Shameless update from Dale Kramer
Old March 16th 16, 07:55 PM posted to rec.aviation.soaring
Steve Koerner
Default Shameless update from Dale Kramer
On Wednesday, March 16, 2016 at 12:22:12 PM UTC-7, DaleKramer wrote:
Craig,
Thanks, right now I plan to have sort of a log on its Kickstarter page, at least for the 1/4 scale vLazair.
Dale
Cool concept. There are a couple things I can see to worry about. It would seem like transitioning from horizontal to vertical landing would involve a risk that the pilot not make it all the way down to the parked position before his 3-4 minute battery life expires.
The other thing that looks worrisome is vulnerability to ground wind in the vertical standing position.
Dale will be pleased to know that the upcoming Nephi nationals does require PowerFlarm. Hopefully that trend will continue.
Old March 16th 16, 08:12 PM posted to rec.aviation.soaring
DaleKramer
Hi Steve,
The transitions should be very quick. Thrust to weight will be about 1.3/1 so acceleration into cruise should be very quick. Landing transitions will basically be just a normal final approach to a touchdown spot but with the idea of being 50 ft high (or so) when you get there. This transition will be very easy to verify and demonstrate with the 1/4 scale. Can always add a few more pounds of battery if needed.
I am hoping to design the gear such that a single person can tip it from tail to nosegear if it gets windy for a tiedown.
What will be strange is that the 'ideal' landing direction will be a 90 degree crosswind landing wrt wind efects.
Great comments!
I saw that for Nephi, hope it continues for a while. Can't afford a glider yet.
Thanks,
Dale
Old March 16th 16, 08:58 PM posted to rec.aviation.soaring
Steve Koerner
On Wednesday, March 16, 2016 at 1:12:18 PM UTC-7, DaleKramer wrote:
Hi Steve,
Great comments!
Thanks,
Dale
It will be interesting to see how that vertical landing works out with the model. I can't visualize how a normal approach speed can get you to a vertical position. Without thrust vector control it seems like it would require a high approach speed in order to then pull up to a vertical position and begin backing.
Have you modeled the vertical landing? How high does the aircraft get if things are done correctly? What speed does it back down at? Will the landing be autonomous or pilot controlled?
I can swallow the idea of vertical take-off much more readily than the landing. Maybe I'm just not visualizing the dynamics of the landing problem correctly.
Old March 16th 16, 09:14 PM posted to rec.aviation.soaring
Andrzej Kobus
On Wednesday, March 16, 2016 at 10:07:51 AM UTC-4, DaleKramer wrote:
Some of you know who I am and that I have not had a real sailplane since I sold my Ventus2CX a few years ago. I am still waiting for Flarms to be mandatory in all contests before I try to find a way back into competition.
What I have been doing is flying my electric Lazair and RV8.
A lot of you know I designed the Lazair ultralight aircraft and now I have come up with a new aircraft design that some of you may be interested in (and I have started a Kickstarter campaign to try to fund it).
I hope you'll at least look at my design and who knows, someday I may visit a contest in a vLazair.
Here is a link for more information:
https://www.kickstarter.com/projects...ertical-takeof
Or just go to Kickstarter and search for vLazair (don't forget the 'v').
Dale, good to hear there is still hope we will see you back in contest flying
Andrzej
Art Kramer Andrew Chaplin Military Aviation 8 July 12th 04 11:25 PM
Art Kramer, your computer may be infected old hoodoo Military Aviation 6 May 24th 04 12:43 PM
Question for Art Kramer. M. H. Greaves Military Aviation 2 May 10th 04 05:17 PM
More B-26 Nonsense from Art Kramer funkraum Military Aviation 7 January 21st 04 10:53 PM
ATTN: Art Kramer robert arndt Military Aviation 2 July 4th 03 02:33 PM
