new wingtip design
Old February 27th 15, 08:24 PM posted to rec.aviation.soaring
ND
Default new wingtip design
interesting article about a potential winglet replacement for jets.
I personally think that winglets have more sex appeal though, especially maughmer's.
http://www.gizmag.com/minix-wing-tip...ynamics/15526/
Old February 27th 15, 08:39 PM posted to rec.aviation.soaring
Jonathon May[_2_]
maughmer's.
http://www.gizmag.com/minix-wing-tip-vortex-aircraft-
aerodynamics/15526/
That's quite old ,has it moved on ?
Anything that improves performance is worth a try .And something that
makes it easier to fit the covers is a bonus.
Old February 27th 15, 09:47 PM posted to rec.aviation.soaring
It's an almost 5 year old article.
Never heard of it before, it was so good, we all would have likely heard more about it.
My understanding is the tip vortex is based mostly on wingloading, the higher the loading the worse the vortex is (everything else remaining the same).
Some airfoils & aspect ratio's are worse than others in terms of vortex with a similar wingloading. And yes, speed has an effect as well.
I would like to see the actual tests performed between a "plain tip", winglet and this device.
Old February 27th 15, 10:20 PM posted to rec.aviation.soaring
I did a Google search for "Minix wing tip"
Came up with....
https://www.google.com/search?q=%22M...sm=93&ie=UTF-8
This page (out of the 1st link) is sorta interesting (it's on page 3 of the above search).
http://www-mip.onera.fr/projets/Wake...Durston%5D.pdf
Most of the pages are old, the "newer ones" basically regurgitated the older info......
Curious on what others here think/feel/know......
Old February 27th 15, 11:25 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
Snip...
Think/feel...
These sorts of things are what happens when intuition is applied inaptly, kind
of like those early schemes proposing ways for making balloons dirigible, i.e.
steerable...you know, oars and sails and the like. How does this magical
"unwinding" device go about capturing the entire pressure differential between
bottom & top of the wing so's to prevent vorticity developing? Methinks at the
very least a considerably larger bell-mouth is in order to have potential for
ANY detectable vortical disruption. :-)
Quite Possibly/Presumably In the "Know Dep't." (Copied from comments)
"I tested this device for my university thesis and it done nothing at all but
to increase drag due to the extra skin friction drag caused by a greater
surface area. The vortices do not reduce because the design considers the
physics on too primitive and intuitive a level."
James Fletcher
26th March, 2012 @ 01:58 pm PDT
Old February 28th 15, 01:30 AM posted to rec.aviation.soaring
Craig Funston
Snip...
Think/feel...
James Fletcher
Excellent discussion of "Common Misconceptions in Aerodyanmics" Worth the time to listen to the whole thing.
https://www.youtube.com/watch?v=QKCK...bn0iDCBbgpLbX6
Craig
Old February 28th 15, 03:34 AM posted to rec.aviation.soaring
BobW
Snip...
Think/feel... These sorts of things are what happens when intuition is
applied inaptly, kind of like those early schemes proposing ways for
making balloons dirigible, i.e. steerable...you know, oars and sails and
the like. How does this magical "unwinding" device go about capturing the
entire pressure differential between bottom & top of the wing so's to
prevent vorticity developing? Methinks at the very least a considerably
larger bell-mouth is in order to have potential for ANY detectable
Quite Possibly/Presumably In the "Know Dep't." (Copied from comments) "I
but to increase drag due to the extra skin friction drag caused by a
greater surface area. The vortices do not reduce because the design
considers the physics on too primitive and intuitive a level." James
Fletcher 26th March, 2012 @ 01:58 pm PDT
Craig
Great lecture - wish I'd had more like this in collich!
The aero engineer in me is still laughing at: "It's easy to explain how a
rocket works, but explaining how a wing works takes a rocket scientist."
Making it even funnier is that I used the degree for the first 4 years after
school in the solid rocket motor industry, where "rocket scientist" jokes were
rife...and decades later, non-aerodynamiscist-me is still trying to refine my
understanding/explanation for lift and its generation! Considering sailplanes,
I'm presently a fan of: gravity causes lift - after that things become
complicated! :-)
Bob W.
Old February 28th 15, 04:59 AM posted to rec.aviation.soaring
Paul Villinski
As a non-scientist/engineer, it baffles me that we are able to build amazingly sophisticated airplanes, yet, as the lecturer demonstrates, there is a huge amount of confusion over how to explain why a wing produces lift, and many of our common assumptions are simply wrong, i.e., the reason(s) for accelerated airflow over the top surface (which intuitively has never made sense to me). Engineers designing airplanes are themselves still arguing over whether it's more about Bernoulli or the downward-turning force or Coanda effect. Yet, I'm still able to get from one coast to another at 35,000 feet traveling at 600 mph, while sipping coffee and watching a movie.
Old February 28th 15, 06:02 AM posted to rec.aviation.soaring
I've been flying airplanes professionally for close to forty years and sailplanes for fun. I spend a lot of time looking at the wing trying to understand how it works. In the end, I conclude it's all magic. I kinda like that.
Old February 28th 15, 09:54 AM
Skypilot Skypilot is offline
Member
First recorded activity by AviationBanter: Feb 2012
The biggest problem is trying to prove up the % saved. Then you have to convince the bean counters.
A wingtip Glenn[_2_] Aviation Photos 5 September 3rd 10 03:33 PM
Yet another PA-28 wingtip query... Mike Spera Owning 2 August 4th 09 03:07 AM
Wingtip Camera NG[_2_] Soaring 14 April 9th 09 11:38 PM
Wingtip Camera kestrel19 Soaring 0 April 9th 09 04:02 PM
L-23 wingtip wheel modification 5Z Soaring 0 February 8th 06 05:50 PM
