CNC Waterjet cutting instrument holes
Old February 26th 15, 10:24 PM posted to rec.aviation.soaring
Default CNC Waterjet cutting instrument holes
After designing the panel on AutoCAD, I sent the .dwg file to Severn Valley Sailplanes in the UK. They made the fibreglass panel and CNC cut the holes.. They did an outstanding job, produced a delamination-free panel and shipped it to my door. If I was to try to find a negative it would be the wait before starting as they had a number of jobs on. But for experienced pros, definitely worth the wait.
CJ
B3
Old February 27th 15, 02:54 AM posted to rec.aviation.soaring
jfitch
I have cut a lot of fiberglass on waterjets. It will delaminate a small circle around the hole pierce, this can be avoided by drilling thru holes where they can start the cut. A backing board will not prevent it, it is a consequence of the waterjet pressure forcing between the laminate layers before the pierce is complete. The edge will be very nice and clean. You can also cut the panel in a conventional CNC machine, however fiberglass is pretty abrasive and so many CNC shops don't want to deal with it (dust gets into the machinery and wears it out). I will cut it on my open mill so I can vacuum up the dust and chips as it is cutting (but I still don't like it), I will not put in the VMC with coolant etc. - no way to collect the dust.
Old February 27th 15, 03:13 PM posted to rec.aviation.soaring
Richard[_9_]
On Thursday, February 26, 2015 at 12:06:01 PM UTC-8, wrote:
Hey All,
Does anybody have any experience with getting a fiberglass instrument panel CNC cut with a waterjet (or any other CNC cutter for that matter)? I called several local shops and I couldn't get a definitive answer whether the waterjet will delaminate the composite around the cut holes or not.
I've previously cut with bi metal hole saws and the hole turned out quite a bit too large and I trust a robot to measure a lot more accurately than myself. I was also interested in laser CNC cutting, but I'm pretty sure that will burn the composite around the edges of the cuts.
Any input would be appreciated.
Thanks,
Omri
Holes saws are very inexpensive at Home Depot. 2 1/4" 57mm, 3 1/8" 80mm.
Use these instruction to draw the hole on the fiberglass panel. Center punch and be very accurate. Pilot drill with a small drill and then drill mounting holes and large instrument hole. Fiberglass cuts like butter. Use a drill press and plywood for backing drill from the back of the panel.
Instructions to make the perfect hole.
http://www.craggyaero.com/Drawings/I...0Templates.pdf
Richard
www.craggyaero.com
Old March 30th 15, 07:02 PM posted to rec.aviation.soaring
Hey All, I ended up having it CNC routed by a machine shop named AST Waterjet (they do CNC routing too) in Grand Prairie, Tx (in the Dallas area). Cost me $195 which was their shop minimum. It turned out really well, no delamination around the edges. I had them drill the 4 screw holes around each instrument undersized and I reamed the holes up by hand with a drill press after. Every hole lined up perfectly so I didn't need to oversize any of those screw holes which was nice from a hole edge clearance point of view and since some instruments used 3mm screws, some 3.5mm and some 6-32. Turned out nicer than I could ever imagine doing by hand and probably saved me a lot more than $200 of my time. Did a full trail fit of all instruments, switches and everything yesterday and it all fit well, I'm spraying primer on the panel later on today.
Old March 30th 15, 07:55 PM posted to rec.aviation.soaring
Craig Funston
Great news. Thanks for the update & have a good flying season.
Craig
7Q
Trying to fill some holes in the instrument panel [email protected] Soaring 2 February 12th 14 02:55 AM
Cutting 57mm holes in the instrument panel.....how to? John Bojack[_2_] Soaring 20 November 12th 10 09:15 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
Cutting shirttails??? Larry Dighera Soaring 11 September 3rd 03 03:34 PM
