When I owned my Astir, I machined a delran rod of the appropriate ID to use for the purpose of aligning the ball sockets at the start of assembly. Much cleaner than using my hands.
Secondly, you do want to make sure the outside of the ball is well lubed; I used a synthetic grease (Superlube). Keep the interface with the socket well packed. Third, the trick is to have everything carefully aligned beforehand. Fuselage exactly vertical. First wing inserted exactly at the right dihedral. Slowly and carefully insert second wing using a reference line on the first wing (i.e when the glider is assembled, use a black sharpie to draw a line along the first spar shows how the second spar lines up). If it's all lined up, the ship goes together in seconds. As far as answering the original question (wear limits and such), if Linder wasn't aware of any, then there's probably none published. Robert Mudd is a good source of info. PM me if you want more thoughts. Erik Mann On Thursday, March 5, 2015 at 8:42:18 AM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote: On Wednesday, March 4, 2015 at 7:23:03 PM UTC-5, JJ Sinclair wrote: The root rib bearing spinning during assembly is something all Grobs have in common. With the ship assembled, I would check for any vertical movement at wing tip (with the other wing tip on a stand). Pick up wing tip with about 25 pound force and check for slop. You can feel any movement. If the wings are tight, I wouldn't change the bearings. You could consider gooping up the bearing to keep it in proper alignment for next assembly, something that would keep the bearing from spinning and still allow slight movement.. The heavy wax used in a toilet ring might do the job. Hope this helps, JJ Reread the 1st post, they have an issue of NOT being able to align the "ball" easily. ;-) Movses....... I would try using a bar (maybe brass or aluminum) inside the "ball" and working it around while spraying some WD-40, PB Blaster, Kroil, etc. on the "ball - socket joint". You will likely wash out some rust and maybe smooth some rough spots. I would just do enough to get it "free" as you don't want it to go too loose, then you're into what JJ was referring to. Wipe everything down to get it clean & dry once the ball is free. Keep a bit of a light oil on the OD of the ball once it's free. PS, I would use plastic sheeting or similar to keep whatever spray you use from soaking into the rest of the wing root. |
HI
When I owned a Astir CS some years ago I replaced those bearings. At the time I felt that they had too much free play or slop in them. I made a device fitted into the centre of the bearing and then expanded out to grip the internal grove inside the bearing. I then had a outer cup which that had an internal bore just greater than the outer of the bearing. The system was such that by screwing up a nut on the outside it would pull the bearing out whilst pushing on the outer mounting region. I have still have the device in my shed. Those bearings take the bending moment of the wings into each other. In service the only time those bearings move would be during rigging and hence it should never be to large angles. Free play in the bearings would really only be noticed in load reversals. Binding in those bearings would only be a problem if they were causing difficulty during rigging. As Papa3 mentions the secret in rigging is getting the wing angles correct. I never worried about lining up the bearings just made sure that the wing angles were correct and presto it worked for me. johnorto at gmail dot com |
K8 wing root depth | Mike Dowling | Soaring | 1 | July 3rd 14 11:30 PM |
Grob 102 Astir CS | fredblair | Soaring | 1 | February 18th 12 11:06 AM |
Grob 102 Astir Std III | [email protected] | Soaring | 0 | May 30th 07 09:27 PM |
Grob wing retainer bearings | Tim | Soaring | 3 | September 3rd 06 02:55 PM |
Wing root fairings | D.A.L | Soaring | 10 | October 29th 03 11:36 AM |
