Use of ridge lift for tow - review of procedure/protocol
Old July 5th 15, 09:55 PM posted to rec.aviation.soaring
Bruce Hoult
Default Use of ridge lift for tow - review of procedure/protocol
On Friday, July 3, 2015 at 6:01:02 PM UTC+3, Dan Marotta wrote:
There was an article in Soaring back in the 80s, I believe, which
discussed rope tension during tow.* It's not very much for a glass
glider (20 lb) and I wouldn't think more than 40 lb. or so for a
drag master (2-33).* There's no harm in releasing at that tension.*
On a cross-country tow, yes. Not when climbing at 700 fpm at 70 knots! Then you've got to add 1/10th of the glider weight from the climb to the 1/40th of the glider weight from the drag.
i.e. more like 100 lb tension than 20 lb (for a modern single seater with a bit of water)
PowerFLARM protocol 71? kirk.stant Soaring 1 May 10th 15 04:46 PM
Who Knew? (dipping protocol) CupCaked Piloting 0 April 26th 11 04:59 PM
Bizjet protocol JS Soaring 5 September 4th 06 06:29 AM
A fine ridge day in PA - the Ridge Soaring Irregulars ride again QT Soaring 0 April 6th 06 04:01 PM
Looking for Ridge Lift/Turbulence Diagram DrJack Soaring 22 November 14th 03 08:49 PM
