alternative to iGlide for iPhone (6 plus)
Old May 14th 15, 05:47 PM posted to rec.aviation.soaring
WinPilot
Default alternative to iGlide for iPhone (6 plus)
Jon - we've just sent you email - please reply with a screen shot of the offset glider.
Also, a screenshot of the settings page would be nice so we can try to reproduce the crash while panning.
Would be fun to get you to be one the evangelists of WP over here
Old May 15th 15, 04:26 PM posted to rec.aviation.soaring
Bob Pasker
here's another bug I filed today.
Aktualisiert von: Marc Förderer, 15. Mai, 17:21:
Hi,
I have. It can be resolved with changing the filter (as a workarround).
We'll change that. Thanks for the help!
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 17:20:
lite on iphone6
have you been able to reproduce?
Aktualisiert von: Marc Förderer, 15. Mai, 16:05:
(If you set the data filter to lets say 3000km, you will of course be able to work around that, yet this is not what we want / no general solution)
Marc
Aktualisiert von: Marc Förderer, 15. Mai, 15:57:
What version do you use? Which device?
I suspect iGlide lite on iPhone?
Sorry for the guessing.
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 14:54:
also, i don't know if I can reproduce the problem without taking another 1500km trip!
On May 15, 2015, at 8:52 AM, Bob Pasker wrote:
Am I missing something?
Aktualisiert von: Bob Pasker, 15. Mai, 14:53:
Sent from my iPhone
Aktualisiert von: Marc Förderer, 15. Mai, 14:46:
What happens if you go to Menu route clear route?
Will it "work" afterwards?
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 14:40:
There should never be any reason why I can't clear the destination! But the answer is yes it had a GPS lock.
Sent from my iPhone
Aktualisiert von: Marc Förderer, 15. Mai, 14:31:
In the second city, did you have a current position in iGlide? Was there a GPS-Signal?
A reason for this behavior would be that iGlide did not get a current GPS position.
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 14:04:
i don't understand the question. I flew from one city to another. when I turned on iGlide, i could not clear the previous destination
Aktualisiert von: Marc Förderer, 15. Mai, 13:51:
maybe I got you wrong, did you have a valid position after being 1500km away?
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 13:46:
its not intended to be used in two different places?
Aktualisiert von: Marc Förderer, 15. Mai, 13:45:
Hi Bob,
thanks for the info. We'll fix that, but well, the app is not intended for this purpose.
Cheers
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 13:23:
1. set a waypoint X as a destination in iGlide
2. do a bunch of soaring
3. with the destination still turned enabled, turn off the app
4. fly commercial aircraft to another city 1500km away
5. turn on the app
6. destination X remains selected, destination is 1500km away.
7. touch "NEAREST" to select a new destination. all nearby waypoints are invisible because the data filter is set to 500km, so all you see are airports 1,000km away
the only way I found to clear the fix was to delete the app and reinstall it, which of course deleted all of my data/preferences
Old May 15th 15, 05:13 PM posted to rec.aviation.soaring
son_of_flubber
I don't doubt that you've found a lot of bugs that no one else has found. Most people stay on the well-worn path, and the bugs on those paths are consequently found and removed. Some people like yourself have a habit of using the program more broadly and then they find additional bugs. The other thing that happens is that people fail to notice bugs that they stumble across or they are too lazy to report them.
The grief and character assassination that you've been given here is entirely short sighted and rude. It's not unpatriotic to find bugs. I thank you for your service. If I were an IGlide developer, I'd give you a free copy of the full program to reap the services of a careful tester.
The problem with fixing obscure bugs is that the developers will sometimes introduce more serious bugs for every inoffensive bug that they remove. This is a good justification for not taking the risk of fixing certain bugs. 'If it's not broken too badly, don't try to fix it and make it worse.' Sometimes when a piece of software has a lot bugs, it is better to delete it and start over. Quality is most successfully (and most economically) introduced during the Functional Testing stage. Trying to introduce quality at the System Testing stage is what a lot of managers like to try, to cover up their mismanagement of the initial development process, but it can be like papering over shoddy construction. It can be an attempt to remove the obvious signs of poor quality without removing the underlying poor quality.
The common practice of running more than one flight computer in the cockpit is a good strategy for improving reliability. Putting one of those programs on a cellphone is a practical means to do that.
Old May 15th 15, 05:44 PM posted to rec.aviation.soaring
Bob Pasker
the only person whose character has been assassinated on this thread has been mine. I have a job and a family, and I'm sorry if I would rather spend the time taking my daughter to the park (like I did yesterday afternoon) instead of wading through a few months of email to re-produce a list of bugs that had already been submitted to the manufacturer.
and to the person who tried to shame me by posting my OLC account, that was one of the most childish things I have ever seen in 26 years of using the internet. anyone who would like to make fun of my soaring experience is welcome to read this: https://groups.google.com/forum/#!se...M/glLCoyEoaDEJ
--bob
Old May 15th 15, 06:01 PM posted to rec.aviation.soaring
Sean Fidler
Bob,
You started this thread. A thread clearly naming iGlide and slamming iGlide. You stated (paraphrasing) that it was "full of bugs" and had a "terrible UI." So far, you have only proven to have reported one bug and have failed to identify the supposed "many" others you claim to have identified. You also claimed that iGlide acknowledged many of your bugs as well.
You have brought this thread on yourself. You chose to name iGlide as a poor application.
I am fine if you have found bugs. I would like to hear about them. If you do not produce them, YES, I am going to have to call you out on it and say I DONT REALLY BELIEVE YOU.
Again, you said many bugs, you have only shown me ONE (filed...you guessed it...today).
Please provide a complete list of your "MANY" reported iGlide bugs so that your thread has some actual value to the rest of us and does not just look like a "drive by shooting..."
Otherwise, stop crying about the attention that you have brought upon yourself. It goes with the territory. I suggest you grow some thicker skin.
Sean
Old May 16th 15, 12:17 AM posted to rec.aviation.soaring
6PK
--bob
Quote= "The grief and character assassination that you've been given here is entirely short sighted and rude"
Bob
Don't feel bad. This was not the first time this happened.
The matter of fact this character regularly "character assonates" anyone dear to disagree with him.
I find this kind of behavior not only childish but probably the reflections of a rather narcissistic and insecure person, sign of a real sociopath.
6PK
Old May 16th 15, 03:27 AM posted to rec.aviation.soaring
Sean Fidler
Once again, I am thoroughly amused! Thank you!
Again, Bob vigirously attacked iGlide claiming it was essentially awful software. I asked Bob to substantiate that claim and explain his comments (bugs). He failed to do so. In fact he refused even though he also claimed that Butterfly acknowledged several of his "bugs." I summarized this for the thread readers and have (along with others) defended iGlide from a clearly unsubstantiated and baseless attack. This threads author clearly provided us all with "a work of utter fiction" at best. At worst...
Now I have some other clown calling me a sociopath? I see that as pure victory. :-)
Obviously, I have struck the "proper" nerve with simple, clear and fact based responses to Bob's highly questionable statements about iGlide.
The fact is that iGlide is not "riddled" with bugs at all. It's among the very best soaring navigation applications available for any platform.
End of discussion. Moving on.
Old May 16th 15, 03:37 PM posted to rec.aviation.soaring
My own iGlide experience came about from being an eeejit. I left my Oudie 3 at home (a country different to my gliding location/s) and wanted a cheap stand-in to use in a club glider for a 500km task. For me, iGlide worked really well. It logged the entire flight, uploaded to OLC directly as well as emailing the file in both .igc and .kml formats to myself. It also synced with the iPad version via Dropbox. The iPhone was held in a suction mount in vertical orientation and was always readable, no washout in the sun. I use an iPhone 5 and the screen could do with being a little bigger (# of nav boxes are limited). An iPad mini would be too big unless panel mounted.. An iPhone 6 would be better and a 6+ great. UI is intuitive and easy to use. I used it without the local TP's because unlike maps and airspace, they can only be loaded via iTunes and I was without my laptop too. Task creation isn't difficult, you can choose your type of OZ and there are some great rubber banding options for modification (like Oz Runways, ForeFlight Mobile, etc). Overall, a good product! It certainly saved me from 'map and compassing' my way around!
I post this from the perspective of a computer literate glider pilot (yes, one of the 12 :P ) and low glider time, high powered time. It was a competitive flight but not a competition (ie. only amongst friends)
CJ - B3
Old May 16th 15, 04:46 PM posted to rec.aviation.soaring
Dan Marotta
Great review! I would only ask about battery life with respect to
flight time.
On 5/16/2015 8:37 AM, wrote:
My own iGlide experience came about from being an eeejit. I left my Oudie 3 at home (a country different to my gliding location/s) and wanted a cheap stand-in to use in a club glider for a 500km task. For me, iGlide worked really well. It logged the entire flight, uploaded to OLC directly as well as emailing the file in both .igc and .kml formats to myself. It also synced with the iPad version via Dropbox. The iPhone was held in a suction mount in vertical orientation and was always readable, no washout in the sun. I use an iPhone 5 and the screen could do with being a little bigger (# of nav boxes are limited). An iPad mini would be too big unless panel mounted. An iPhone 6 would be better and a 6+ great. UI is intuitive and easy to use. I used it without the local TP's because unlike maps and airspace, they can only be loaded via iTunes and I was without my laptop too. Task creation isn't difficult, you can choose your type of OZ and there are some great rubber banding options for modification (like Oz Runways, ForeFlight Mobile, etc). Overall, a good product! It certainly saved me from 'map and compassing' my way around!
CJ - B3
Dan Marotta
Old May 17th 15, 08:05 PM posted to rec.aviation.soaring
John Carlyle
iGlide loads turn points just fine using Dropbox - you don't need iTunes. To do it, activate Dropbox (menu|interfaces and sensors|dropbox sync). Then on your PC move your waypoints into dropbox/apps/iglide/wpt.
-John, Q3
CJ - B3
iGlide Ben S Soaring 31 February 16th 20 04:14 AM
iPhone 6 Plus and iGlide jfitch Soaring 39 May 20th 15 01:07 AM
iGlide Mike Rinaldi Soaring 4 April 28th 15 12:48 AM
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 03:24 AM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
