Silver Badge questions
Old February 22nd 15, 12:37 AM posted to rec.aviation.soaring
Default Silver Badge questions
On Saturday, February 21, 2015 at 4:21:35 PM UTC-8, Bob Pasker wrote:
but there is a table titled "Flight Recorder FR300 Quick list of certificates" that does now show that the device can be used for SSA Silver and Gold badges, although this is contradicted in the text.
It is pretty much impossible to find the position recorder approval documents on the SSA web site (someone may want to consider fixing that), it is much easier to find on the FAI web site:
http://www.fai.org/component/phocado...proval-ssa-v3a
Marc
Old February 22nd 15, 12:31 AM posted to rec.aviation.soaring
Cookie
Observer: Just ask around! Any SSA member should be qualified, and willing. You do all the "grunt" work and get the forms and fill them out properly...so the observer needs only to "supervise" and sign. Don't become a "pest"
Flight recorder:
1) Just ask! Somebody will probably have something they can lend you.
2)Or... Most pilots join some sort of glider club. Most clubs have such equipment available to members..
3)Some commercial glider operators offer "rental" of flight recorders for a "small fee"
4)If you wish to use a simple old fashioned mechanical baragraph, I bet somebody would give you one for the asking....Back in the day, they were in the range of $400 and up! Nowadays they are used for Christmas tree decorations, door stops, and to start nostalgic conversations. No actual monetary value....My club has 6 of 'em sitting in the closet in the equipment shed!
5) Consider buying your own equipment....this is something you may find useful for years to come. Some used ones come up now and then...The "fly with CE" is a good deal...maybe colibri II....etc?
Cookie
On Saturday, February 21, 2015 at 5:53:54 PM UTC-5, Bob Pasker wrote:
I would like to attempt the duration and altitude silver badge.
how do I go about finding an observer willing to work with me?
how do I borrow/rent an appropriate flight data recorder?
thanks, bob
Old February 22nd 15, 12:44 AM posted to rec.aviation.soaring
Dan Marotta
IIRC, unless something has changed, not just any SSA member is qualified
as an observer. I believe the observer has to at least hold a badge
leg. Airport managers also qualify and, perhaps, an FBO. Just be sure
to get it right. It's a bummer to have a good flight disqualified on a
technicality but the technicalities are part of the process. Don't cut
corners.
Good luck!
Flight recorder:
Cookie
thanks, bob
Dan Marotta
Old February 22nd 15, 03:11 AM posted to rec.aviation.soaring
Cookie
Here's the skinny on OO....so just about (but not necessarily) every SSA member
A:
In the United States, the SSA has established the following requirements for a person to act as an Official Observer (OO) for any FAI Badge or Record flight or SSA State Record or Awards flight:
Must hold at least an SSA B Badge or higher SSA Badge (C or Bronze Badge), or a leg of an FAI Badge (e.g., Silver Altitude) or completed FAI Silver, Gold or Diamond Badge.
Must have a working knowledge of the FAI Sporting Code as it pertains to gliders (Section 3) including Annex C which is a guide to the Code.
Must be an SSA Member.
An Airport Manager may also act as an Official Observer
corners.
Good luck!
Flight recorder:
Cookie
thanks, bob
Dan Marotta
Old February 22nd 15, 03:52 AM posted to rec.aviation.soaring
I'll second the use of the FlywithCE FR300. I purchased one for this past season and was able to obtain my Silver Badge with it. It does require you to use the associated Logbook to download the .igc's from the recorder. Naturally the Logbook program is only available for a Windows based computer.. This did force me to finally install Bootcamp and Windows 7 on my iMac. But use of the Recorder is extremely easy. I just turn it on about 10 minutes or so before takeoff and turn it off a couple of minutes after landing and that's it.
Old February 22nd 15, 02:51 PM posted to rec.aviation.soaring
Bob Pasker
well, I am not getting a barograph. this is 2015, after all
so the low-cost choices seem to be (correct me if I'm wrong):
Fly WithCE (needs windows, but I guess I can install Parallels on my Mac)
EW Microrecorders (looks like a Hayes Modem from 1982)
LXNAV Nano (seems to be my favorite choice right now)
they are all within my price range
can any of these devices act as a high-res GPS source for an iPad running, say, Foreflight or one of the soaring apps, either over bluetooth or USB?
thanks!
Old February 22nd 15, 03:08 PM posted to rec.aviation.soaring
Bob Pasker
looks like their Logbook program installs and runs in Parallels + Windows 10 Technical Preview, but I don't know if it will connect with the device because I don't have one
Old February 22nd 15, 03:39 PM posted to rec.aviation.soaring
Craig Funston
Shoot, for $100 more the Nano 3 looks like the way to go.
Old February 22nd 15, 04:41 PM posted to rec.aviation.soaring
Bob Pasker
i like the electronic vario on the Nano3, but the user experience for operating its modes and screens belongs in a cardboard box in the garage with the barograph. I'd rather use a soaring app with my touchscreen iPad or iPhone.
Old February 22nd 15, 05:14 PM posted to rec.aviation.soaring
Craig Funston
Agreed Bob. But as a back up, the nano three isn't bad. It has Bluetooth so you can probably use iGlide with your iPhone or iPad.
fly with ce silver badge question Bob Cook[_2_] Soaring 4 August 20th 13 04:37 PM
fly with ce silver badge question Bob Cook[_2_] Soaring 0 August 20th 13 02:47 AM
Silver Badge! [email protected] Soaring 17 November 24th 08 03:12 AM
Silver Badge Fun (?) Mark Zivley Soaring 43 July 14th 03 07:52 PM
Silver Badge Fun (?) - real challenges? Nyal Williams Soaring 0 July 11th 03 04:45 PM
