fiberglass repair?
Old August 13th 15, 05:25 AM posted to rec.aviation.soaring
Bob Kuykendall
Default fiberglass repair?
On Wednesday, August 12, 2015 at 1:52:27 AM UTC-7, krasw wrote:
Is there a reason this damage cannot be repaired by putting simple multilayer patch (right size, of course) on the inside surface? With proper overlap it gives you original strength without time-consuming surface finish work. Why not take advantage that fuselage shell is not sandwich structure and inside of the shell is easily accessible?
The conventional reasoning for not going with a simple patch like that is that it results in a steep stiffness gradient at the site of the damage. The more widely accepted scarf repair, when properly done, restores not only the strength, but also the stiffness distribution of the original. That helps ensure that the repaired area will not be prone to delamination or cracking as it ages.
At issue is that gliders tend to be very limber structures--they bend a lot.. As they bend, some parts of them get stretched out, and other parts get pressed together. And where there are abrupt changes in stiffness, for example, where there is a change in sectional thickness, the stretching or shrinking happens unevenly. That uneven stress distribution can cause cracking in the most brittle layer, the gelcoat. Sometimes the cracking can go deeper, into the structure below, but that's pretty rare in a well-designed glider. Typically you'll see this effect in gelcoat cracks that form at the corners of airbrake boxes, along ribs and bulkheads and other internal reinforcements.
Thanks, Bob K.
Old August 13th 15, 05:48 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
At issue is that gliders tend to be very limber structures--they bend a lot. As they bend, some parts of them get stretched out, and other parts get pressed together. And where there are abrupt changes in stiffness, for example, where there is a change in sectional thickness, the stretching or shrinking happens unevenly. That uneven stress distribution can cause cracking in the most brittle layer, the gelcoat. Sometimes the cracking can go deeper, into the structure below, but that's pretty rare in a well-designed glider. Typically you'll see this effect in gelcoat cracks that form at the corners of airbrake boxes, along ribs and bulkheads and other internal reinforcements.
Thanks, Bob K.
Think you misunderstood his question, Bob. He was asking "Why scarf from the outside and make a very large area you have to re-finish? Why not scarf the inside, and have a small area that needs the more aesthetically time consuming finish work outside?" Inside is less "optically critical".
Eric says the manufacturer does not approve of such repairs. I have seen several manuals, and all seem to show scarfing to be done from the outside for a glass shell. However, they are also all showing the repair as a hole into something that you do not have access to the other side of as you close it up. In the cockpit, you would have this access. In the tailcone, you would not. And on the inner skin of cored structure, I have seen splices shown in both directions for the inner skin. Honestly, you are putting back the same number of plies, with the same orientation as what was there before the break. Can you tell me the repair will be weaker if the scarf is made from one side than the other?
The bigger thing is that it is MUCH easier to scarf a convex surface (outside of the fuselage) than a concave surface (inside of the fuselage).
Steve Leonard
Fiberglass glider repair in Southern California? Roger Worden[_2_] Soaring 4 September 2nd 12 02:37 AM
this guy doesn't believe in fiberglass rwhughe Aviation Photos 0 February 27th 10 06:05 AM
Fiberglass revisited Lou Home Built 3 October 31st 06 12:50 PM
Fiberglass seperation Lou Home Built 7 September 25th 06 04:03 AM
Fiberglass/gelcoat repair question Kilo Charlie Soaring 9 April 19th 05 03:30 PM
