"John Waters" wrote in message m...
wrote in message ... Trying to fly these in the game IL2 is a waste of time, they are really crap. I can't believe this was realistic in comparison to other fighters of the time. Anyone know how good the real planes were and/or what their major weaknesses were? Biggest problem about computer games I have discovered so far is Earth's G effect is ignored (the egg) along with no unloaded (zero-G) accleration increase. The gun ranges far exceed actual effective ranges in real life, as well as the lead requirements are way too small. For example, co-speed 400KIAS, 1500 foot range, 5 G, the pipper sags down below the nose in an F104A - your target's wings stick out each side of the radome. Also, fuel consumption is also way too low, at a guesstimate about 1/4 what it really is in combat. Walt BJ |
![]() BTW, the Spitfires are nice till you get P51s but the Hurricanes have a turning radius and roll rate that seems to be an advantage in some engagements. I wonder if this reflects real conditions? I went about European Air War completely backwards - flying missions in Me 262s and P-47s against essentially sitting ducks (B-24s and He 111s, respectively). After a couple years playing it and trying nearly every aircraft, I flew a couple campaigns set on realistic (read: landing by parachute was considered a success) and the best fighter v fighter in the game was a Spit IX. Close second, as far as flying a whole campaign, was the Hurricane. That thing had a ton of guns and most of what was being fired back was light enough that, when hit, you could bail out over friendly territory and begin again. Defending Beachy Head from a sky full of 110s seemed pretty realistic, *for a game*. One thing I hate about WWII flight sims is that aircraft in bomber streams never seem to feel effects of turbulance. Formations bob ever so gently in rhythmic patterns at a set airspeed, like perfect robots. 10+ Mosquitos fly along at 12,000' in loose groups at 280 knots, serene as nuns as you fall in astern. Yah, that's realism. Has anyone seen a decent nightfighter sim? Something in a Mosquito or Beau..? v/r Gordon ====(A+C==== USN SAR An LZ is a place you want to land, not stay. |
![]() Has anyone seen a decent nightfighter sim? Something in a Mosquito or Beau..? Nothing on that front, Gordon. There's been discussions about the subject and while it would be quite easy to put the right planes into night skies, everything else is way harder to make. Radar, for example. It would be immensely hard to make a radar display that works like the original. Having computer voice give you corrections from "his" radar display could work, but that would lack the feeling. Night war was so technical, that you know, it would be mostly flying in dark sky and not seeing anything - and that would bore 99,5% of the players. THOUGH... We did run a three battle long night bombers campaign on WarBirds simualtor a few years ago. It was fantastic, though very hard. We managed to do it with a lot of tweaking. Many interesting things "adjusted" to make a daylight air combat sim to work in a night bomber scenario, but it worked surprisingly well. Skipping the details, the RAF bombers did not have any radars, RAF night intruders had partial radar picture, Luftwaffe night fighters had no radar and Luftwaffe ground control had full radar picture. This worked in teh in flight map, little dots moving in the map and we limited that each and every person could see. Very rough, not like a real radar at all but best what we could do. Most of the planes were almost correct, some changes with sub variants, just that the Lancaster had to be replaced by B-24. In the end, the scenarios were amazing. The pilots flying in almost blind, relying largely on instruments, Luftwaffe interceptors listening to ground radar comms and trying to find the bomber streams from blackness, me as CO of one night fighter squadron plotting the map, moving counters on tablemap, trying to guide the night fighters around RAF intruders hunting near airfields and yelling to the guys on radio (real time voice comms) when they were too late making a turn or druly commenting "scharm 3, you're in middle of bomber stream". "Control, we don't see anything..." "Scharm 3, watch again, I repeat you are in middle of 12+ bombers, control out". So night bombers can be simulated in some way, in at least correct online environment, but I don't quite see much changes for a dedicated simulator. One was in the works by hobbyists but I think that project has died. Here's some info/pictures on the night bombers battle: http://vip.mikrobitti.fi/~jukkak/wb/...ns.htm#emc15.1 jok |
Regnirps wrote:
snip BTW, the Spitfires are nice till you get P51s but the Hurricanes have a turning radius and roll rate that seems to be an advantage in some engagements. I wonder if this reflects real conditions? AFAIR it does, at least prior to the Spits getting metal ailerons (which boosted their roll rate at high IAS). That came in starting as a retrofit on either Mk. IIs or Mk. Vs, I forget which. IIRR, the Hurricane I could out-turn the Spit I at low/medium altitudes, but the Spit had better speed up high so it had a more Ps available up there, where the Hurricane was hanging on a stall while maxed out. Guy |
On Sun, 23 May 2004 05:21:00 GMT, Guy Alcala
wrote: AFAIR it does, at least prior to the Spits getting metal ailerons (which boosted their roll rate at high IAS). That came in starting as a retrofit on either Mk. IIs or Mk. Vs, I forget which. Officially, Mk Vs, but that didn't stop some unit commanders (e.g. Bader at Tangmere) short-circuiting the procurement procedure to get their Mk IIs fitted with them. They apparently weren't common on the Mk V until late in 1941, as Neville Duke complained when his metal-aileroned Mk V was lost on operations with another pilot that summer. And that was when he was with 92 Squadron, the first to get Spit Vs. Gavin Bailey -- Now see message: "Boot sector corrupt. System halted. All data lost." Spend thousands of dollar on top grade windows system. Result better than expected. What your problem? - Bart Kwan En |
Well, I dont know which flightsims you tried, but Il-2 surely can't be
blamed of having a simplyfied gunerry model. Every bullet is a vector defined object, as well as aircraft, and collision between these objects is what is used in IL-2 to detect hits being scored. In older sims the hit bubble was used so it was rather easy to score hits. Now I haven't fired an airborne weapon in my life, but IL-2 feels just about right. It also has a state of the art flight model. I don't think you will be dissapointed if you try it. It would also be very interesting to read what you think of it once you've tried it. As for jet sims, the latest thing is LOMAC which models modern jets (F-15, A-10, Su-27, Mig-29). Jets of the '60s are soarly missed in todays flightsim market... I'd really like a decent F-104 sim... __/ G R E E T I N G S ! \__ \ / "WaltBJ" wrote in message om... "John Waters" wrote in message m... wrote in message ... Trying to fly these in the game IL2 is a waste of time, they are really crap. I can't believe this was realistic in comparison to other fighters of the time. Anyone know how good the real planes were and/or what their major weaknesses were? Biggest problem about computer games I have discovered so far is Earth's G effect is ignored (the egg) along with no unloaded (zero-G) accleration increase. The gun ranges far exceed actual effective ranges in real life, as well as the lead requirements are way too small. For example, co-speed 400KIAS, 1500 foot range, 5 G, the pipper sags down below the nose in an F104A - your target's wings stick out each side of the radome. Also, fuel consumption is also way too low, at a guesstimate about 1/4 what it really is in combat. Walt BJ |
Walt I have no idea what sim you are refering to with F104s etc, IL-2 is an
WW2 FS, that is considered by many, to be the most realistic WW2 FS made.. As to gun ranges in IL-2 they are accurate from what I have read in WW2 pilot AARs etc. As to gravity effects etc, thats a question better presented at: http://ubbxforums.ubi.com/6/ubb.x?a=...102&f=63110913 Regards, John Waters "WaltBJ" wrote in message Biggest problem about computer games I have discovered so far is Earth's G effect is ignored (the egg) along with no unloaded (zero-G) accleration increase. The gun ranges far exceed actual effective ranges in real life, as well as the lead requirements are way too small. For example, co-speed 400KIAS, 1500 foot range, 5 G, the pipper sags down below the nose in an F104A - your target's wings stick out each side of the radome. Also, fuel consumption is also way too low, at a guesstimate about 1/4 what it really is in combat. Walt BJ |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
Good Ad! WWII Pilot | Joe | Military Aviation | 0 | January 11th 04 09:37 PM |
P-47/51 deflection shots into the belly of the German tanks,reality | ArtKramr | Military Aviation | 131 | September 7th 03 09:02 PM |
FA: WWII B-3jacket, B-1 pants, Class A uniform | N329DF | Military Aviation | 1 | August 16th 03 03:41 PM |
