WTB E-Vario
Old September 28th 15, 12:14 AM posted to rec.aviation.soaring
Default WTB E-Vario
Greetings JJ.
I am really after a Borgelt B400. I used an Lnav many moons ago (1990) and although a good unit at the time a little antiquated.
Thanks for the offer. That's a great price but the snow will be here soon!
Old September 29th 15, 05:14 AM posted to rec.aviation.soaring
Default WTB E-Vario
I'll echo JJ's comments about the LNAV. I bought mine in 1992 and it's worked great ever since, for most of that time coupled with an "antique" Compaq 1550 running Glide Navigator II. I'm currently exploring a flight computer upgrade using open source software (e.g, TopHat) and a cheap tablet. But based on input from several pilots whose opinions I trust, including several national champions, I've been reassured that any improvement in the new varios vis-a-vis the LNAV is modest, at best, and doesn't justify my investing the required price. I'll revisit if it looks like I need more of a data stream than can be provided by my current hardware (or if my fellow pilots are lying to me in order to hobble my performance!) but in the meantime, I'll continue to rely on the LNAV.
Chip Bearden
ASW 24 "JB"
U.S.A.
Old September 29th 15, 11:35 AM posted to rec.aviation.soaring
Tango Eight
Default WTB E-Vario
Chip Bearden
ASW 24 "JB"
U.S.A.
It's very easy to install a top quality vario and drag it down to below LNav performance. Sharing a TE source with a mechanical vario (think of it as a big leak) is the most common problem I see. How much havoc this causes depends upon things we don't have good ways to measure (e.g. the impedance of the TE system).
Evan Ludeman (ClearNav guy)
Old September 29th 15, 02:26 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default WTB E-Vario
If you split the total energy line, as far aft as possible, the cross-talk between varios is all but eliminated. I am running an SN-10 and B300 that share the TE signal that is split under the seat with 2 lines going forward.my varios are side by side and I see no cross-talking going on.
JJ
Old September 29th 15, 02:30 PM posted to rec.aviation.soaring
Default WTB E-Vario
I suspect you're right, T8. Would that also apply to the LNAV itself? That might make me finally address the issue of sharing a triple probe TE with my Winter backup vario, which has been the case since the glider was new in 1992. The biggest sin, I imagine, is using a "T" connection immediately behind the instrument panel rather than a "Y" farther back in the fuselage. Question: would you expect both varios to benefit from this, or just my LNAV?
Chip Bearden
ASW 24 "JB"
U.S.A.
Old September 25th 15, 03:37 AM posted to rec.aviation.soaring
Default WTB E-Vario
Butterfly vario side-by-side with ClearNav vario [email protected] Soaring 30 May 22nd 13 07:11 AM
What vario is this? [email protected] Soaring 6 December 6th 12 11:30 PM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
TE vario G.A. Seguin Soaring 8 June 8th 04 04:44 AM
WTB LD-200 Vario Romeo Delta Soaring 0 June 4th 04 03:08 PM
