Cockpit Size and Comfort
Old May 5th 15, 10:01 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default Cockpit Size and Comfort
On Sunday, May 3, 2015 at 7:04:57 AM UTC-7, Mike Rinaldi wrote:
I am looking to purchase a new (to me) XC ship. Which ones have the largest/roomiest cockpit? Not for a tall person, one with broad shoulders, about 5'9 and 200lbs. Discuss and Thank you in advance!
Go to a glider field with a lot of gliders - a reasonably well-attended contest is a good idea. Ask pilots if you can test-fit. I dare say most will say yes (unless it is time to launch - don't do that). Cordele is probably the closest contest to you in early June or Sports Nationals in Waynesville. I flew all the way across the country to play "try on" when I was in the market.
I am the same general proportions as you describe (as far as you go at least). The only glider I can't fit in with my shoulders parallel to the wings are the Shempp a-models. Unless you are a serious bodybuilder or made out of very low-density stuff, you should be able to fit into pretty much anything -- so it's a matter of overall comfort. Beyond width, there will be a host of other dimensions that you may like or dislike. My arms aren't long enough to reach the instrument panel without a lot of fiddling with sitting position on most Shempp gliders. The LSs have a pronounced hump under the knees which some pilots like and some don't. LS heel brakes, Shempp motorcycle brakes, front canopy, side canopy, removable canopy, rudder pedal width and height, etc. Then there are flying qualities, flaps/no flaps, span and on and on.
No substitute for sitting in a few - preferably in your price range. Wings and Wheels can give you some ideas about that. Also keep in mind that there are fewer fuselage variants than there are glider types - a little querying of experienced pilots will help make the challenge manageable if you don't know or remember. My rough recollection of common fuselages across multiple models is:
Libelle 201/301 (depending on canopy)
Cirrus and Mini-Nimbus (?)
LS-3, LS-4
LS-6, LS-7, LS-8, LS-10
Pretty much all the single-seat DGs after the 100 (?)
Ventus/Discus a
Ventus/Discus b
(similar, if not identical for V-2/D-2 a vs b/c) (?)
ASW-19/20, Pegasus
ASW-24, 27, 29
I'm sure others can add/correct, but that's reasonably close. I didn't get into open class - some go straight there but most don't.
Andy
Old May 5th 15, 02:00 PM posted to rec.aviation.soaring
PBA
Ahhh, there is nothing more fun than shopping for a new-used glider.
There's a nice Grob 102 on Wings and Wheels. That's got to be the #1 value in used glass gliders. Typically around $15,000, you get 34:1 real world L/D and all the performance needed to do lots of XC training.
I flew one for a year and loved it. Heavy on the controls but climbs and penetrates well. I would only lose a little flying with a Ventus and and LS8 if we were at 65 kts or less....
I'm 6'4" 165 lbs. It's very comfortable. Did my silver duration in it and wasn't even hurting in my back by the end. You would have ample room and you will be able to pull your knees up and stretch a bit in the cockpit if needed. Good to keep the blood flowing.
As others have said though, 5'9" 200 lbs is pretty standard, you are going to fit in most everything comfortably. As I'm sure you've been told, ease of assembly and the trailer rigging is major because if it sucks to put together, you will start coming up with reasons not to do it and fly the club ships.
With that said, the Grob is not my favorite to put together. The wings are tricky to get on for the first 10 assemblies but then you learn the tricks and do it much faster. Airbrakes are excellent and noisy so you'll never mistake them for being closed. Built like a tank and sort of feels like it flying, but thermals very well.
Old May 5th 15, 04:31 PM posted to rec.aviation.soaring
kirk.stant
Unless you were thermalling, the only time a Ventus or an LS8 will be flying at 65 kts or less is in the pattern... ;^)
Seriously, a G-102 is a nice club ship, but probably not the best for a first XC ship - if only because it can be a pain to rig and derig (BTDT). I would recommend the LS4 as probably the absolute best (and a much more comfortable cockpit than the G-102, IMO), but they can be rare. Next, ASW-19, Pegase, DGs, etc all have comfortable cockpits - the best advise was given earlier - try them out. Someone mentioned that the Pik-20 had a big cockpit - yes if you are tall and thin, but it's a bit narrow and you have to have room to move the flap handle, so definitely check it out first.
But comfort is what you make of it. I'm pretty hefty (5-11, 240) and fit just fine in my LS6. I just have to make sure I don't have to fold a chart inflight! But it's a racing glider and I like it nice and tight...
Anyway, it's the condition of the trailer that really counts!
Kirk
66
Old May 5th 15, 04:49 PM posted to rec.aviation.soaring
Papa3[_2_]
Kirk
66
Ask 20 glider pilots this question and you'll get 20 different answers. So, FWIW...
I'm 6'0", 200 lbs, with shoulders and a back that developed their shape thanks to 30 years of swimming. I'm not super wide but the upper back is where I run into issues.
I owned a Grob Astir CS, and it's without a doubt the roomiest cockpit. But, I've flown all of the following and managed to fit pretty well (LS 3,4, 6, and 8). ASW-20, 27 and ASG-29. Libelle 301. Discus and Discus 2b. The only one that was a definitely not for me was a Ventus 2a, but you already knew that.
So, I think the advice to pick your price point first, then go sit in a few gliders that fall into that range makes the most sense.
As far as the Grob was concerned, my two cents. It was actually quite easy to rig if you took the time to figure out a few minor tricks. Those have been covered in prior threads. The other point is that the Grob always wanted to have at least some water. With 20 gallons, it still climbed very well and it ran much, much better. Dry, it was a struggle to keep up with other standard class ships on the run (note that at that point in my soaring career I was probably only 180 lbs, so I had even less personal ballast).
Erik Mann (P3)
Old May 5th 15, 04:54 PM posted to rec.aviation.soaring
Dan Marotta
snip
Kirk 66
Gotta call BS on the trailer thing. If it's flying you want, who cares
about the trailer? It might add 10-15 minutes to rig and derig times
but that's a miniscule part of the soaring day.
I've had Pfeiffer, Minden, Komet, Cobra, and LAK trailers and, though I
preferred the Cobra, it was the glider I was after, not the trailer.
My advice is: Get the glider you want and take whatever trailer it
comes in. After all, you don't sit in the trailer all day, do you? BTW,
I'm very pleased with the comfort of my LAK-17a and the LAK T5 trailer
is designed specifically for that glider.
Dan Marotta
Old May 5th 15, 05:10 PM posted to rec.aviation.soaring
Tango Whisky
Le mardi 5 mai 2015 16:54:48 UTC+2, Dan Marotta a écrit*:
snip
*Anyway, it's the condition of the trailer that really counts!
Kirk
66
Gotta call BS on the trailer thing.* If it's flying you want, who
cares about the trailer?* It might add 10-15 minutes to rig and
derig times but that's a miniscule part of the soaring day.
though I preferred the Cobra, it was the glider I was after, not the
trailer.
My advice is:* Get the glider you want and take whatever trailer it
comes in.* After all, you don't sit in the trailer all day, do you?*
BTW, I'm very pleased with the comfort of my LAK-17a and the LAK T5
trailer is designed specifically for that glider.
Dan Marotta
I would second that. Get the best glider you can afford - any upgrade from a ****ty trailer to a decent trailer is relatively cheap and can be done a year or two later.
Old May 5th 15, 07:57 PM posted to rec.aviation.soaring
On Tuesday, May 5, 2015 at 10:54:48 AM UTC-4, Dan Marotta wrote:
snip
snip
Dan Marotta
If you think a ****ty trailer only adds 10-15 minutes, then you never used a real "****ty" one !
Todd Smith
3S
Old May 5th 15, 08:25 PM posted to rec.aviation.soaring
joesimmers[_2_]
Hmm.. Let me guess, you keep your glider rigged and in a hangar?
The trailer is pretty important when you rig/derig every flight.
Old May 5th 15, 02:37 PM posted to rec.aviation.soaring
krasw
Since there is no mention of budget, EB-29 has a fairly roomy cockpit.
Old May 6th 15, 03:48 AM posted to rec.aviation.soaring
Mark628CA
Bob W. hit on the absolutely best argument about the trailer issue (now that this thread has drifted so far from the initial query).
If the rigging procedure is so painful that it causes a reduction in your airtime (Should I? It doesn't look that good. Maybe tomorrow...) then you need a better trailer or rigging procedure.
Similarly, if you have to land early to make sure you have assistance to de-rig (Hey! Where did everybody go?) then you need a better trailer or de-rigging procedure.
I still like the hangar option, and as an added benefit, I save ounces of pennies on wing tape.
LS6"C" (17.6) Cockpit Size Mike Williams Soaring 6 February 16th 15 12:52 AM
Discus 2a cockpit size EdByars Soaring 1 March 18th 10 04:37 AM
Discus 2a cockpit size Stephen[_3_] Soaring 7 March 17th 10 06:57 PM
Cockpit size of Libelle? Kevin Morris Soaring 4 July 16th 04 12:32 AM
Discus 2b cockpit comfort? Jeremy Zawodny Soaring 11 January 12th 04 09:03 PM
