New Airplanes in WWI (ISOT)
Old June 8th 04, 12:16 PM
Jack Linthicum
Howard Berkowitz wrote in message ...
In article , "Keith Willshaw"
"Jack Linthicum" wrote in message
om...
Perhaps not the airplanes but their armament, a machine gun based on
known Gatling technology but significantly lighter in weight.
The problem would synchronising the gun with the engine.
Vickers and Lewis guns were perfectly adequate
The
Brits used incindiary rockets on the Zeppelins, would napalm on the
trenches be a significant addition?
Not really , they dropped poison gas and phsophorus
bombs as it was.
Cluster munitions would be even more effective, although the timing
would be a challenge.
Flamethrowers need someone on the cold end to run it, IIRC in WWII
this was an aiming point for the Japanese who were being assualted by
them. Napalm is more fluid, ie runs along trench lines, and less
personal, drop it and forget it. If you need a second dose, bring in a
second raid. With those large trench complexes it would seem to be a
weapon without defense.
Old June 13th 04, 03:25 PM
Jack
The Horny Goat wrote:
Vietnam certainly demonstrated napalm could be effectively delivered
in bomb form though...
That was proved (again?) in Korea.
I question whether it was available in large
enough quantities to cause grief to miles
and miles of trench lines.
Napalm was available in sufficient quantities to turn targets such as trenches
into graves, once we found them. "Shake and bake" also worked on other related
targets
Napalm was a bit more expensive to apply than the targets and their defenses
were to construct, of course. But we solved that problem nicely by avoiding the
highest value targets. We became expert at killing trees and dirt in the South,
and avoiding ships, port facilities, and dams in the North.
Heaven forbid we should destroy the enemy's ability to resist when it is so much
more convenient to destroy the environs of our allies. But then war being
diplomacy by other means, the so-called "diplomats" had their way, just as they
are doing today.
Jack
FS: 1988 "Aces High" (Military Airplanes) Hardcover Edition Book J.R. Sinclair Aviation Marketplace 0 August 23rd 04 05:18 AM
Ever heard of Nearly-New Airplanes, Inc.? The Rainmaker Aviation Marketplace 1 June 23rd 04 05:08 PM
SMALLL airplanes.. BllFs6 Home Built 12 May 8th 04 12:48 PM
FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set J.R. Sinclair Aviation Marketplace 0 April 12th 04 05:57 AM
Sport Pilot Airplanes - Homebuilt? Rich S. Home Built 8 August 10th 03 11:41 PM
