On Mon, 07 Mar 2016 17:52:54 -0800, kevinsoar wrote:
I went on their web site, but several glues. Any idea which one? Disclaimer: the following is model aircraft buildig and general use experience, not direct aviation use, so please bear that in mind. Also I think the formulation may have changed a bit recently, since the 'standard' Araldite used to be yellowish when mixed and is now milky white. There are two common Araldite types. - "Standard", which used to be known as '24 hour' Araldite comes in blue/ white coloured tubes, takes about 24 hours to fully cure at room temp, and gives a really tough joint. It tends to soften if you heat it after its cured. So much so, that if you know its going to be used at a higher temp, you should let it cure at the expected use temp or a bit hotter. This is the one I use for general engineering and anywhere I expect the joint to be load bearing. - "Rapid" comes in red/white tubes, is handlable after 30 mins and full strength after 1-2 hours. I've never heated this after curing so have no idea whether it heat softens because I normally use it for gluing wood and plastic. Its sets hard rather than tough: the glue shatters if overstressed. I only use it for low stress joints and/or for quick repairs where speed of cure is more important than glue strength. Bottom line: anywhere that you care about joint integrity, use Araldite Standard in the blue/white tube set. Also, is there any concern with changing temper on the aluminum push rods when heating? As others have said, if you heat Araldite epoxies hot enough for long enough to affect the temper of metal its joining stuff, the epoxy bond will be destroyed rather than softened. And, like them, I'd use a hobby- style (900w) heat gun to soften an existing epoxy joint. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Wedekind sleeve | Hartley Falbaum[_2_] | Soaring | 4 | February 5th 14 12:54 PM |
Wedekind sleeve for Std Cirrus | John Galloway | Soaring | 8 | July 9th 13 02:15 PM |
pvc tubing/sleeve source? | Jim Burns | Owning | 4 | September 28th 06 03:36 AM |
pvc tubing/sleeve source? | Jim Burns | Home Built | 4 | September 28th 06 03:36 AM |
Source for Wedekind sleeves - AS-W20a | Mark Grubb | Soaring | 7 | April 6th 04 08:19 PM |
