wrote in :
Vaughn wrote: On 5/9/2015 4:32 PM, wrote: If you burn hydrogen in an engine, you get lots of NOX byproducts, i.e. smog, because air is mostly nitrogen and hydrogen has a very high flame temperature. Fuel cells do not have that problem as the temperatured involved are much lower. Yes, but my point was that you are still left with the problem of the pollution and greenhouse gas generated by the production of your "clean" hydrogen fuel. Besides, for at least the last 30 years, mass consumer fuel cells have been "just around the corner". Even if they suddenly became practical and economical, we would still be left with the huge problems involved in producing and distributing hydrogen. You can wave your arms and talk about fuel cells all day, but the problems with hydrogen won't go away. Hydrogen is not an energy source. To make hydrogen, you make pollution. And my point was if you BURN hydrogen, you make pollution. You are BOTH right. And a similar argument can be made for going all electric. How do you make electricity? Right now, most of it is made by BURNING hydrocarbons. Moving to electric powered vehicles only shifts the location of the burning from the vehicle to the electric power plant. The only way to make electric vehicles viable from a 'pollution elimination' point of view is to ALSO generate the electricity from some other method than burning hydrocarbons. As Vaughn pointed out, we have to find an alternate SOURCE of energy, not an alternate medium by which to store it. Hydrocarbons are a source of energy. We get more energy out of hydrocarbons than we put in to extract it. We don't have to make it. Although there is the argument about how much is left. The problem is finding a viable alternate source of energy to replace hydrocarbons. Ones that can produce energy on par with, and for future growth eventually exceed the scale of what we get out of hydrocarbons. And then there's the whole problem of upgrading the power grid to handle everyone plugging in their e-car's without the wires glowing. The alternative to that may well be distributed energy generation. Replacing hydrocarbons for transportation use is not a simple or singular problem. At the risk of sounding cliche, it will require a paradigm shift in the way energy is produced, distributed, and consumed, and it will have to be adopted by everyone to make it work. Brian -- http://www.earthwaves.org/forum/index.php - Earth Sciences discussion http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Sed quis custodiet ipsos Custodes? |
In article , ,
says... Vaughn wrote: On 5/9/2015 4:32 PM, wrote: If you burn hydrogen in an engine, you get lots of NOX byproducts, i.e. smog, because air is mostly nitrogen and hydrogen has a very high flame temperature. Fuel cells do not have that problem as the temperatured involved are much lower. Yes, but my point was that you are still left with the problem of the pollution and greenhouse gas generated by the production of your "clean" hydrogen fuel. Besides, for at least the last 30 years, mass consumer fuel cells have been "just around the corner". Even if they suddenly became practical and economical, we would still be left with the huge problems involved in producing and distributing hydrogen. You can wave your arms and talk about fuel cells all day, but the problems with hydrogen won't go away. Hydrogen is not an energy source. To make hydrogen, you make pollution. And my point was if you BURN hydrogen, you make pollution. Water is pollution? I think you either need to get your chemistry right, or define "hydrogen" - or perhaps, what you are burning. Hydrocarbons? -- Duncan. |
Dave Doe wrote in
: Water is pollution? I think you either need to get your chemistry right, or define "hydrogen" - or perhaps, what you are burning. Hydrocarbons? Burning hydrogen with pure oxygen produces only water vapor. For example, LH2 and O2 rocket engines such as the Shuttle's. Burning hydrogen with 'air' also produces other compounds, including nitrous oxides (smog, harmful to humans). 'Air' is not pure oxygen. Check your chemistry. ![]() Brian -- http://www.earthwaves.org/forum/index.php - Earth Sciences discussion http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Sed quis custodiet ipsos Custodes? |
Dave Doe wrote:
In article , , says... Vaughn wrote: On 5/9/2015 4:32 PM, wrote: If you burn hydrogen in an engine, you get lots of NOX byproducts, i.e. smog, because air is mostly nitrogen and hydrogen has a very high flame temperature. Fuel cells do not have that problem as the temperatured involved are much lower. Yes, but my point was that you are still left with the problem of the pollution and greenhouse gas generated by the production of your "clean" hydrogen fuel. Besides, for at least the last 30 years, mass consumer fuel cells have been "just around the corner". Even if they suddenly became practical and economical, we would still be left with the huge problems involved in producing and distributing hydrogen. You can wave your arms and talk about fuel cells all day, but the problems with hydrogen won't go away. Hydrogen is not an energy source. To make hydrogen, you make pollution. And my point was if you BURN hydrogen, you make pollution. Water is pollution? I think you either need to get your chemistry right, or define "hydrogen" - or perhaps, what you are burning. Hydrocarbons? Air is 78% nitrogen. Air is used as the oxidizer in an engine. At high temperatures, i.e. inside an engine, the nitrogen combines with the excess oxygen to produce NOx; mostly NO and NO2. It does not matter what is actually "burning", it is the temperature that causes the reaction and hydrogen has a very high flame temperature. As hydrocarbons as a rule do not contain nitrogen, where do you think the NOx emmisions come from? -- Jim Pennino |
SunAero Electric Aircraft | Larry Dighera | Piloting | 0 | September 27th 14 04:52 PM |
WWI WESTERN ELECTRIC SCR 68 AIRCRAFT TRANSCEIVER 1918 | Larry Dighera | Piloting | 3 | October 11th 06 07:35 PM |
NSM History Symposium | [email protected] | Soaring | 0 | April 24th 06 04:11 PM |
Solar Electric Powered Aircraft | Larry Dighera | Piloting | 33 | November 6th 05 08:37 PM |
Solar Electric Powered Aircraft | Larry Dighera | Soaring | 31 | November 6th 05 08:37 PM |
