Ventus B, Discus ect aileron connecting rod/slide lube
Old February 3rd 15, 09:38 PM posted to rec.aviation.soaring
BobW
Default Ventus B, Discus ect aileron connecting rod/slide lube
On 2/3/2015 1:30 PM, Don Johnstone wrote:
At 14:15 03 February 2015, Bob Whelan wrote:
Major snip
True in glider design, too. The trick is to know - or at lest to remain
within
- one's limitations.
YMWV
Bob W.
P.S. I believe Dick Johnson was a degreed aeronautical engineer. His
entire
working life was spent in the engineering field, and his extracurricular
soaring-and-sailplane-design-and-testing-related body of work was
prodigious.
He likely passed on from heart failure in his mid-eighties while flying
Ventus he owned for decades - the one in which he drilled lube access
holes.
Make of all that what works for yourself!
Up until today I was firmly of the opinion that EASA and their regulation
was an unnecessary imposition on gliding. I had always believed that no-one
who flew a type certified glider would make structural modifications
without consulting the type certificate holder and obtaining their approval
for a modification, I simply did not believe that anyone could be THAT
irresponsible. I seems I was wrong, which is nothing new. I suppose that
EASA is a necessary evil while there are those who think that such behavior
is acceptable. What worries me most is that these actions are taken by
people who are described as well respected and qualified engineers. It
certainly increases my understanding of the attitude of EASA to FAA
licensed engineers.
I am well aware that in the past such modifications were made to simple
wood and fabric constructed gliders, cutting and patching a hole in fabric
or indeed metal skins is a completely different matter to drilling holes in
a GRP structure, the best that can be said is that such action has not
failed, YET, or maybe not.
To say that a course of action is ok because A.N Other did it and got away
with it is not safe practice, especially when it encourages those without
knowledge to try an "inspired" fix.
If you can produce a note of compliance, a relevant AD or tech note, from
the type certificate holder I will of course take it all back.
Hmmm...should I have also mentioned that - in the U.S. - it was (may still be)
quite common for early-imported, eventually ATC-ed gliders to be initially
licensed in the "Experimental - Exhibition and Racing" category, after which,
should reciprocal LBA/FAA certification eventually occur, the current owner
could choose to either retain the Exp-E&R certificate or switch the ship into
the ATC category? The switch didn't happen automatically. Left for another
discussion is the differing rights and responsibilities legally open to owners
of U.S.-licensed ships in either category...
Left for interested readers is to research Dick Johnson's 1981, S/N 29, Ventus
A's licensing category. (For the Anal Police, complain to the NTSB if you're
unhappy they weren't able to type in the correct verbiage for the ship's
certificate in their Full Narrative Report...all my experimentally licensed
sailplanes had the wording I've used above.)
Again - readers are entitled to draw their own conclusions and hold their
individual opinions. Isn't the concept of individual responsibility wonderful? :-)
Regards,
Bob W.
Old February 3rd 15, 10:58 PM posted to rec.aviation.soaring
licensed engineers.
I'm not so sure what Mr Johnson did would fall into the category of some really bad action as the writer above seems to imply.
The maintenance and repair manuals required as part of instructions for continued airworthiness specify various levels of damage and how they are to be handled. Come small holes commonly can be taped over, at least temporarily. It is quite possible the hole Mr Johnson described falls in that range. As as aero engineer by degree, he certainly would have made the proper judgement.
Sometimes, to get access to inner stuff to keep older gliders flying, a hole may need to be cut. Obviously it should be repaired as appropriate. In truth and composite repair is commonly easier that one in metal.
That said, Joe Winglifter should not just cut holes in stuff obviously.
EASA is an evil that is best avoided at all costs. In my view it has contributed little, if anything to our little part of the universe, yet has added much cost and aggravation to those it affects.
UH
Old February 4th 15, 02:12 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
=20
regulation
no-o=
ne
approv=
al
that
behavi=
or
licensed engineers.
fabri=
c
holes
in
awa=
y
without
from
re=
con=
b=
temporaril=
range.
judg=
ement.
hol=
tr=
contri=
added=
UH =20
You may well be right, Mr Johnson may have had the necessary skills and
knowledge to safely take action, I do not have too much of a problem with
that. What does concern me, and imho should concern all of us, that someone
with the knowledge and experience to make an informed decision may be
acceptable, but there was a suggestion or encouragement for those who do
not have that knowledge or experience to attempt to copy him. That still
does not explain why it should be necessary to apply lubricant to an item
that was designed to have none. Perhaps the best advice would be to consult
the type certificate holder for their opinion, they still make the Ventus
so that should not be a difficult task. As far as I know Schempp Hirth are
not like Friedel Weber at DG and do not charge an exorbitant price for very
little, inter alia blaming it on EASA. If the controls are stiff perhaps a
proper investigation into the cause as against treating the symptoms might
be a more responsible approach.
Old February 4th 15, 03:52 PM posted to rec.aviation.soaring
Dan Marotta
Let's not forget that manufacturers and licensing agencies don't always
get it right. If they did, we wouldn't have so many airworthiness
directives and mandatory service bulletins...
=20
regulation
no-o=
ne
approv=
al
that
behavi=
or
licensed engineers.
fabri=
c
holes
in
awa=
y
without
from
re=
con=
b=
temporaril=
range.
judg=
ement.
hol=
tr=
contri=
added=
UH =20
Dan Marotta
Old February 4th 15, 05:52 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
On 2/4/2015 8:52 AM, Dan Marotta wrote:
Let's not forget that manufacturers and licensing agencies don't always get it
right. If they did, we wouldn't have so many airworthiness directives and
Not to mention - in the U.S., anyway - alternative methods of compliance,
which are FAA-approved alternatives to the original FAA-issued Airworthiness
Directive and which typically come into being when people (read: [typically]
owners, repair shops, users and others with an economic interest in the
aircraft affected) feel sufficiently strongly that they convince the FAA the
original FAA-mandated fix (AD) can be accomplished in an alternative
(typically less draconian/expensive) manner (AMOC).
Ah, perfection; thou art indeed a virtue!
Ah, thread drift...
Bob W.
Old February 3rd 15, 11:45 PM posted to rec.aviation.soaring
Dave Nadler
Um, as one who owned one of these brutes, until it perished
in the great Barstow fire, I also made a hole to lubricate
the drive knuckles. OMG! Great Balls of Fire! The World will END!
Well no, the 3/32" hole is thru the fabric seal,
NOT through GRP structure. The track/follower assembly is
accessed via a factory-provided inspection plate.
Really now...
Discus Aileron Seals Peter F[_2_] Soaring 8 August 20th 13 05:07 PM
left aileron for Discus CS wanted [email protected] Soaring 0 September 28th 12 01:31 AM
New Ventus 2 and Discus Winglets - M&H Alpha Eight Soaring 11 February 21st 12 04:41 PM
Looking for Left Outer Aileron for Ventus C Bob Gibbons[_2_] Soaring 0 June 30th 09 02:12 AM
Ventus 1 - anyone have experience w/o aileron centering spring? Gary Emerson Soaring 0 November 1st 08 02:36 PM
