General Zinni on Sixty Minutes
Old June 1st 04, 07:32 PM
Howard Berkowitz
In article , Ed Rasimus
On Tue, 1 Jun 2004 12:55:05 -0400, "George Z. Bush"
"Ed Rasimus" wrote in message
By your rationale the only way a nation possesses WMD is if ALL of
their weapons fit the class? We've found one Sarin filled shell in a
country the size of California. Saddam had twelve years of experience
in hiding WMD from UN inspectors. He had a couple of years of warning
regarding build-up to invasion. He had almost a year after expelling
the UN inspectors to dismantle, export, hide or decommission WMDs.
Is Sarin a chemical weapon? Would the components of a binary weapon by
a chemical weapon if they were held in two separate locations?
Under the Chemical Weapons Convention (CWC), the Australia Group
agreements, and the US Militarily Critical Technologies list, unitary
sarin is definitely a chemical weapon, as are the phosphofluoro
precursors. The latter are in the same Class I category as GB (Sarin).
Plain isopropanol and elemental sulfur, the basic second components of
GB and VX, are only "dual use" by a generous interpretation --
isopropanol is common rubbing alcohol. A better binary precursor (OPA)
mixes diisopropylamine with isopropanol; if there is at least 30%
diisopropylamine, the mixture is considered a dual use material not
explicitly classifed by the Australia Group.
Is a
biological weapon only a biological weapon when it is employed,
otherwise it's just a case of the sniffles?
I would say that it has to be weaponized and associated with a plausible
disposal system. The same botulinus toxin used in medical Botox is a
weapon when in much larger quantities and associated with a dispersion
system.
I baby-sat a B-61 Y-1 at 345KT was that a WMD? If we only had Fat Man
and Little Boy (which is all we had) and then we dropped them on
Hiroshima and Nagasaki, did we then no longer have WMD? Or, since
those two weapons were only 20-25KT were they not even WMD at all?
For simplicity, any nuclear explosive should be considered WMD. That
being said, PGMs may be as or more useful for a given application as
were tactical nuclear weapons with much less accurate delivery.
The relationship between the jailers and WMD isn't a very rational
argument. How much Sarin will you allow to be deployed in New York
City before you take offense?
Let me speak to the more general case of cholinesterase inhibitors
("nerve gasses"). Diisopropyl fluorophosphate was one of the first such
agents considered by the US, but also has perfectly legitimate
applications in opthalmology. How much does the local distributor have
in its warehouse? I don't know.
Research laboratories may legitimately have small quantities of nerve
agent precursors or actual agents. Increasingly, there are licensing
and quantity restrictions. Certainly, any laboratory that needs to check
detectors needs some quantity, and a reference laboratory that confirms
particular agents will need samples. Quantity limits on biological
toxins are much more stringent.
Some sample regulations based on Federal regulations, this example from
the University of Pennsylvania:
The medical use of toxins for patient treatment is exempt.
The following select agent toxins are exempt if the aggregate amount
under the control of one principal investigator does not, at any time,
exceed:
- 0.5 mg of Botulinum neurotoxins
- 5 mg of Staphylococcal enterotoxins
- 100 mg of abrin, Clostridium perfringens epsilon toxin, conotoxin,
ricin, saxitoxin, shigatoxin, shiga-like ribosome inactivating protein,
and tetrodotoxin
- 1,000 mg of diacetoxyscirpenol and T-2 toxin
The following select agent organisms or toxins are also exempt:
- Any agent or toxin that is in its naturally occurring environment
provided it has not been intentionally introduced, cultivated, collected,
or otherwise extracted from its natural source.
- Non-viable select agent organisms or nonfunctional toxins.
- The vaccine strains of Junin virus (Candid #1), Rift Valley fever virus
(MP-12), Venezuelan Equine encephalitis virus vaccine strain TC-83
So, the bottom line is that an acceptable quantity is greater than zero.
Would it be more acceptable to use it in
Jerusalem? Would it be alright to spread three liters of Sarin in
Kuwait City?
How many WMD rounds does it take to equal possession of WMD in your
convoluted logic? Would two be better than one? Or will you hold out
for exclusive WMD rounds and no conventional? Then, one conventional
round would prove the non-existance of WMD, despite the other rounds?
Let us focus on the "mass" in mass destruction. Aside from the aspect
of fear (personally, I'd far rather die of sarin than napalm), to be a
WMD, the weapons have to be available in militarily significant
quantity, such that they cause more destruction/effect than an
equivalent quantity of conventional weapons. I'm certainly willing to
bend this rule to include active R&D or manufacturing programs.
The rule of thumb for a militarily significant amount of G-agents is in
the tons. Yes, with skilled dispersion, a chemical weapon can cause far
more casualties than conventional weapons. In our one terrorist example,
compared to the massive quantities used in WWI, Aum Shinryo managed
about a dozen deaths. Casualties numbered in the hundreds to low
thousands, but a significant proportion of cases were trauma caused by a
panicking crowd, or psychosomatic. Several Claymore mines on a subway
platform would almost certainly cause more casualties.
Old June 1st 04, 09:21 PM
Paul J. Adam
In message , Ed Rasimus
writes
convoluted logic?
To quote something I wrote earlier...
Let's - for the sake of simplicity - assume the munitions and facilities
have a trustworthy date stamp, however ascertained. Hard to do, but it
simplifies the terms.
1998 and earlier, I'm willing to accept a few (call it three, offhand)
"WME stockpiles" that are - for a rule of thumb - a pallet or less of
shells, 122mm rockets, or precursors each. 1991 or earlier, I'd raise
the bar quite a lot higher, because they prepared to fight a defensive
war and then lost it massively and that's where large amounts of kit go
missing. (We're still occasionally digging up buried caches of 1940s No.
76 grenades here in the UK, which is a problem because they're beer
bottles filled with a benzene, rubber and white phosphorous mixture -
not nice to accidentally put a spade through one)
Post-1998, "a pallet" of filled basic munitions or of filler for them,
or a single weapon that was a significant advance on their previous
capability, would be conclusive proof. Less than that would be a very
unwelcome surprise, though not decisive (we know they *wanted* to keep
their programs going, but the claim was that the programs existed and
were an immediate threat)
Opinion, assayed at $0.02 exact.
He thinks too much: such men are dangerous.
Julius Caesar I:2
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Old June 1st 04, 09:53 PM
George Z. Bush
First, let's note that I said or wrote none of which "George Z. Bush"
has posted here below the attibution header!
(Snip)
I took out all of an exchange you were having with someone else which was
irrelevant to what I wanted to say. No need for you to be so defensive about
it....it just wasn't pertinent, so I deleted it.
How about considering that we are quick to disavow the outrageous behavior of
a
handful of our sadistic jailers as being representative of us as a nation,
but
we deny the Iraqis the same right to disavow the existence of a single
artillery
shell of dubious age filled with Sarin as being representative of an arsenal
of
WMDs they would have used on us if they had existed.
One sadistic jailer doesn't mean that all of our jailers are sadistic any
more
than one Sarin-filled artillery shell means that all of the artillery shells
Iraqis had were filled with Sarin. It took us a whole year to find (or 'fess
up
to) one of each.
George Z.
WMD is an acronym for Weapons of Mass Destruction. That is "weapons"
(plural)....and One of anything does not make it plural. You want to make a
federal case out of finding one artillery shell after a year of intense looking
by thousands of troops, go right ahead. I'll just rest my case on the theory
that one weapon does not an arsenal make, and you can pooh-pooh me if it makes
you feel better.
a chemical weapon if they were held in two separate locations? Is a
Of course it's a chemical weapon. But one artillery shell does not constitute a
threat that warrants embarking on an active war over. Not only that, but we
didn't even know for a fact that they had that one weapon when we started the
war....we apparently started it on some Mickey-Mouse intelligence information
that it took us a year to find out wasn't accurate.
By your logic, we probably ought to be at war with half the world if those
nations possessed one chemical or biological weapon that they might someday
consider using against someone for some reason somewhere down the road. Tell me
the Chinese don't have one or more, or the Pakistanis (who, you will recall,
sold nuclear know-how to the Libyans), or the Russians, or the Israelis or, for
that matter, even the Saudis. Numerous countrys, many of whom we have
disagreements with, have WMDs, but we don't go to war with them because of it.
Sounds like you want to refight WWII because we had and used nukes. That's a
bit more nonsensical that I care to bother with. Or are you suggesting that we
were the bad guys because we developed them and used them?
City before you take offense? Would it be more acceptable to use it in
Kuwait City?
When all is said and done, your arguments are sophomoric and thoroughly
unconvincing. They're not worthy of individual responses.
C'mon George, confess that you didn't think it through when you wrote
that/
Ed, it's all in the eye of the beholder, and I like to think that my arguments
were more logical and convincing than your efforts to belittle them.
Perhaps it's one of those times when we need to agree to disagree and simply
move on.
George Z.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
Smithsonian Institution Press
ISBN #1-58834-103-8
Old June 1st 04, 07:04 PM
Kevin Brooks
"George Z. Bush" wrote in message
(Snip)
of a
but
artillery
arsenal of
Bad logic. We never declared, as part of a ceasefire agreement from the
*last* conflict, that we had no individuals who could/would commit criminal
acts in our military services. And you seem to be forgetting the other round
reported (mustard), the hiding of equipment and documents related to WMD
development (as reported by Kay in his report), the continuing development
work on ricin (also testified to by Kay), etc....
more
shells the
'fess up
to) one of each.
You are the only ignoramus who has claimed that "all of the artillery shells
the Iraqis had were filled with Sarin". To be completely honest (something
you are, I know, loathe to be), AFAIK we have not found *any* shells "filled
with Sarin". What we have found is the remains of one shell that was filled
with the binary components of sarin (another wee problem, since the Iraqis
never acknowledged having *any* such shells in their possession, at *any*
time--which is another violation...), evidence of their attempting to hide
equipment, documents, and cultures related to bio/chemical warfare programs,
a continuing ricin development effort, etc. But I am quite sure that if it
suits your purpose (being the damning of GWB at all costs, of course), you
will soon assign the "all of the artillery shells" quote to *him* at the
nearest opportunity--who cares if it is accurate, right? Just as you
obviously don't care about accuracy in regards to your "single artillery
shell...filled with Sarin" statement, eh?
Brooks
George Z.
Old June 1st 04, 04:56 PM
Paul J. Adam
writes
On 01 Jun 2004 10:09:37 GMT, (ArtKramr) wrote:
Who knew we were being lied to about WMD? We never should have believed that
bum and his neocon liars..
Conveniently overlooking the recent Sarin discovery in Iraq
One shell, apparently dated pre-1991 - this isn't a clear and present
danger. (The production facility for it would be - no signs so far)
and the
presence of Al-Zawaheri at the beheading of Nick Berg.
Alleged - weren't the killers hooded?
Note also that at one point there was a declared "flypaper strategy" of
using Iraq as bait to draw in and destroy terrorists - was al-Zawaheri
in Iraq before 2003, or did he (or his adherents) go there to kill
Americans post-war?
If it doesn't fit the perconception simply ignore it.
On the other hand, don't latch too solidly onto it just because it's
comfortable.
We all might start at this point by acknowledging that Islamic
fundamentalist terrorism is NOT a national movement. The repetition of
things like "why Iraq" or "the 9/11 perps were all Saudi" ignores the
fact that the terrorists don't represent a particular country but
rather a particular ideology that is inimical to democracy and
Judeo/Christian societies.
However, the al-Qaeda movement in particular and the Wahabbi ideology in
general are both solidly based in and funded from Saudi Arabia. (Where
al-Qaeda terrorists are still operating)
A brief review of Samuel Huntington's "Clash of Civilizations" might
be in order.
So you attack fundamentalist Islam by invading one of the more secular
states in the Middle East? Does not compute...
Julius Caesar I:2
Old June 1st 04, 08:02 PM
Steven P. McNicoll
"Paul J. Adam" wrote in message
Didn't the Iraqis claim they never had any Sarin at all? If that's the
case, doesn't the presence of even one shell prove they did not abide by the
1991 agreement?
That seems to be happening now.
Old June 1st 04, 09:18 PM
Paul J. Adam
In message . net,
Steven P. McNicoll writes
No, they claimed that they'd had a fair amount pre-1991 and had since
destroyed almost all of it, apart from some odds and ends that had gone
adrift in the course of two wars, a short sharp shower of ****e and a
prolonged game of hide-the-programs.
The inspectors who audited their claims found some discrepancies, like
the alleged binary shell R&D program that *may* have produced this round
and thirty to forty like it, for further study: however, the further
study was pre-empted.
If that's the
1991 agreement?
The US and UK still turn up chemical and (occasionally in the US)
biological munitions here and there - does that prove we're in violation
of treaties? Or just that accounting down to individual rounds is a
tricky process?
Significant quantities of sarin are measured in the hundreds of kilos,
at least, for military effects. I'd be looking for a significant and
recent stockpile, or better yet a recent production program.
One shell, over a decade old, whose users seem to have had little idea
what it was, isn't particularly persuasive that there was a significant
threat.
Julius Caesar I:2
Old June 1st 04, 09:36 PM
Chad Irby
In article . net,
the case, doesn't the presence of even one shell prove they did not
abide by the 1991 agreement?
They supposedly only did "research" on binary sarin rounds, and that
*after* 1991.
The existence of this round, at *all*, shows that they weren't complying
with their obligations by informing the UN of the research program.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old June 1st 04, 08:40 PM
Denyav
For the US:
1)Iraq is tactical target
2)Saudi Kingdom is strategic target
3)Egypt is the trophy.
Unfortunately US planners forgat something that some others might have
different great game plans (like following):
1)Iraq is nothing
2)Saudi Kingdom is tactical target
3)Iran and Turkey are strategic targets
4)USA is the trophy
Old June 1st 04, 10:07 PM
Denyav
I am sure we wont be overlooking when somebody discovers ex-Bulgarian Scuds
with chemical warheads on right time.
(Saddam never received any Scuds from Bulgaria,but it is only a small detail)
be in order.
Samuel Huntingtons ties to some semi-secret but very powerful societies explain
why he wrote that book.
The motto of this organization is
"Ordo Ab Chao"
This organisation is actually aganist ALL major religions fights for centuries
to destroy every religion and replace them with Paganism.
The fight between major religions is an excellent tool realize their final
goal.
Who is Mr.Al-Whatever?
Everbody who thinks that 9/11 was not a domestic vaccination operation ignores
works and findings of the Office of Net Assesment and the existence of an
organization in US with more executive powers than US President !.
(The name of this organization is NOT FBI or CIA)
You are totally wrong.
According to the findings of Marshall&Co paradigm shift in warfare and
predicted natural disasters (some of them with the help of HPM weapons of
course) could create a chaos situation in US that could not be controlled by
existing (pre-9/11) structures.
So,the country needed more military like structures and organizations in other
words US needed more military style discipline and less liberalism.
How could you implement neccesary changes?
1)You tell everything to the public and call for their support.
(But if you do that the chaos predicted to take place 15-20 later might start
tomorrow,so not a good idea)
2)You create an imaginary enemy and implement all neccesary measures that you
will need to face challenges of next decade and after,under pretext of fighting
an (imaginary) enemy.
US will be a much more militaristic and disciplined society in near and medium
term future,but the President still be a civilian.
But US citizens wont be able to elect their presidents in foreseable future,as
all Presidents in foreseable future will be "selected" not "elected".
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Home Built 3 May 14th 04 11:55 AM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 10:43 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aviation Marketplace 0 May 11th 04 10:43 PM
Highest-Ranking Black Air Force General Credits Success to Hard Work Otis Willie Military Aviation 0 February 10th 04 11:06 PM
