PowerFlarm Range Analysis for "WX" - 15M Nats Yreka 2014
Old March 27th 15, 03:22 AM posted to rec.aviation.soaring
Default PowerFlarm Range Analysis for "WX" - 15M Nats Yreka 2014
On Tuesday, March 24, 2015 at 12:32:03 AM UTC-7, waremark wrote:
Your performance is way better than my Euro Flarm fitted inside the LX 9000.
My problem with the range analysis tool is that it only tells you where you did pick up gliders. It does not tell you about the Flarm equipped gliders which you did not pick up. Did you never get contacts (or gliders) 'suddenly' appear closer than say 2k?
Mark Burton
I ran FLARM range files for ~dozen of the contestants I flew with in a contest last year by downloading their IGC contest files. Most had 4-6 km ranges (including mine) except for 2. One was a portable, the other was a Euro Flarm in an LX8000, both had ranges of around 1 km.
If gliders are "suddenly appearing" you might check some of their IGC files (OLC?) and see if that helps to sort out if the problem is their installation and/or yours.
2014 SSA/US Tasking Analysis Sean Fidler Soaring 68 February 4th 15 06:21 PM
Interesting analysis of US Soaring Team Results (1950-2014) Sean Fidler Soaring 6 January 31st 15 05:32 AM
PowerFlarm: 2.7 Vertical Range [email protected] Soaring 8 April 9th 13 11:27 PM
PowerFlarm Range Analysis Richard[_9_] Soaring 0 March 25th 13 04:43 PM
PowerFLarm expected range [email protected] Soaring 6 August 30th 12 03:43 PM
