be a non-issue? I'm not sure that the 767 has a fuel consumption advantage over a 135R across the spectrum of tanker roles (it has a small offload advantage owing to higher gross weight), but of course it's an issue, one to be properly analysed to see just _how much_ of an issue it is, or is likely to become. In other words, let's do this using our brains rather than just going on gut feeling. snip Which is better suited for the role? Is the extra M0.05 in cruise a major advantage? Not likely. Depends on the specific mission, and more importantly, what percentage of the mission spectrum does that particular mission occupy. There are missions now where the faster KC-135 is better suited than a KC-767 would be, and others where the latter comes out ahead. Sorry, but I can't buy that the extra five one-hundredths mach is going to be an issue either way. Certainly can be, depending on how fast your fighters have their best cruise at, at what altitude, and what their best tanking speed is. M0.05 works out to about 30 knots true at typical tanker altitudes (25-35,000 feet). If that higher cruise speed allows the fighters to tank significantly higher or faster, i.e. without having to drop down out of their best cruise envelope or at speeds that put them on the back side of the drag curve, I think you'll agree that will give a significant decrease in fuel offload required, improve range, decrease transit time, or what have you. For deployment tanking or when transiting to/from distant tanker tracks, higher speed gives you better utilization because you get more trips per unit time. In emergencies, a tanker getting there a minute or two earlier may well be the difference between saving or losing an a/c (at say $40 million each, that could buy a lot of fuel). And there are obviously missions where it makes no difference whatsoever, or where the slower speed may be preferable -- time spent loitering on tanker orbits probably being one such, and the likely better takeoff and landing performance being another. So let's look at the tradeoffs. Does the higher composite content significantly decrease the corrosion issues down the road? Maybe, but doubtfull, as corrosion awareness was better incorporated into the 767 manufacture than it was in the 135. And will be even more incorporated into the 7E7, especally since (AFAIK) there is no corrosion of composites yet known. But you have been claiming that corrosion is not a problem withthe 135 any longer--now you want to use corrosion as a deciding point between the 767 and an aircraft that has yet to even fly, much less become available in a tanker form? Kevin, when did I ever say that corrosion is not a problem? I said that the DSB said it's currently manageable, and not a major driving issue _now_. At no point did I ever say or imply that it would _never_ be an issue. Of course you want to consider how it might affect life-cycle costs and utility, for the 767 and 7E7 just as much as with the 135. My '88 Subaru had a bit of rust on the drivers side A-pillar; it wasn't a major issue at the time, but it might have become one at some point, which would have factored into my decision as to when to replace it. How about the 20% better fuel efficiency? Sounds good, but then again you have to examine the interval between the time the 767 would be available and the (elsewhere not mentioned, AFAIK) 7E7 tanker version (expect what, a five or six year period at best before the first tanker 7E7 could be available?)...I'll be kind and use a five year period, at 131 E models costing maybe $2 million each more per year in operating costs than the 767, that works out to around $1.3 billion in extra operating costs? That is a hell of a lot of gas... Check out how much the KC-767 tankers cost. You were talking gas, right? I was talking total cost, purchase/lease plus O&M for comparable capability. OK, lets be more realistic and say that if we canned the 767 proposal and started from scratch, we'd likely not see a new tanker enter the inventory until 2011 or so. That would be six years to the *start* of replacing the E models. Of course, that pretty much forces you into converting those to R's--GAO estimates the cost for that to be some $3.6 billion. No, it doesn't, although it might be the best choice to do so. Remember, currently, the KC-135E fleet costs ca. $131 million (your figure) per year more than a comparable number of 135Rs to operate. So, multiplying $131 million x 7 (to get us from here to 2011) is only an extra $917 million, vs. the $3.6 billion for the conversion, minus the incremental savings from the improved operating costs ca. $1 million per conversion/yr. For the sake of argument, let's assume that the average number of conversions available is half the fleet over that period, so the conversions save an average of $65 million per year on O&M, or $455 million over the whole 7 year period. So the total net cost looks like $917 million (keep the unmodified Es) vs. $3.15 billion (upgrade them all to Rs and reap the O&M savings), to the start of replacement date. For the sake of argument, let's assume that the E vs. R O&M disadvantage doubles for that period, which still only costs us $1.834 billion vs. $3.15 billion. In 2011, we start discarding them and replacing them with whichever a/c we decide to replace them with, having saved ourselves somewhere between $1 - $2 billion in the meantime. In this simplified calc I haven't bothered to take account of the operational advantages of an R over an E, which would of course need to be factored in, but it does show that under certain conditions keeping the Es as they are while waiting to buy a tanker better suited to our long-term needs, may be the preferred solution. If we work *really fast* to do that, we can maybe get it done over about a four year period, so for the last two years of that period up to 2011 we can use the cheaper O&M cost of the R model ($3.7 million per year per aircraft) which is (we'll assume, based upon KC-10 operating costs, which would likely be a bit more than the 767) maybe $1.5 mil per year greater than the 767 cost. Two years times 131 aircraft times $1.5 mil is about $400 mil. Of course, we have that earlier period (four years)when the E's (or the ever decreasing number remaining of them as they undergo upgrade to R) are still flying as is, and that would add maybe another $600 mil. Say a billion bucks total versus the operating cost of the 767's (yeah, I know we would not get all of the 767's delivered in lump sum, but I am trying to keep this simple and fair as well, so I am not going to figure the post-2011 additional operating cost of the 135R's versus 767 into the mix to try and keep things even). That is a total of $4.6 billion you have just dumped into keeping the 135E's flying just until 2011. Er, no. As I understand it, you've converted them to Rs and kept them flying until then. At $200 mil per 767, that is the equivalent of some 23 new 767's right there--over half of what the USAF is asking for in the first lot. If you go the lease route with the first forty tankers, you could cover a significant part of the overall lease cost with that money. And you are getting an aircraft that carries more fuel to boot. Or you could take the $1 to $2 billion you saved by keeping the Es unmodified and just start buying 767s (or what have you) outright, also saving yourself the interest on the lease. We're talking about paying $2 billion per year on the lease, which would buy 10 767s each and every year. As it was Boeing claimed the lease was only going to allow us to start replacing 135Es about 3 years earlier than otherwise. In short, I think the lease stinks, as we don't _need_ the new a/c right away (whatever type), so leasing instead of buying makes no sense, especially as were going to keep the a/c for so long. Respective runway and ramp space requirements? PFI vs. military? Etc. Lose the outsourcing option from the get-go, IMO. Won't work for an organization with the scope of tanking requirements that the USAF has. Perhaps yes, perhaps no. Air bridge and training tanking doesn't require military crewing. It's certainly an option worth looking at for at least some tanking requirements, if not all. I am not crazy about the idea of having a portion of the tanker force unavailable for use in the T/O (and no, this is not the same as my below posit regarding using the 767's for these roles--those 767's could just as well extend to the T/O where they provide full capacity tanking to USAF assets, even with their (initially) marginal USN tanking support capability). We have a portion of the tanker force that is unavailable for use in the T/O now, according to an AF general -- the 135Es. There will always be tankers that are involved with routine duties outside the T/O. snip Yes, they do, but the question remains, are 767s rather than upgraded Es and later 7E7s the best way to go; what's the best mix, what % of tankers need to do which roles, how will the advent of UCAVs affect the need for tankers and the type mix, what effect will USAF F-35 buys have, etc. This needs to be properly studied. Again with the neverending studies? :-) What never-ending study? The USAF failed to do such a study in the first place, especially an AoA. The latter was predicted to take about 18 months, but the head of AQ&L (Wynne) says they'll probably push it and complete it by December or so. I was referring to your DSB folks..."studies" was the term they used. As in "more than one". Because there are several still underway as we speak, looking at various issues, most of them ordered by the SecDef. The AoA is one of them, and almost certainly the most important. snip I'm aware that the R&D will still apply, I'm worried about the materiel costs, which are only going to go up. If we need the capability, then let's just buy it and get the purchase out of the way, instead of paying inflated prices later. Even if it delays entry further, meaning you are also going to be paying that higher O&M cost for the remaining E's even longer...? If that allows us to make a better decision for the long term, sure. We can get upgraded Es (Pacer Crag Rs) into service faster than we can get 767s. And pay some $3.6 billion for the privaledge of then having the longest serving remaining KC-135's committed to an even longer period of service. So? The Rs are only a year younger on average, and yet no one's raising a big fuss about them hanging around until 2040. So we convert the Es, and maybe start retiring them a few years earlier. IMO, not a wise course of action--only to be used if the 767 deal gets trashed due to both Boeing's stupid handling of what should have been a done deal by now and the involvement of politicos-with-axes-to-grind, like McCain. Just which axe is McCain grinding, other than the one (widely shared) that the lease makes no fiscal sense, and is essentially driven by the wish to give Boeing a bailout? IMO, if that is the way it plays out, we will see the conversion to R's, then a mindset of, "What? You want a *new* tanker, after we just sank all of that money into upgrading those last E models? Maybe next year we might authorize a *study*..." set in, leaving the USAF in the lurch with an open-ended KC-135 tanker force, and the BUFF's being replaced before they are. If that winds up with us having equal or greater capability at equal or lesser price, I'm all for it. Given the choice between multipoint-capable Rs now and single point 767s (or whatever) later, I'd take the Rs, unless the economics are are shown to go the other way. So far, I've seen no evidence that they do, which is why I want to see an AoA done. snip I am not as impressed with the summary of the DSB report as you are (but then again, I tend to weigh the advice of the folks actually tasked to fly the missions a bit more than I do the DSB, GAO, etc). Seeing as how the DSB works for the Pentagon, and Rumsfeld is the guy who tasked them to do the study back in February, I put a bit more weight on their advice than you do. Especially since opponents of the 767 deal (McCain to thefront) believed that the DSB was much too cosy with the military and Boeing (the DSB Chairman had to recuse himself because he was also a paid Boeing consultant and had been mentioned in internal company e-mails back in Dec.2002/Jan. 2003 as willing to help push the deal), and fully expected them to support it. I believe McCain's words were something along the lines of a "fox guarding the chickens." So yeah, when even they come out and say they that we've got time to do the study and the corrosion is manageable, I'm inclined to believe them. Then we will have to agree to disagree on this point. Fair enough. snip In the long run, yes. But is it worth slowing delivery up-front even further than it already has been slowed? According to the DSB, we have the time. The DSB that claims, contrary to what the USAF LTG testified last year, that the corrosion problem is readily in-hand...? the DSB's claim is based on the USAF unit doing the corrosion controls data, let's remember. The situation isn't static, and they've gotten better at it since last year. You left out that whole "tolerate higher maintenance cost" part of the DSB's corrosion solution--I don't think that is a "minor" part of the equation here, though the DSB apparently does given the off-hand way they worded that statement. See my reply to you where you made much the same point, above. And thinks out-sourcing tanker requirements is a fine idea? They're saying it's a viable option, it should be looked at in an AoA, and we've got the time to do so. No more, no less. If you "tolerate higher maintenance costs" you have that time. Yes, and lower acquisition costs. I am not buying into either, at this point. Until the AoA is actually done, we have nothing to base a decision on other than "because I think so," which IMO is a pretty poor way to spend billions of dollars. DSB did not say they *thought* keeping the E models would be more expensive than what we are already paying--they said we would have to tolerate higher maintenance costs, period, while the "studies" (plural) take place. And the questions we need to answer are whether that is cheaper than leasing 767s, buying them outright, buying something else down the road, converting Es to Rs, or what have you. Makes sense to me - it may cost us a bit more right now, but may save us a bundle down the road. Exactly the opposite applies with leasing rather than buying 767s. snip I remain unconvinced that AMC would throw a hissy fit if the USN wanted to include a secondary tanking capability to its C-40B's. More likely, they'd suffer a rupture from laughing at the USN devoting such a large proportion of its budget to paying the NRE for so few a/c of such limited performance (as tankers). Then the critical USN "requirement" that led off this thread...must be more of a "desire" than it is a "requirement". No, it just means that you spend your money wisely, and buying a few "KC-40s" of limited performance and very high cost is anything but that. Personally, I doubt the USAF would have put up a fight if the USN had said they wanted to incorporate a secondary refueling capability in their C-40B's; just as the USN has been strangely silent over the USAF talking about recreating an in-house stand-off jamming capability. There is no way in hell that the USN would pay the R&D NRE for a tanker mod for their C-40s, with all their other needs. Exactly. So the lack of multi-point refuelers must not be such a critical one, eh? Since no one else is even considering buying 737s as tankers, and the navy is only buying a few (somewhere between 5 and 8, as best I can tell), the navy would have to be nuts to make that kind of investment for so few a/c, even assuming that they would be reasonable tankers. Given their limited payload/range and performance, I have my doubts they would be, but it's moot. They (C-40A--I goofed with the "B", which is one of the USAF models) are replacing the C-9 in the USN; from what I gather, the plan is to replace 27 C-9's, and I doubt that 8 C-40's can do that. I read where one of the military lobbying groups noted that the CNO wants to procure three per year (unspecified total delivery). I've been unable to find a definitive total number either. 5-8 I'm pretty sure of, but beyond that everything seems tenuous. Kind of like how many tankers the USAF needs, of what type, and when;-) I am not sure the 737 would make a superior tanker, either--my point was more in the line of, "If the USN is *really* worried about tanking capability for its aircraft, why have they not moved to increase their own in-house capability beyond buddy tanking and C-130's, especially when they have recently begun procuring a new dedicated land based logistics support aircraft?" In other words, this a BIG priority for them--as long as somebody else is footing the bill, that is. Otherwise, the priority seems to be somwhere down in the weeds... The only way to settle this is to wait and see how the USAF reacts if, after selecting whatever new tanker they pick, the USN says "hey, we want some of those for ourselves, and here's the money." Myabe the USAF will say "you're welcome, and thanks so much for helping out with the R&D." Or maybe they'll get all territorial; it's not as if turf wars are dead just because we've been fighting real ones. Guy |
![]() "Kevin Brooks" wrote in message ... "Guy Alcala" wrote in message . .. Kevin Brooks wrote: "Guy Alcala" wrote in message . .. Kevin Brooks wrote: "Guy Alcala" wrote in message .. . Sorry for the delayed reply -- it's been a busy week. Kevin Brooks wrote: snip corrosion lead-in You are forgetting the corrosion problems with the E models--corrosion tends to reduce fatigue life, too, IIRC from my long-ago materials science classes... Corrosion is an issue with any a/c -- certainly the KC-135Rs as well, which (after all) were 135As before, just as the Es were. It sounds to me like the only way you are going to get that long a life from the E's would be if you also replaced some structural components (meaning you are going even further than the old R model mods, IIRC). Why is corrosion and fatigue on the Es supposedly so much more serious than the Rs, when they all started out as 135As? I'd assume they are both going to exhibit corrosion problems, but didn't the R's go through a significant IRAN as part of their upgrade? Not that I can find, but that's not definitive. Boeing replaced the lower wing skinsof 746 C/KC-135s, but that seems to have been applied to all models in service. All I can figure is that the old nacelles and struts (from 707s) may be causing the difference, which would go away if they were upgraded to Rs (which get new struts and nacelles as well as engines). The USAF, per those comments from the three-star last year, seems most concerned with the E's. See above, or possibly just because the Es were less effective than the Rs, so sure, say they're falling apart because of corrosion so we can buy new a/c. You've got to come up with some justification. No, I don't have to. A serving USAF LTG made the statements quoted to you--the best you have offered in response is that the DSB says they can control the problem--if enough money is committed to maintenance on a yearly basis. Duh. Doesn't it sound a bit odd to hear a response that says, "It is not a problem--if we dump enough money into it annually throughout the remaining service life..."? That sounds like the very definition of a "problem" to me. Ooops--late night! Hit the send key a bit early... snip Wait a second--spend *more* money on trying to upgrade E's, while doing *another* study to determine if/when/how we replace the E's? What do you mean, _trying_ to upgrade the Es? We know perfectly well how to upgrade them -we've got 400+ prototypes in service, after all, with the R&D all paid for. No, no, no--that was not what I meant. My point is that at this point tossing *more* money into the upgrade of the E models seems a bit shortsighted, when that same money (along with the savings accrued from cheaper operating costs) could go towards purchasing new-build airframes. We did not have that option (or the money to make it happen) available back when the original R program started--we do now. Actually, we don't have the money at the moment, which is why the whole lease thing was suggested. But look at it another way -- might it make more sense to upgrade some/all Es to Rs at far lower cost than than buying 767s, while we perhaps decide to skip the 767 generation entirely and buy either a 7E7 tanker, or even a BWB one around 2015 or so, if the latter a/c is more suitable in the long term? Considering the difference in cost between upgrading an E to a Pacer Crag R vs. buying new KC-767s, it's going to take a considerable time (a couple of decades, I imagine) for the O&M cost advantage of the latter to overcome purchase cost advantageof the former, assuming that it ever does (at least one source claims that it won't). Pardon me for not inserting "or leasing" after "purchasing". Last I heard, Boeing has gotten very quiet about the whole BWB concept, so I am not sure how much confidence you can put into it. And again, after spending some $3.6 billion to upgrade the remaining E's (which still have that corrosion "problem", albeit one that the DSB contends we can discount--if we are willing to dump enough money into future maintenance...), how sure are you that you will be able to get funding for *another* major tanker program in short order? That sounds like a fine...bureaucratic solution? Even the GAO was saying in the 1990's that the USAF needed to get off its duff and start planning the replacement of the KC-135E fleet. Sure. It didn't say what to replace them with. Nope. The USAF has said what they want to replace them with--you have no trust in the USAF? The USAF said what it wanted to replace them with in 2001, when they had no other US choice, and still haven't justified the _need_ to replace them now, vs. other options. The assumptions have changed, as has the situation. Guy, for gosh sakes--they *still* have no other domestic choice beside the 767! Your 7E7 has not even been *designed* yet, much less is it ready to take to the skies in tanker mode. Studies are great--unfortunately, they have a tendancy of becoming an ends-unto-themselves. We have a good proposal that the USAF has supported--it puts new airframes into the mission much more quickly than if we follow the "usual" method of purchasing new aircraft (of course, you could use the F/A-22 or F-35 model...which would mean if we started that new study right now, we might plan on seeing some new tankers around what...2015 at best?), and it takes advantage of an existing excess production capability/inventory at the only US company currently building aircraft of that class--sounds like a good plan to me. Who says we need new airframes _right_ now? As we both agree, buying more pods and converting more Rs to carry them is the best solution in the short term to the navy/Allies problem, while converting Es to Rs _may_ be the best solution for increasing our tanker force in a hurry. Or it may not be, butsince the USAF never did an Analysis of Alternatives (AoA), we don't know. Upgrading to R's does not do a great deal towards "increasing our tanker force"--it instead is more of a "spend some money now to reduce O&M costs in the long run, and keep the force from being *reduced* as E models break". Of course, the 767 option does ptretty much the same thing--albeit with an even greater reduction in operating costs, and a significantly better possibility of future upgrades (at what point does it become impractical to keep trying to modernize a 43 year old airframe?). You'd better ask Bufdrvr (or the Air Force) about that one;-) However, I disagree with your premise - upgrading Es to Rs does indeed increase our tanker force, both by improving MC rates, and by increasing offload and reducing runway length requirements, just as the KC-767 would. The E is restricted by lack of thrust in the amount of fuel it can lift off many runways, compared to the R or a 767 (Boeing claims the 767 can lift the same fuel load from a 4,000 foot shorter runway). The A model was even worse, of course, being essentially useless during DS from most runways in the middle east. Hot and/or high has become pretty typical for us, so tankers that have trouble operating from such fields are essentially operationally useless (which is what the USAF general claiming that we needed the 767 to replace the Es said). OK, you win. I vote we keep the KC-135 flying for another forty years--when the wings start shedding from them in flight, maybe we can discuss replacing them? Of course, you will guarantee that the ever increasing O&M costs, to include that extra money required to solve that "non-problem" corrosion situation, will be forthcoming every year, and that we can continue to upgrade them as required throughout that period... Nah, just kidding. This has been interesting, and informative; I hate to admit it ( :-) ), but I have learned a few things in this thread--though nothing that convinces me that either (a) we should not continue with procurement of the 767 tanker, or (b) there is something critically wrong with procuring the first 40 767's without multi-point capability up-front. And BTW--I don't find the assertion that we could keep the E's flying "as is" very convincing--ISTR there are real concerns over the availability of engines and related parts for the existing powerplants, so if you wanna go the "keep the E's" route you are realistically going to *have* to upgrade them. Thanks for the info, and I appreciate the discourse. Brooks snip what has become one of our more long-winded discussions |
Kevin Brooks wrote:
snip This has been interesting, and informative; I hate to admit it ( :-) ), but I have learned a few things in this thread--though nothing that convinces me that either (a) we should not continue with procurement of the 767 tanker, or (b) there is something critically wrong with procuring the first 40 767's without multi-point capability up-front. And BTW--I don't find the assertion that we could keep the E's flying "as is" very convincing--ISTR there are real concerns over the availability of engines and related parts for the existing powerplants, so if you wanna go the "keep the E's" route you are realistically going to *have* to upgrade them. Thanks for the info, and I appreciate the discourse. Kevin, since were both tired of arguing the same points while lacking the data, here's a Congressional Research Service report from last September which presents both sides' arguments, as well as showing the costs and what assumptions went in to them, plus the effect on costs if any of those assumptions change. See: www.fas.org/man/crs/RL32056.pdf Of interest, my WAG that the engine struts (pylons) on the Es might be the main (extra) corrosion driver compared to the Rs was correct. I get lucky once in a while. Also, the report mentioned that the navy was already contracting out training and coast-to-coast tanking services, which I was unaware of. I haven't yet found out who they're contracting with or what kind of a/c they're using. Guy |
Guy Alcala wrote:
snip Also, the report mentioned that the navy was already contracting out training and coast-to-coast tanking services, which I was unaware of. I haven't yet found out who they're contracting with or what kind of a/c they're using. Found it. They're contracting with an Irish company called Omega Air, which provides used 707-320s (they' got one or two in service so far) equipped with a pair of centerline Sargent-Fletcher (apparently now owned by Cobham PLC, formerly Flight-Refueling Ltd.) FR300 drogues. Omega has also apparently bought a fleet of used DC-10s, and plans to convert some of them into tankers in the future. At the moment, they're concentrating on hose-drogue refueling, both because the conversion is easier and ceaper, and because most air forces use it. the following is a quote from a 2001 AvLeak article: "Following retirement of its Grumman KA-6D and Lockheed KS-3A tankers, the U.S. Navy is exploring PFI operations through a recent $6.6 million air refueling contract with Flight International, Inc. and Omega Air. This involves 600 hours of tanker, EW training and other U.S. Navy support missions by Omega's dual probe-and-drogue equipped Boeing 707-320 through October this year, with renewal options up to 2005. These, and the USAF's massive KC-X requirement, are also hungrily earmarked for early pursuit by the FTSA contenders, who have also briefed 10 or more other countries on their proposals." This article apparently dates from 2000 so is a bit out of date, but it provides some useful info: http://www.nawcad.navy.mil/view_rele...m?article_id=8 Guy |
![]() "Guy Alcala" wrote in message .. . Kevin Brooks wrote: snip This has been interesting, and informative; I hate to admit it ( :-) ), but I have learned a few things in this thread--though nothing that convinces me that either (a) we should not continue with procurement of the 767 tanker, or (b) there is something critically wrong with procuring the first 40 767's without multi-point capability up-front. And BTW--I don't find the assertion that we could keep the E's flying "as is" very convincing--ISTR there are real concerns over the availability of engines and related parts for the existing powerplants, so if you wanna go the "keep the E's" route you are realistically going to *have* to upgrade them. Thanks for the info, and I appreciate the discourse. Kevin, since were both tired of arguing the same points while lacking the data, here's a Congressional Research Service report from last September which presents both sides' arguments, as well as showing the costs and what assumptions went in to them, plus the effect on costs if any of those assumptions change. See: www.fas.org/man/crs/RL32056.pdf Of interest, my WAG that the engine struts (pylons) on the Es might be the main (extra) corrosion driver compared to the Rs was correct. I get lucky once in a while. Also, the report mentioned that the navy was already contracting out training and coast-to-coast tanking services, which I was unaware of. I haven't yet found out who they're contracting with or what kind of a/c they're using. I believe that would have been Omega Air, using a single 707 tanker; there was some info about it floating around in some of the pubs at the time, reporting its participation in an exercise or two. Brooks Guy |
I am not crazy about the idea of having a portion of the tanker force unavailable for use in the T/O (and no, this is not the same as my below posit regarding using the 767's for these roles--those 767's could just as well extend to the T/O where they provide full capacity tanking to USAF assets, even with their (initially) marginal USN tanking support capability). This is presupposing the 767s will not be made prematurely obsolete by the emerging long range AAM and SAM threats. A Feb AvWeek article reported USAF interest in stealthy tanker designs...even equipped with stealthy booms. Sounds like somebody in the AF is as crazy as me... (Feb23 AvWeek) "Moreover, U.S. Air Force representatives have indicated interest in a stealthy tanker to support their stealthy attack platforms, the F/A-22, F-35 and B-2, to make them less susceptible to attack while they refuel. To adequately satisfy that demand, Lockheed Martin has devised a stealth shrouding for the refueling "boom." The 767 is a poor investment for the future, and a 7E7 variant or the Airbus offerings would merely be more expensive poor investments. |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Highest-Ranking Black Air Force General Credits Success to Hard Work | Otis Willie | Military Aviation | 0 | February 10th 04 11:06 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Air Force announces acquisition management reorganization | Otis Willie | Military Aviation | 0 | August 21st 03 09:16 PM |
