At 22:04 10 February 2016, Six-Seven Romeo wrote:
I am in the midst of an instrument panel refit on a Standard Cirrus that wi= ll include a PowerFLARM core. The mount of the FLARM antennas is always a = lifely subject here on RAS. I have read and absorbed the very instructive = FLARM antenna placement application note. Anyway, someone mentioned to me years ago that it is a bad idea to mount th= ings on the canopy or canopy rails (PDA, Camera, etc) as it could prevent f= ull ejection of the canopy and leave it tethered to the fuselage by a power= or control cable. This could make a bad situation worse (take that statem= ent for what it is worth). Truth or myth? Assuming for the moment that the above is true, then same logic leads me to= the bad idea of mounting things onto a glare screen that is attached to th= e canopy like with a Standard Cirrus. If mounting things on the canopy is = bad, then mounting things on a canopy attached glare screen is also bad. This finally leads me to how to mount FLARM antennas. Often FLARM antennas= are mounted onto the glare screen. But two FLARM antenna coaxes would def= initely be stong enoght to tether the canopy, back to bad again. An option= al placement of the antenna would be below, but not attached to, the glare = screen. However this might impact coverage. What are your wise opinions? One answer would be to use a SMB Connector, which is a snap-in co-ax connector, just requires a firm pull to disconnect (adrenalin helps!). |
Reducing canopy glare caused by instrument face reflections. | [email protected] | Soaring | 1 | November 11th 13 09:22 PM |
PowerFlarm mounting question, and an idea for mounting devices | brianDG303[_2_] | Soaring | 2 | October 23rd 11 06:51 PM |
be safe | Raymond Staton | Piloting | 0 | October 9th 09 06:22 PM |
anti-glare PDA screen protectors | Gary Emerson | Soaring | 4 | May 7th 08 03:19 PM |
Canopy glare and UV protection? | Kevin R. Anderson | Soaring | 1 | May 10th 04 01:09 AM |
