FLARM in Stealth Mode at US 15M/Standard Nationals - Loved It!
Old August 9th 15, 12:39 AM posted to rec.aviation.soaring
Default FLARM in Stealth Mode at US 15M/Standard Nationals - Loved It!
On Saturday, August 8, 2015 at 12:51:17 PM UTC-4, Ron Gleason wrote:
On Saturday, 8 August 2015 10:28:15 UTC-6, Andy Blackburn wrote:
Seems like many of the procedures to enforce turning Flarm on and off or adjusting range are the same or similar to enforcing stealth mode, the primary difference being in one case you are ensuring they don't have too much range and in the other you are ensuring they don't have too little - log files, Flarm ground stations, etc have been proposed for both.
Also worth pondering - in a world with ADS-B we will ultimately end up in a world were stealth mode is effectively voluntary - like today only more so.
9B
If the SSA Competition Rules Committee or Competition Committee decides that stealth mode is required at some level of contests and a rule is implemented the enforcement of the rule *MUST* be automated, just like airspace violations are checked within WINSCORE or SeeYou Competition.
Please do not put yet another level of burden on contest organizers.
This was contemplated several years ago. In discussing what I called "US Stealth", I asked Urs at Flarm if the Flarm device could be put into Stealth and locked for a predetermined time so that a single verification, presumably during the practice period, could be done. He indicated that this was quite feasible. If Stealth in competition takes off, obviously scorers all over will want this quickly. This also avoids the problem of not being able to supply a complying log because of a failure.
UH
Old August 10th 15, 01:33 PM posted to rec.aviation.soaring
2 cents from a Rookie so take it for what it's worth.
I put my FlARM on Stealth for the Nationals - worked just as good to find people I could not see quickly and were close enough that is was comforting to find them.
I bought Flarm originally to see power traffic coming down out of a cloud on IFR when I get a little too close to cloud base - it still does that nicely.
When I am at home if I want to know where other gliders are I just call them on the radio and they tell me location, height and if they have "great lift" - so I am not sure if/why I will change the FLARM config file.
I have competed in pretty high level sports and have no disire to gain tactical advantage by seeing other gliders outside on eyesight range - true sport is about the inner game, which is where satisfaction really lives Some winners are never satisfied with their performance.
Stealth worked well makes sense for contests.
WH
Old August 8th 15, 07:06 AM posted to rec.aviation.soaring
Jim White[_3_]
At 02:15 08 August 2015, Papa3 wrote:
I agree - lots of good discussion. =20
I would again emphasize though that nobody has yet put the effort into
buil=
ding a true Tactical Leeching Tool. Flarm just provides data and a
collisi=
on warning algorithm which seems to work extremely well for the purpose
for=
which it was designed. I have been truly impressed at how few spurious
wa=
rnings I have gotten in either unrestricted or stealth mode. As a safety
to=
ol, I love it. =20
But, please consider what folks could do IF they put their minds to it.
V=
isualizing and presenting the Flarm data for tactical advantage has
hardly
been tapped at all. Imagine a filtering algorithm that takes in Flarm
dat=
a from a bunch of gliders. It figures out if this is a "gaggle"
(defined
by at least 2 gliders circling for at least 30 seconds and climbing, for
ex=
ample). Now, imagine that it smooths the climb data from the gliders
th=
at are identified as Gaggle A with an indication of average climb rate
(30
second, 60 second, duration of climb) as selected by the user. Imagine
t=
hat another gaggle (Gaggle B) nearby is similarly filtered and
displayed.
Color coding is applied with strongest average climbs in Green and
decreas=
ing in size and intensity with weaker climbs. Also, the user can set
aler=
ts to indicate if specific targets are in Gaggle A or Gaggle B. Okay,
Gag=
gle A is clearly averaging a better climb, and as a bonus P7 is part of
the=
group. This is not 10 years out sort of stuff. I've already written
spe=
cs for several of these examples. =20
I suspect that the reason a lot of folks are finding Flarm of limited
tacti=
cal value right now is largely unfamiliarity with the tool combined with
Us=
er Interfaces which are not yet optimized for competition. My Flarm
routin=
ely provides 7.5km to 8km range, which is basically a corridor 15km wide
(l=
eft and right). And contrary to statements made in this thread, many
the=
rmals are relatively persistent and regenerative. All you have to do
to
see this in action is to download competition files from a recent contest
a=
nd replay the flights in maggot race mode on SeeYou. If you synchronize
o=
n start time, you can see gliders converging on exactly the same spot
often=
times 10-15 minutes apart when you shift back to real-time. So,
having
a choice of 2 gaggles displayed each of which is only 3 miles away and
KNOW=
ING which gaggle is the stronger climb is a very real tactical advantage.
Similar examples apply to the pre-start, straight glides, etc.=20
Of course, if everyone has it, then maybe the playing field is again
level.=
Except that instead of looking out the window and eyeballing other
glider=
s to figure out which group is climbing better relative to you, you'll be
z=
ooming in the gain on your Leeching Window. Sort of like good weather
rad=
ar operators today who know how to identify the really ugly cells vs. the
m=
ore benign cells. Maybe that's the exciting next frontier? =20
P3
Astute thinking. Flying the computers is the problem for me.
AOPA Convention - B29 FIFI ------ Stealth Mode Noted!!! Stetson J.B. Mentzer Aviation Photos 0 December 27th 10 12:07 AM
Flarm and stealth John Cochrane[_2_] Soaring 47 November 3rd 10 06:19 AM
Standard Nationals-Hobbs BGMIFF Soaring 3 July 21st 04 06:16 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Standard Class Nationals Sam Giltner Soaring 1 August 21st 03 01:42 AM
